Question about Canon Sure Shot 105u 35mm Film Camera
H flashing on screen
If you take out the battery then put them back in you can take one picture maybe two at the maximun, then an H appears on the screen and you cannot turn the camera back on or take another picture.
  • kshell Nov 24, 2007
    Removed battery. Replaced film. Held down on/off button and menu button.
    Problem Solver:
  • 40 Answers
I'd suggest "googling" your error message as your best bet.
Posted on May 24, 2007
I tried to put my pictures onto my computer last night but the computer froze so I gave up but I took pictures this morning, and it was fine. Then the next picture I went to take nothing showed up on the...
Your coin battery that powers the memory system of your camera may be failing. This battery keeps your settings and powers your on board computer. Do not confuse this with your picture battery, as that only powers the lens and picture taking ability. The coin battery holds the program. See page 38 of your manual "Replacing the Date/Time battery."
Dec 20, 2010 | Canon EOS Rebel XS 35mm SLR Camera
1 vertical line across the screen maybe 1" tall. It appears to have the entire picture in that short little space.
tv turns its self off i unplug it plug it back in it will flash on not showing picture it u can her it flash on and right back of some times it will not flash in back of tv and i can hit power it will flash and go off every now and then it will come on show picture after being unplugged and plugged back but then shuts off
Jul 16, 2010 | Toshiba 36A50 36" TV
Where do i add steering fluid
Hi: Open Hood You Have a Plastic Resevoir with a Black Cap On The Cap It Should Say Power Steering Fluid. Get your Car Up To Normal Running Temperture 1st and tyrn your Wheels Back And Forth you'll want to Fill The Power Steering Resevoir to where its Written On The Side Of Your Resevoir MAXIMUN DON't Over Fill it.Get Back In Your Vehicle and Turn Wheels Left To Right All The Way To Get Any Air That Might Be in the Power Steering System.Then REcheck to Make Sure Your Level Is Still Fill To Maximun or Maybe a 1/4 Inch Below The Mark -Maximun. Let Me Know If This Has Helped You Out, By Voting on The Quality On My Solution.
From The WYOCWBOY
Jun 01, 2010 | 2003 Buick LeSabre
Can't get flash to work
• If you are taking pictures in low light (dim light) and the flash is required, the flash will operate
automatically. A lightning bolt appears on the LCD screen and blinks until the flash is ready.
• While holding the camera steady, press the shutter button to take a picture.
Hint: The flash works best when your picture subject is about 4 ft. - 7.5 ft. (1.22 m - 2.23 m)
from the camera.
• When the batteries are getting weak, the flash will not fully charge and the no flash lightning
bolt appears on the LCD screen. It's time for an adult to change the "AA" (LR6) batteries,
Hope this works!!!
Soyleonel
18
Nov 26, 2009 | Fisher Price J8209 Digital Camera
Mitsubishi ws 65857 no picture but screen pulsates. bulbs ok
code 12 indicates no fault. tv probably needs the high voltage board rebuilt, have a shop do it. Maybe you need to check all the connections.
Aug 30, 2009 | Televison & Video
Continuous flash charge
Try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
May 23, 2008 | HP Photosmart 735 Digital Camera
There is a pop up screen that says "OUT OF RANGE" and keeps moving from corner to corner around the screen. What do i need to do to fix this?
maybe your screen resolution doesn't match with the monitor resolution , so minimize you're screen resolution
maybe you can try with 800 * 600 and go up one by one and see which maximun it support
Apr 22, 2008 | Computers & Internet
Help with s630 Digital Camera
Rechargable batteries actually do not recharge the 100 times advertised. After maybe 10 times they are reduced in capacity noticably. For instance, new alkaline batteries will last me maybe 60 pictures, however the rechargables are only good for about 5. To test this try taking out the batteries, and put back in before you wish to try them, also turn off the flash if it is not needed.(flash uses a lot of power)
Apr 11, 2008 | Samsung Digimax S630 Digital Camera
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Jan 19, 2008 | Pentax Optio E10 Digital Camera
Canon Sure Shot 105u 35mm Film Camera Logo
47 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
