Question about Sanyo Split System Air Conditioner
I am using a sanyo split AC ,the error code F2 came as an indication what do i do.
The model is SAP-K12AG
3 Suggested Answers
  • 88 Answers
SOURCE: I has a split AC there is problem of electrical
hi,there is a problem commucating...possible one of the wires has gone bad....you will need to to turn off all power to both units at the breaker at the panel or disconnect...you will need to go to walmart purchase a electronic test meter..they have one for 20.00 ..i bought one yesterday...yiu will need to remove one wire at a time from the indoor unit...get a piece of paper befor removing any wires...mARK NUMBERS....
Posted on Mar 27, 2010
  • 13 Answers
SOURCE: ERROR CODE BLINKING,THE AIR CONDITIONER DOESNT WORK
it is happening due to blower motor not giving the signal to pcb pls check their is a return signal wire in blower motor is broken or motor is defective.
Posted on Jul 20, 2010
My printer is intermec PF8T i have i SAP program to print patient information but it cannot print the error is orange ligths was the error.
There are a few things to figure out here from a SAP basis administrator perspective these steps are common. Also I am just trying to help and with SAP there could be multiple solutions. Good luck.
Check SAP MarketPlace for SAP note: 1557674
Here are the steps taken from the SAP Community Network which might help. I would suggest reading the entire link as its informative. http://scn.sap.com/thread/1975158
Step:
run SPAD
to create an output device, choose Output Devices on the Devices/Server Tab
click on Display now you will be in Spool Administration window
click on Change button then Create tab will be appear, now you have to put the following information.
Under DeviceAttributees
put the Output Device name with shortname
Device Type: SAPWIN
Device class: Standards printer
you can put Model/Location/Message as per concern.
Under Access Method
Access Method: G
Host Printer: __default
save
for more information about
Device Type
http://help.sap.com/saphelp_nwmobile711/helpdata/en/d9/4a910f51ea11d189570000e829fbbd/content.htm
Access Method
http://help.sap.com/saphelp_nw70/helpdata/en/4f/9c033cff903105e10000000a114084/content.htm
(1) Choose "S: Print Using SAP Protocol" if a print server with SAPlpd or SAPsprint is used to print barcodes.
(2) Choose "F: Printing on Frontend Computer" if SAPlpd and SAP GUI are used together to print barcodes, SAP GUI sends print job to SAPlpd, SAPlpd is started automatically and forwards the print data stream to the Windows print manager.
(3) Choose "G: Frontend Printing with Control Tech", only SAP GUI is involved in printing barcodes, SAPlpd is not used.
Here are the Intermec drivers:
http://www.intermec.com/support/downloads/index.aspx
Understanding the LED Indicators
LED Meaning
Green (blinking) Auto-Sensing mode
Green (blinking) Downloading font, form, or graphic
Green (solid) Dump mode
Green (solid) Ready mode
Green (solid) Print mode
Orange (solid) Boot mode
Red (blinking) Media jam, overheated print head or stepper
motor
Red (blinking) Downloading firmware
Red (solid) Error mode
Good luck
Dec 27, 2013 | Intermec Office Equipment & Supplies
Error problem e9 in onida 5star split ac
what means of e9 error code in onida split ac ?
Mar 13, 2013 | Heating & Cooling
Whirlpool matermind window AC shows error code F2 when power on and won't cool. Sometimes it starts up perfectly fine.
F2 ---for me its a sensor problem had it done thanks katsaras
Unit -- Whirpool AC Model no. Wasr18k20 1.5 ton split AC
Jul 25, 2012 | Heating & Cooling
I think that my TV soney braiva xbr has an issue with SAP but some ch. are in spanish some do not have sound How do i reset this tv?
Press MTS/SAP on the remote (under the number buttons) to go between the 3 options of STEREO or MONO or AUTO SAP. Not all channels will have SAP (secondary audio program). Selecting stereo should eliminate any secondary audio.
Mar 24, 2011 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sanyo sap-71a will not start using remote the remote will start other air conditioners thanks
Simple, remove power and then unplug DC wire from indoor display for 2 minutes.Again plug it, power on. And also remove batteries and re insert in remote and then use. If still problem, your signal receiving sensor defective. You have to repair/replace indoor PCB.
Feb 05, 2011 | Sanyo 12KHS71 Split System Air Conditioner
Hello, I have a split system air conditioner (one of SAP-K181AA or SAP-K241AA or SAP-K251AA) and it is dripping cold water inside onto the floor. Can you help.
try to unclog drain line of your ac.or check the elevation of you indoor may be the drain water cannot flow smothly.
Jan 30, 2011 | Sanyo Heating & Cooling
SAP possibly enabled and need it off on channel 10 San Diego, CA Mintek TV model where do we find SAP on the remote control or TV settings?
A lot of times the remote will have it marked as MTS, this will enable or disable Mono, Stereo, and SAP.
Oct 05, 2010 | Televison & Video
Sanyo  Split System Air Conditioner Logo
393 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
