Question about Mitsubishi WD-62527 Compatible TV Lamp
My tv a mitsubishi d 62527 the green light kees blinking
Reseting does not work unpluging does not work
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Called the blinking green light of death---set should if power lost when put back blink for 70 seconds or so---digital unit booting up.
About the only simple cause is in the main power supply are four 1000 uf caps that puff up and fail--provide boot up voltage.
follower power cord to supply and look for bad caps (they will be easy to spot) and see attached photos of what to look for.
my tv a mitsubishi d 62527 the green light kees bl - 11_6_2012_6_53_33_pm.jpg11_6_2012_6_53_49_pm.jpg
Posted on Nov 06, 2012
designer7
SOURCE: Blinking Green Light
Hmm I tried unplugging it for a while but I will try this again tonight since it will be unplugged for about 24 hours.
Thank you McColp for the info..
I have a service guy coming tomorrow, maybe this will work before he comes! I appreciate your help!
take care
Maria
Posted on Nov 02, 2007
  • 1694 Answers
SOURCE: Mitsubishi WS65513 with blinking green light
Download Chris@ChrisAndNat.com .........T.
Posted on Nov 09, 2007
SOURCE: blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Posted on Sep 19, 2008
SOURCE: Mitsubishi TV WS 65869 blinking Green Light
I have the same problem with my projection screen TV.
Posted on Dec 08, 2008
SOURCE: mitsubishi WS-55859
Easy to fix this problem, I did 1 mounth ago. 30 min and $20 dollar
Posted on Dec 30, 2008
Steady blinking green light on Mitsubishi LCD model LT 55164
I also have a Mitsubishi LT 55164 with blinking green status light...does nothing else...reset does no good, also tried to reload software with no difference. Replaced power and inverter boards button stop the same. No obvious bad components on boards. Help! Anyone ever actually fix one of these?
Aug 29, 2015 | Mitsubishi LT55164 55 in LCD TV
Mitsubishi WD-73733 green blinking light will not turn on.
This is know as the blinkling light of death. You can get parts - just google TV Repair Kits
Mar 26, 2012 | Mitsubishi WD-73733 73" HDTV
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Flashing green light on Mitsubishi WD- 62527 TV
how time dose the light blinking was your pix
dark if so you need a lamp@powersupply for lamp. hope this help you out,
Aug 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi TV WD-62527 will not turn on
Hi there, this is most commonly known as power board failure in the industry. the capacitors are blown. if you are experienced in inspecting circuit boards this will be helpful. you will have to disassemble and pull the power board and preform a break point test. the bown capacitors are easily picked out. they will be swollen and discolored. If you are not comfortable with disassembling this set, i suggest a service call. just tell the tech you are experiencing a power board failure.
Mar 07, 2009 | Mitsubishi WD-62827 62" Television
Continuosly blinking green light and tv won't turn on.
Either bad capacitors -vented - on power supply board or bad E2P eprom board on DM board.Probably the capacitors-4-1000Ufd and 2-3300ufd.You should get expert help from reputable tv shop.Not really do it yourself fix either way.
Dec 15, 2008 | Sony KDS-60A2000 60" HDTV
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Blinking green light, will not power up
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WD-62527 Compatible TV Lamp Logo
143 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
