Question about Microsoft Zune JS8-00001 Digital Media Player
Totally dead Zune!
My Zune is totally dead! Initially I thought it was due to a low battery but it won't charge on the CPU (it doesn't even recognize that anything is connected) nor will it charge with the wall adapter, won't even light up to show that it is charging. I have tried all of the suggestions here, i.e. different combinations of buttons, and still nothing. What to do?
  • 2 more comments
  • Anonymous Jan 05, 2009
    zune died on new years, ran the battery out, and it reset ok, until last nite, Jan 3rd, same situation - unable to get it to work again.....
  • Utah_misery Jan 08, 2009
    I have the same problem with my 30gb, at first it would just show a screen but the battery wouldn't charge. It would eventually say low battery then it would just die. Now it won't even power up or do anything. I saw on a website where you can replace the internal parts fairly cheap it was but if I can get away from doing that I would welcome any advice. Please email me at
  • dmhomz Jan 13, 2009
    Thanks for the suggestion vibilo but plugging my Zune into either my cpu or wall charger does nothing, the Zune doesn't light up to indicate that it is indeed charging nor does my cpu acknowledge that new hardware has been connected.
    Perhaps my Zune has bigger issues than the simple "leap year bug" and as a result I am sending it back (as it is still under warranty) where hopefully the Microsoft gurus will be able to remedy the situation or simply replace it.
  • Anonymous May 16, 2009
    OMG i have the same exact problem
  • 502 Answers
If nothing seems to revive it, You most likely need a new logic board which can be replaced without problems. There are third party Zune repair services, that will fix it for cheap. Even better, I found an DYI Zune repair guide, soyoucan do it yourself too, not that difficult. Part is availableon Ebay. If you can't do it yourself, have a tech savy friend do itfor you.
Posted on Aug 24, 2010
  • 27 Answers
It sounds like you guys might be suffering from the Infamous zune new year bug. Let your Zune completely die (leave it for a few days if you have to). After doing this plug it into a computer or wall out let to charge. Leave it to charge for at least an hour. Come back and unpluge the zune and reconnect it to a different usb port if possible. Let it continue to charge.
Letting it die should fix the freeze and swapping ports during the charge will help the computer detect the zune as when their batteries are 100% dead they do not have enough power to say that they are there.
Hopefully this will help out one or two of you.
Posted on Jan 13, 2009
Charging battery on Tablet which is totally dead
Depends on how long it sat for with no charge. LION batteries dont recharge from totally being dead if they are left discharged for long periods of time.
Jul 29, 2013 | Polaroid 7-in. Internet Tablet - Other
How to restart nokia5310
Hi whats the problem ? you mean your phone could not start up,or it is totally dead ? For nokia 5310 sometimes this problem cause due to im-proper connection of its battery,the connector of the battery gets open frequently,so first check it out Or if the battery fully drains.Put another battery and try,even if there is no effect insert charger.And if the charging is indicated the fault is power key.When charging indicated and your phone doesn't switch on then you need to change the Strip (Pata).Neverthless,contact mobile repairing shop.Thanks for visiting fixya.Good luck
Jun 26, 2012 | Nokia 5310 Cellular Phone
My car battery is totally and completely dead on my G5 2008 Pontiac as the lights were left on overnight. There were zero indications or problems before. I tried to charge using cables and it was totally...
Have your battery tested / charged.
Totally dead battery may take some extra time to charge being hooked to cables.
When a battery is "hard discharged" as you described...sometimes they never recover and require replacement.
Jul 24, 2011 | 2008 Pontiac G5
My samsung gt 15500 won't charge up. It was working fine 2 days ago and yesterday i brought the usb lead to work with me to charge it with my computer. Nothing happened when i plugged it in so i...
If the phone was totally dead before it refused to charge initially, then the refusal to charge is due to the fact that there was no residual charge left to bring it to a charge, because the battery completely died.
To fix it, kick start the charging process.
Remove the battery, and using a universal charger (desktop charger) charge the battery for say 10 minutes, before re- inserting the battery to the phone and continuing with the normal charging process.
If this does not work out, then problem is with the charging port. It has to be replaced. This can be done by nearby local phone repairers.
Hope it helps?
May 12, 2011 | Cell Phones
Zune 80G Freeze
I returned it to Ebay after calling Zune Tech Support to find out it was a dead battery or a battery that was not holding a charge.
Thanks but no premium plan needed.
Feb 18, 2009 | Microsoft Zune JS8-00001 Digital Media...
Microsoft Zune JS8-00001 Digital Media Player Logo
855 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
