Question about Yamaha RX-V992
Yamaha RX-V992 won't stay on. Starts for a second then shuts off.
I had my receiver boxed for a couple of years, while I was living in a different location. It was stored in the original box and kept at room temperature (no extremes).
I recently unboxed it and set it up. It looked perfectly normal. I plugged it in, turned on the power, and then it shuts off within a second. It acts like there is some kind of internal auto-protection kicking in. But I'm perplexed... the unit was perfectly fine when I boxed it. I can't understand how storage could cause any kind of degradation. Is this a power supply issue?
During the brief second when it is on, I can change some settings (such as input source, speaker set) just before it shuts off. When I try starting it again, the new settings show for that brief second. But it doesn't matter how many times I try--it just won't stay on.
Any ideas or troubleshooting suggestions? Thanks.
  • 1 more comment
  • Gary
    Gary Jan 05, 2009
    I thought it might be a speaker or component wiring issue as well, so I unplugged everything, unplugged the receiver for a few minutes, then plugged it back in (alone, nothing else attached). It still won't stay on more than a half-second.
    The thing that confuses me is that the unit was sitting in storage for two years, not used at all. And it was working just before I packed it up. Can components degrade without even being used, even when "mothballed" in a protected environment? No moisture or intense heat exposure involved at all.
    Thanks for helping.
  • Gary
    Gary Jan 07, 2009
    I took off the cover of the unit and performed an inspection... looking for anything "unusual" or unexpected. I could find nothing. Clean as a whistle. No sign of damage or a blown component. There is one fuse, but it is coated in some thick white material--I can't see its state. But I have to expect if it wasn't functional, there would be no power whatsoever.
    Anyway, I'm baffled and bummed. And certainly bringing it in for repairs is a waste of time (these amps can be had for around $100 used, so...). I guess the next thing is to pawn it off on CL or EB.
  • jeffry rodriguez
    jeffry rodriguez Jan 12, 2009
    i have the same problem, the unit powers on then in half a second it goes off. i opened the unit to see if anything was blowed or un-pluged. but found nothing. when i power it on the blue supply on the power board makes a sound then another, which could be the power supply. it had white mold inside. i should a air pressure machine to clean inside but still nothing. ima send the unit to a electronic repair store. and what ever he tells me the problem is...ill post it up here.
  • 73 Answers
Sounds like one of a few things. There is an auto protect feature in most amps and they kick on when one of the following happens. This is assuming that the speakers are plugged in when the problem happens. If not, the power supply is shot or some other non user serviceable problem is happening with the amp.
A. Speakers are out of phase B.The Speakers are way to large for the system C.There is a short in one of the speaker lines. D.The speakers are blown or shorted. E. Last but not least, the power supply for the amp is going, going gone. It could also have gotten some moisture.
Not to be redundant but try some of this. Take a new speaker wire, not the old.
1.Check the phase. For all speakers. Make it the same all the way around,
+red or white stripe, to the red terminal and -black or non striped to the black or negative at the amp and speakers.
2. Start with all speakers unplugged and plug just the right front in. Test it.
If it works ok, then plug in the second speaker, again by itself. Test it.
on and on. By process of elimination, you should be able to isolate the problem. That is of course, if it has anything to do with the speakers.
Posted on Jan 05, 2009
  • charles durando Jan 05, 2009
    Sorry I couldnt be more help.
    Usually components wont degrade in a controlled environment, but It can happen. oxidation happens sometimes even under ideal situations. You could try looking under the hood to see if there are any fuses that are blown if you can find any. Best regards.
Maybe the problem is with your speakers. Shorted speakers or speakers that are being over-driven can cause the receiver to shut down and possibly be damaged.
May 21, 2013 | Yamaha Rx-v465/rxv465 Home Theater...
Yamaha RX V992, HDMI 2 mode
tell toshiba dvd 720 p only and use bitstream outsetting in audio of dvd player ok if that dont do it run dvd directto tv then digita opti cable from tv back to sterio ok
Jan 21, 2008 | Yamaha RX-V992
Receiver shutdown
change your power regulator it is leaky and there are some diodes around the regulator change them also check the caps and some of the resistors some also can be faulty.good luck.
Jun 07, 2007 | Yamaha RX-V1500 Receiver
I have a Yamaha RX-V992 receiver and I would like to install a Bose 901 active equalizer Where will I connect this to my receiver? Thanks Mark
Basically here are the connections you have to do:
In case you don't have tape recorder forget the "box" named tape recorder. Your RX-V992 is the box named receiver or preamplifier. You have to connect with RCA - RCA cables the tape out from the RV-X992 to Bose input, and the Bose output to tape in at RV-X992. With the setup connected like this whenever you choose from the RV-X "tape monitor" you will hear the sound equalized from Bose; if you disable the "tape monitor" switch you will hear without any equalization.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
direct FixYa link:
May 09, 2010 | Audio Players & Recorders
Can you fix the volume button on the remote on the rx-v992?
No, it's a rubber membrane under the button and rubber "bubble pad" check ebay for replacement, not too expensive. If you need a "system control" remote, look at the Harmony Logitech series. The 620 is around 100 and the 610 is around 70. Great remotes and "Easy" to program. Hope this helps
Feb 26, 2010 | Yamaha RX-V992
Yamaha RX-V992 AM/FM stopped working & Right Speakers
Go to then support then authorized serice centers. Hope this helps
Jul 06, 2009 | Yamaha RX-V992
The receiver sound shuts off
There is a problem with the receiver that is allowing DC voltage to get to the output amp section. This is detected and the protection circuit shuts down the receiver. Yamaha uses coupling capacitors between sections to prevent this. If one of these is defective, it would explain your symptom. This should be a relatively simple repair for a repair shop. Expect $10-$25 for parts plus the local labor rate.
Mar 18, 2008 | Yamaha RX-V992
Receiver shuts off at times
There is some leakage of DC voltage getting to the output section. DC voltage will cause the protection circuit to kick in and shut down the amp. This should be a relatively simple repair and cost about $15-$30 in parts plus the local labor rate.
Dec 14, 2007 | Yamaha RX-V992
Volume not playing
I would guess that the blinking vol lite is indicating "protect" mode. This is a case where the amp section is shutdown to prevent further damage as a problem has been found. This is usually because the amp transistors have failed. Expect $25-$35 in parts plus the local labor rate.
Jul 30, 2007 | Yamaha RX-V992
Yamaha RX-V992 Logo
368 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
