Mitsubishi WS-73713 73" Rear Projection Television Logo
duc huu ho Posted on Nov 06, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The power on no piture
Turn on tv no piture
Anonymous
Level 3:
Top Expert:
  • Mitsubishi Master 14,553 Answers
  • Posted on Nov 06, 2012
Anonymous
Mitsubishi Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715202
Points
48227
If the power light comes on (green) for a few seconds and goes off:
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
2answers
No piture or sound
replace your power board,.they are on e-bay for around 150.00
Menu pops on and off for about a minute when i first turn the tv on
the self diadnostic program in the tv is going bad.. may be time to replace the tv or dont shut it off completely
L G LCD RZ-27LZ55 TV NO PITURE
If you are sure that the backlight board is good and that correct power is reaching your board then you might have a problem with the bulbs themselves. Also make sure that the board is grounded.
www.interliquidparts.com
Our philips lcd tv picture turns off but sound stays on and then the piture won't come back on for longer while.
Suddenly, the sound for LCD 42PFL3605/12 dissapeared. Resetted to factory settings, upgraded firmware, but no result. The TV ran just 24 hours. Please, help!
Low light
GET INTO THE MENU SCROLL OVER TO TV SETTINGS THEN SCROLL DOWN TO TV PITURE AND RESET THE LIGHT POWER TO HIGH
4helpful
2answers
Tv comes on as always with piture then the piture goes out in 2 seconds
HELLO it sounds like a couple of things could be wrong. you could have what they call a dry socket or a bad, cold solder joint. what it means is that on the power supply section of the chassis the tv has gotten so hot that the solder has melted away frrom its connection and it is not making true contact on the chassis. if you know how to solder you can fix this yourself.. you will need some 60/40 rosin core solder and a soldering gun that is not over 40 watts. you will need to go over the connections on the chassis in the power supply section. hope this helps you just remember you must unplug your set before working on it. GOOD LUCK
TV will not turn on model aquos LC-46X20 Went away for a long weekend, did not turn power off left TV on stand by. Came back and power LED on front of TV is flashing and will not show any form of piture...
hello. here is something you can try , unplug the set and let it set. for about 10 mins. then plug it back and try tpo turn it on. hope this help's you. let me know "GOOD LUCK"
2answers
Problem
Hi three months ago my kp-61hs30 tv looks like 3d picture and technician man replaced the two convergence Ic's but last night my tv looks like 3d picture and it look like is the picture goes down
i don't know why happened again
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
