Burner propblem I have a riello burner (Press GW )for my central heating system. in the morning, i turn the heating on the burner for a few swconds and then control box blind red-blue-red-blu.... I press reset button but the burner is not start. I have plenty of oil and tried to clean the fuel nozzle and electrodes as I thought it may be dirty.when degree is 70c, the burner is start. I still need to clean the inside of the boiler free of sut. Can you tell me if I need a new photocell, pump or something else
  • 700 Answers
Have you tried to wipe off the fire eye on the unit if it has one? If it's dirty too then it will not see the flame and not let the unit come on correctly. Good Luck and have a Happy New Year.
Posted on Jan 05, 2009
Fitted new oil burner riello 40 model g3b to a heatmaster 70/90 boiler. fitting the thermostat wires to the control box live and neutral keeps triping out the fuse box. any ideas;
If the pump has seized, this can cause an overload and blow the trip. Hopefully, that hasn't happened.
You can check by doing the following.
The pump and valve are normally located close to each other and may well be in your loft.
This webpage gives a few examples of what it may look like. motorised+valve&gbv=2
They are often in two parts, the mechanical valve and the electrical actuator and the two parts can sometimes be pulled apart.
If you can do this (don't try it if you are not confident with what you are doing), you will be able to determine whether it is an electrical problem with the actuator of if the mechanical part of the valve is jammed in one position.
Simply take the electrical actuator off the valve assy and switch the heating on again.
If the boiler starts up and the fuse doesn't blow then it will be the mechanical part of the valve jammed and this will need to be replaced.
If the fuse blows then it will be the electrical actuator or the wiring between it and the central heating controller.
One other possibility is the thermostat or the wiring to it.
Jun 03, 2017 | Heating & Cooling
Riello f5 oil motor will not start
Is your electric air shutter opening? That causes power to come on. Here's a link. don-ohio (:^)
Jan 19, 2017 | Heating & Cooling
Centeral heating system not heating house
To receive any assistance your question needs to be more specific regarding the type of system you have and any and all symptoms.
Feb 15, 2016 | Biasi B-6 Oil Boiler w/ Riello Burner -...
Pilot light out....buderus furnace but a red riello ingniter on the front....I've watched my fuel guy flash a light into it this baby when out before but need to do it myself now.....could you walk me thru...
This is due to a "Lock-Out" Check your flame sensor for carbon build up. Possible heat exchanger blockage.
The reason he used a flashlight was to trick the burner into seeing a flame, not a good idea for a novice.
Mar 16, 2011 | Heating & Cooling
Riello oil burner RDB Hi everybody i have a Riello oil burner RDB . I am wondering is there a way to make it more oil efficient?
does it have the air damper installed? You can add a magic heater to the flue and dump heat into your basement.. thats maybe 5 to 10 percent more efficient
Sep 25, 2010 | Heating & Cooling
I find the riello burner 721T manual. Thanks,
Unfortunately, Riello does not release manuals other than to heating professionals.
Good Luck!
Dec 11, 2009 | Home
I have a riello oil burner, starts to fire up for a few seconds and fails , fuel is ok any ideas please
i have a riello oil burner 40 F5, starts to fire up for a few seconds and fails , but then it will start for a few minutes...then shuts off... house is not being heated sufficient. There's hot water but after one shower the water starts getting cold....fuel is ok any ideas please
Nov 28, 2009 | SySTOR Systems (400S52) Burner
Oil went too low, now don't start
There is a bleed screw on the pump, turn a 1/4 turn to the left, and bleed until oil is free of oil. On older pumps, instead or a bleeder valve it is just a plug, you will have to remove the plug, bleed, then replace the plug
Apr 06, 2009 | SySTOR Systems (400S52) Burner
I have a riello burner for my central heating system. When i turn the heating on the burner ignites for a few swconds and then goes out.... the burner tries to re-ignite and the same happens. I have...
Replace the nozzle, don't try and clean it. After the burner runs a few seconds, do you have to reset the control (red button) before it will start again? Does it sound like there is a pulsation in the flame when it starts or it is running out of oil? You may have a bad ignition control. Start with the small stuff, nozzle, strainer filter, oil tank filter and then work to the more complicated.
Aug 01, 2008 | Heating & Cooling
Heating & Cooling Logo
228 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
