Spring not hooked on to fram
Spint cycle rocks loudly found sprig hanging lose from the shell of the machine wher do I hook it up to the shell of the machine model is WHIRLPOOL "LXR9245EQ1 thank you hank
  • 115 Answers
Is this the spring in the back if so look in the very back center bottom and you will see where the hole use to be but it probably rusted out just take like 1/4" drill bit and make another hole Please rate my solution
Posted on Jan 05, 2009
BLADES WILL NOT TURN OFF, FOUND A LARGE SPRING ON DECK. IT SAID TO HOOK IT TO THE IDLER PULLEY AND THEN TO THE TAB ON THE FRONT OF THE DECK. THERE IS NO TAB ON FRONT OF DECK. WHERE DOES IT HOOK TO?
The tab they are directing you to may have broken off - hence the spring hanging and no place to connect the other end. You might need to have this service professionally..
Oct 19, 2015 | Bolens 13.5 HP Manual 38-in Riding Lawn...
My machine won't pick up the thread at the thread take-up? What should I do? It is also making a loud sound.
The loud sound suggests that the moving needle and the moving parts of the bobbin system are no longer timed properly>
If this is the case you cannot fix it yourself and I can"t tell you how to do it
A qualified technician can do it>
Sorry I cannot be more help but my layman knowledge does not cover that!!!!!!
Apr 22, 2015 | Singer 7258 Sewing Machine
Bobbin case moves
it would be a good idea to have the sewing machine checked
to see if the bobbin case needs to be replaced or see if something
is wrong with the hook & hook race.
Oct 09, 2012 | Elna Sewing Machines
Washing machine will spin but not drain the water out
either an obstruction in your drain line or a bad pump
Jul 30, 2012 | Whirlpool Washing Machines
When the washer runs on final spin cycle I hear a banging sound within the unit. As the spinning increases in speed, the banging is extremely loud and unbearable. What would be the problem?
1 or more springs are broken or fell off.
If it is by chance a 2000 or 2001 Sears front load washer (Electrolux), the outer shell likely failed where the springs attach to keep the outer shell and inner wash tub suspended.
If you remove the lower panel, and look underneath and see one or more springs laying down on the bottom of the cabinet, look around to see if you can spot the end of the spring. Sometimes the ear that breaks off these will still be attached to the spring. The ear cannot be glued. The outer shell "could" be replaced, but the time investment makes complete replacement of washer the only cost effective solution in that situation.
If by chance the springs simply popped out, they can be re-hooked to the ear they came out of with some effort and careful pushing of the outer shell.
Dec 20, 2011 | Washing Machines
Loud knocking during finial spin cycle
replace the balance springs from the bottom of the tub to the frame there weak and letting the tub rock
Jan 18, 2010 | Washing Machines
Baumatic washer draining but not spinning
I had this problem, may be an easy fix if similar issue: Remove back cover. Take a look at the underneath the drum towards the right hand side. There may be a hook on a wire hanging there. If it is just hanging, there, it should be hooked onto a grey coloured lever, which has a hole on the edge of it. This is the drum brake which during the spin cycle releases the brake allowing the washer to spin. Hook the hook onto this grey lever through the hole. Replace the back cover. Test the machine with a towel or something, allow it to fill a little, then jump to the spin setting and see if it spins. Worth a shot, these are great machines.
Sep 05, 2009 | Baumatic MEGAWDSS Front Load Washer /...
Long drive belt cant remember how to put spring back on
The 'j' hook hooks over the transaxle and just hangs there. The spring attaches to the stabilizer rod (reference # 43) and the other end attaches to the "j' hook hanging on the left axle.
Jun 20, 2009 | Mtd Garden
At the end of each spin cycle it knocks loudly
A Clothes Washer with the complaint of "excessive noise & sssshaking" can typically be a couple of things;
Un-level Washer (Very Likely) - I would level and adjust your legs on your washer appropriately. Make sure when your slighly "push test" your washer, you have no machine movement, rocking or tilting. When the machine is going into the final rinse/spin cycle, the tub can rotate fast and if the washer legs or even the floor is slightly un-level, this can result in your washer to become noisey, shake, etc and can further cause the unit to break-down and no longer spin.
Un-balanced Load (Likely) - Ensure you are loading the washer and distributing the clothes (weight) evenly as this may cause the tub to spin improperly at final spin cycle.
Broken Drum Support/Springs (Likely) - Can be 5" black supports located at inside - top of tub area. Also, springs can also be located at inside bottom rear of machine holding the tub to the rear panel.
-C
Fremont, CA
Jan 29, 2009 | Kenmore 24032\24036 Top Load Washer
Directions needed
go to retrevo they'll have instrucitons for ya
Aug 03, 2008 | Evenflo ExerSaucer SmartSteps ABC Stroller
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
