Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
My solo kicker isnt performing right
I hooked up another woofer to my punch 800a2 and was floored by how much it out performed my sub it is wired in series should i go parallel or what?
  • 46 Answers
Do both voicecoils work? try one at a time...then if they do....get a piece of speaker wire about a foot long...connect the positive to the positive and the negative to the negative...then hook the wire from the amp up to one voicecoil....
Posted on Jan 14, 2009
How to run the speaker wires to connect to the subwoofer? and does a sub woofer burn if you do not put the right ammount of watts to it for example having an kicker l7 connected to a three houndred watt...
i'm guessing you are having problems with the dual voice coil's so I will link you to the kicker wiring guide...
http://kicker.com/sites/default/files/SoloBaricL72006.pdf that has the wiring options, you will need a pdf reader **** as adobe or foxit..
Under powering your subs won't hurt them but running a 15 inch l7 at 300 watts is not going to let the sub perform at peak, I would go with a 800 to 1000 watt amp.
15 inch l7 watt's are as follow
rms = 1000
peak = 2000
Mar 16, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker subs hook up problems
Connect one to each channel, for the best sound.
Jan 05, 2010 | Kicker Solo-Baric L5 Car Subwoofer
My friend jus bought 2 10 inch kicker l5s and when we hooked them up to his boss 1100 wat amp and hooked everything up they are moving but are not producing any sound. boss amp i do not know any thinbg...
it must be reversed polarity in coil voices of speakers check + - wires from amplifiers fit on coil voices of speakers try to get each speaker to 8 ohms wiring in serial the two coil voices n'd put in paralel both speakers in bridge mode output from amplifier to get most stable power ,
Nov 04, 2009 | Kicker Solo-Baric L5 Car Subwoofer
Amp 4 a Kicker S17L7
just make sure your kenwood amp can at least handle a 2ohm stereo load.Most amps now are able to .Your amps manual should list this or go online and check for that model .You basically have 2 subs in one allowing you to use one sub box in stereo mode.And just hook it up like two speakers left and right ..make sure amp has a crossover so that you only get bass at your woofer
Jul 30, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Wire my kicker
This will help you :)
Below is a link to the subwoofers manual where is clearly states how to wire it all up, it includes both the 2ohm DVC and 4 ohm DVC models.
Click Here for the L7 Solo Baric Manual
Jan 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker L712 and rockford fosgate800a2 amp.weak prfmce
Is the box sealed air tight, leaking around speaker? plumbers putty works great. Amp may be good enough for the mtx but underpowered for the kicker. When kicker says 1000 watts that what it is (at a 14.4 volt input). Mtx is ok but may not tell the true watts. Check to see if the speakers are the same ohms also!
Jan 05, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker solobarrick...still not working...
kicker aint kickin? warranty,warranty,warranty!!!
Oct 16, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
Sep 26, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
75 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
