Question about Fellowes PS80C-2 Shredder
Random Running I've had this PS80c@ for about 6 months and have used it very litte, about two binfuls worth. About two weeks ago, it started running all by itself with no paper in the feedslot nor help from me. I cleaned the sensor and the paper caught in the shred heads. I turned it on, put it in stand-by and, in the middle of the night, was awakened by the shredder running. This is scary and dangerous. The next day,I oiled the shredder blades and cleaned the sensor again and turned it back on and shredded a few pieces of junk mail and left it in stand-by and started watching TV. About an hour later I heard the thing running as if a ghost started the thing up. Well, this was the last straw and I umplugged it for good and sent an email to Fellows website describing what had happened. I haven't heard from them yet but it's been only a day since I sent it. Has anyone had any trouble close to this? What did Fellows have to say about it? For me, what I spent on this product is quite alot but I need a product that is safe and can take care of all this confounded junk mail. It is truly amazing how the junk mail people ratchet up the thickness of their mail pieces knowing that people like me shred their junk and they mail thicker and thicker mailings. It's kinda like spy vs spy and where it will stop, I do not know. Maybe an acid bath for all that crap is what I will need. Help!
  • Dave Cooper May 23, 2007
    I assumed the sensor was/is the culprit. My problem is what Fellows is willing to do about it.
Sounds like a malfunctioning input sensor
Posted on May 22, 2007
Geforce 8600 GTS recent drivers cause random freezes using vista
Are you sure that it's the driver that's causing it?
I suggest that you run an anti-virus scan. It might have been caused by a virus infection in your computer.
You can also try using RadarSync to scan your computer for driver problems (outdated drivers), then you can google the drivers and install. RadarSync will give recommendations. If you want RadarSync to do all the things for you, then you can buy the license.
I hope this helps!
David
Jan 21, 2013 | Computers & Internet
Engine "ticks" and misses when cold then clears up when hot, runs fine
Lifters are getting week. When tthe oil gets hot the oil get's thinner makeing it run more freely through lifters.Might try a bottle of sea foam . usually works well .
Good luck with it.
Dec 04, 2011 | 2004 Jeep Grand Cherokee
My 2000 Chrysler Sebring stops running. After a few minutes it will start again and run fine. This situation just started happenning a few months ago and is increasing in frequency
is the check engine light on??
i've done a few that had no light/codes.the most common problems are crank or cam sensor failures. really need to check when car stalls.
replacing crank sensor 6 mths ago & car has'nt had a problem. if you search these sensor on the sebring you'll find alot of info.
Jul 12, 2011 | 2000 Chrysler Sebring
I have a 1998 silverado with a 5.7l engine.Truck all of the sudden started running rough. Use code reader and came up with 3 codes. P0300- random misfire P0440- evaporative emission system P1345- cam to...
hi my is jose, a few months ago i had a toyota with the po300 random misfire. The problem was the spark plugs, thats is easy way to eliminated the codes. try this steps first.
Dec 16, 2010 | 1998 Chevrolet K1500
Fridge running continuously
Another defective thermostat.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2010 | Refrigerators
I bought HP Pavilion dv5 6 months ago and fan not working
Your cooling fan sounds to have went out,causing it to overheat and shut down.It also could be something in the fan stopping it from turning.Try cleaning it or blowing it out with it off.But it mostly sounds to have went out.
Aug 05, 2009 | Computers & Internet
Hi I have a 2001 Xterra, Manual, 213,000, runs rough at random
If your mechanic changed the spark plugs. Make sure he did a few things.
First make sure he used NGK plugs. I have seen other make plugs cause running conditions.
The other thing is make sure plug number 6 was changed. I can not tell you how many times I have seen shops leave that one cause it's to hard. That also can give you the ruff condition.
Last but not least, if the distributor cap and rotor and wires were not replaced, it may be possible that you could have a spark issue being loss. If you notice it more when conditions are wet, then it has to be related to those items.
Thanks Jay!
Jul 20, 2009 | 2001 Nissan Xterra
Food and water freezes but ice cream is soft
Check the door gasket seal.
Open the door for a few seconds and then close.
Immediately open the door again, and, if sealing properly, it should take more pulling force to open the door.
Mar 30, 2009 | Refrigerators
E-Machine T6216 PSU fan runs, computer will not boot
Giving the fact that your fan is constantly running and you had an electrical spike you should take it in to be looked at. If it overheats then the motherboard will go and it will cost more to fix it than to buy a new one.
Don't forget to rate this solution before you log off.
Jan 26, 2009 | Computers & Internet
Fellowes PS80C-2 Shredder Logo
166 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
midnightmove
Level 1 Expert
quennie732
Ed
Ed
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
