Question about Williams 2509612 Ceramic Mid-Size Heater
How to light the pilot
Where do I put the match to light the pilot?
  • umm_nmrah Jan 05, 2009
    sorry i am not mechanically inclined at all. where is the burner? middle, left, right? can you describe it in relation to the pilot button that I have to push in?
    Thanks
  • 28 Answers
If you look at the burner you will see a line pointing towards it about an 1/2in
dont try to light it if you smell gas, turn it off and let it air out
Posted on Jan 05, 2009
How do i re start the pilot lght
You will need:
a wire hanger or something like that about 14 in long
a small clip and matches to clip to wire.
Turn red knob to off
remove small door covers (Both).
look inside you will see a tube pointing up this is where you put the match to light it.
turn red knob to pilot and push down and hold
light match and put it at end of the tube inside it will light a blue flame
remove match.
all this time holding knob pushed down
continue to hold down for 60 sec
then let it up slowly and turn knob to on
should flame up and start whole burner
replace door your done.
OR call your gas company most will light it for free
Jan 17, 2016 | Water Heaters
How can we ignite the pilot switch
The directions are on the inside cover of the water heater as well as on the paperwork you received with the unit.
If you have none of these, get the make and model number of the unit and look it up on the internet.
General directions to light a gas appliance:
1.Turn the switch to, "Off"
2.Remove the 2 panels at the base of the unit.
3 Identify the pilot device.
4.Get a long lighter or match on a stick that reaches the pilot.
5.Turn the gas knob to the, "Pilot" position
6.Light the match and put it next to the pilot while pressing down the knob
7. Keep the knob pressed for about 45 seconds after the pilot lights
8. Let go of the knob so it's in the, "up" position
9. Turn the knob to the, "On" position
-the water heater should fire up in under a minute.
10. Put the metal panels back into position.
Jul 14, 2014 | Honeywell VR8200C6008
For 10 years, I lit my Williams Direct Vent Wall Furnace by using the red spark ignition button. For the first time, It would not work so I tried to light the pilot light by removing the wingnut to the...
Put a coat over the vent this will stop the it blowing the match out . don't forget to take it off . Pilot my need cleaning or thermocouple replacing .
Mar 28, 2017 | Heating & Cooling
How do you light the pilot for the flat top section of our Imperial 6 top stove?
This range has a standing pilot light for the top burners and griddle top. If you look through the small hole under the flat top griddle you can see a small line about 1/4 inch that runs from the main gas manifold to the pilot light about 6 inches back under the griddle top. You will need a tightly wrapped piece of paper or a long match or small wooden stick, like a chop stick. Light the end of your paper, or stick and put it through the hole all the way to the pilot light. It should catch on fire. Whenever the main gas line is on, the gas will flow through the pilot light. If it will not light, there is a pilot light adjustment that is a very small screw in the middle of a 1/2 inch square metal fitting that is screwed into the gas manifold. If the pilot won't light, this screw may be turned all the way in, thus cutting the gas off to the pilot light. If necessary take a very small flat blade screw driver and turn the screw counterclockwise a half turn. That will increase the gas flow to the pilot light. Another way to light the pilot is to put your burning stick or match into the hole near the burner under the griddle plate, then slowly turn the heat valve to the on position. The main burner will light and then the pilot will light off of it. Don't get your face too close to the griddle when you light it, gas can flash back into your face.
Sep 23, 2010 | Imperial IR-4-G12 Elite Gas Kitchen Range
Pilot lighting
1) Open the door on the bottom of the tank to show the burner. 2) Turn the valve to "pilot" and depress. 3) Light the match, (best if you have a candle/grill lighter), and follow the skinny copper tube from the valve to the burner inside (this is called the thermocoupler). At the end of it, you will see the pilot. 4) Once pilot is lit, keep valve depressed for a minute (this warms the thermocoupler, thus sending a signal to the valve saying the pilot is lit). 5) Let go of the pilot button (usually red). 6) If pilot stays on, put the door(s) back on and turn the valve to "on". You will hear/see the gas ignite when complete. Good luck!
Dec 28, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Read the instructions on how to light the pilot but where I need to put the match I am not sure where to direct the flame to. I see the housing for the pilot but not where inside
You noted above it is a Coleman forced air Heater with a electronic ignition? You don't need a match to light the pilot, it lights automatic on a call for heat at the thermostat.If it does not light, then you have other problems. Let me know.
Good Luck,
Shastalaker7
Nov 04, 2009 | Coleman Propane Forced Air Heater...
Pilot went out and don't know how to lite it
YES YOU DO NEED MATCHES TO LIGHT THE PILOT IT IT DONT HAVE A AUTO PILOT AND IF IT DOES THEN YOU'LD HEAR IT CLICKING OR TRYING TO LIGHT IF NO CLICK THEN YES MATCHES WILL WORK TO LIGHT THE PILOT
Apr 11, 2009 | Williams 1403622 Gas Compact Heater
Burner on new Whirlpool gass water heater will not stay lit
One of the proper ways to light a gas water heater, is to turn the black knob to Pilot, put a match to the end of the pilot light, while holding the match there, push the red reset button down and hold the match & the reset button down for one full minute. Then, release the reset button and turn the black knob to On. This should keep the pilot light on.
Jan 21, 2009 | Water Heaters
The pilot light for the oven went out.
Relighting Your Furnace's Pilot Light
furnace1.jpg - Turn off the gas at the main valve at your utility box - Wait five to ten minutes for gas fumes to waft away - Get a long match—yes, a fireplace match, not a standard match - Set the gas valve on your furnace to "pilot" - Press the red button as you hold the match to the pilot valve - Keep pressing the red button for 30-60 seconds so the pilot can heat the thermocouple. Release the button and see if the pilot remains lit - If pilot goes out, wait five to ten minutes and repeat the process - Once the pilot stays lit, turn the main gas valve back on - If the pilot light continues to go out, call a technician, who may need to adjust or replace your thermocouple or adjust your pilot
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
Williams 2509612 Ceramic Mid-Size Heater Logo
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
