Question about Ovens
Westinghouse GOR474 fitting catalytic liner
Fitting catalytic liners purchased separately
2 Suggested Answers
  • 36 Answers
SOURCE: left a silicone liner in a self-cleaning oven when I cleaned it
JUST SCRAPE IT OFF IF YOU CAN. OTHERWISE RUN ANOTHER CYCLE AND BURN THE REST OUT OF THERE.
OR JUST USE IT AS LONG AS YOU DONT SMELL ANYTHING BAD.
Posted on Mar 05, 2008
Mistakenly placed foil on bottom of oven. Pulled out foil and noticed minor damage to lining. What is the impact of this and does it need to repaired or replaced
Other than the appearance of the bottom liner I don't think you did any other damage. You probably just melted some of the foil to the liner. Just keep and eye on it the next few times you bake something. If for some reason the liner coating starts to come off more every time you use the oven---then it probably will need fixed. This would require replacing the complete oven liner if the bottom is not removable as a single part.
Jun 14, 2015 | Frigidaire 30" Built-In Double Electric...
The racks all fall out if even the slightest weight is on them, very scary keep waiting to burn myself badly
Hello Kathy Manson - Unfortunately, based on the symptoms you are describing, the oven liner would need to be replaced. The oven liner cannot be adjusted or shimmed to resolve this issue. If I was in your position, I personally recommend consulting an experiencing service technician to assist with the repairs.
Mar 04, 2013 | Electrolux 30" Built-In Single Electric...
AEG D2100-4 , THE TOP GRILL HAS FALLEN DOWN AND THE RETAINING SCREWS WONTS GO BACK ANY IDEAS THANKS
Hi the spare part solution is to replace the oven liner. not economic and difficult to do. If engneering minded you can make a long slide clip i have made some out of an old oven shelf grid.forming a shape similar to a tent peg in shape and size and sliding it horizontally through the grill retainining bracket and hole in the oven liner. not easy to explain this but it works on aeg bosch and neff ovens with the same fault.
Nov 09, 2010 | AEG D2100-4 Electric Double Oven
How do I change a GE oven gasket for 60's era wall
The oven liner has to be pulled forward about 1/4" to do this remove the 2 screws at the center front top and bottom.
Mar 03, 2010 | Ovens
EW81 top oven/grill door. The glass front has separated at the bottom from the metal door (sticky pads don't stick anymore). Is there a solution or do I need the whole fitting ? If so, where can I get one,...
It is held on with a special heat resistant adhesive.
You can find it on the internet, look under adhesives, and you should find what you are looking for.
Dec 21, 2009 | Ovens
I have just opened up my chimney and took it back to the bare bricks and was giong to install a wood burner but decided to fit a gas stove instead. there was originally a gas fire installed so it has a...
You will need to install a flue liner ( i know its a nuisance) to allow the products of combustion to escape as quickly and as safely as possible.
If you installed a gas appliance without a liner, due to the temperature of the flue gases (lower than solid fuel) the emissions would struggle to exit via the flue terminal.
If you install the appliance following the manufacturers instructions, you cannot go wrong. The other recommendation is get a 'Gas Safe' engineer to carry out the commssioning/testing.(house insurance void if not certified)
I hope this helps.
Jul 07, 2009 | Ovens
Oven door does not close fully
You need to replace the oven door hinges.
Please rate my solutrion.
Thanks.
May 15, 2009 | Neff B1421 Electric Single Oven
GE PGB975SEMSS Broiler and Oven flames too large and yellow
It sounds like your not getting enough air mixed in with the gas.if you can't adjust for more air make sure you were not supposed to change the spuds that feed the gas on the lower units.
Mar 16, 2009 | Ovens
Ovens Logo
26 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
