Question about Black & Decker 18V Cordless Drill/Driver
Black and decker sps 18v how to open chuck - Black & Decker 18V Cordless Drill/Driver
woobie dog
  • 1273 Answers
SOURCE: Black and Decker Cordless Drill Chuck stuck in full open position
I'd put penetrating oil in it and tap the chuck with a plastic hammer. That should free it up.
Best rgrds, W/D
Posted on Aug 18, 2009
rowdy45176
  • 2176 Answers
SOURCE: lost 18V AC adaptor- can I use one made for laptop with 18V output?
I don't know if I would try this or not. there could be a difference in the amps and usually a charger is designed to shut off or go to trickle when the battery is fully charged.
Posted on May 25, 2009
rowdy45176
  • 2176 Answers
SOURCE: replacing the chuck on black & decker drill
remove the chuck retaining screw LH thread, and then find a bent handle allen wrench about the chuck capacity and insert the shorter piece in the jaws and tighten, Shift the tool to the low position (if it has one) and the selector to drill only (if it has one) position the chuck on a block of wood at about a 30 degree angle so you can strike it counter clockwise and hit it with a hammer, it might take a couple times but it will come off. Reinstall in reverse order,
Posted on Oct 10, 2009
  • 10 Answers
SOURCE: How do replace a chuck on a black-decker cordless
you must open the chuck all the way and the screw is in the back inside the chuck this is a left screw which means its righty loosey and lefty tighty; unlike normal righty tighty and lefty loosey.
Posted on Mar 29, 2010
wireguy212
  • 1627 Answers
SOURCE: I have a Black & Decker 18V cordless drill
Look at the three jaws in the chuck,if on is further out than the others the you need to tap ti back into place with a small punch and a hammer.If this does not work then you need to replace the chuck,remove the screw at the bottom of the chuck[where you put the bit],then you will need to to clamp vise grip on the chuck and with it pointed away from you hit the vise grips with a hammer with a sharp blow downward and it should come off.Hope this helps.
Posted on Jun 12, 2010
Keyless chuck overtightened
two strap wrenches work well becasue they will not crush or scratch the chuck like channel locks or any plier.
Apr 04, 2014 | Black & Decker Black and Decker FIRESTORM...
12 volt black and decker keyless chuck will not close. Model CD120G
Try giving the inside a spray with WD40 then try closing the chuck. Check that there is not a left handed screw in the center of the chuck that has become partialy unscrewed. The chuck can jam open and just need a strong gril to release it. If the outer sleve of the chuck is turning but nothiing happens then you will need to get the chuck replaced.
Jun 10, 2012 | Black & Decker 18V Cordless Drill/Driver
Chuck wont open or close to replace drills
There are threads inside, may be a little oil might help
Jan 20, 2011 | Black & Decker 18V Cordless Drill/Driver
Choke will not open or close
Do you mean the chuck to get the drill bit in or the button to change direction? I used to build these so please give me more details and I may be able to help
Jan 06, 2011 | Black & Decker 18V Cordless Drill/Driver
I have a Black and Decker 18 V drill .I opened the bit up to its largest opening and now cannot get it to budge. It is a keyless chuck. thanks, RW The model# iis CD180GS
I have had that same issue -- I just get a pair of channel locks and clamp onto the chuck ( not hard ) and run the drill forward -- this should close the teeth.
c...
Dec 31, 2010 | Black & Decker 18V Cordless Drill/Driver
I have a Black & Decker 18V cordless drill with keyless chuck. The spot where the drill bit fits is in the open position stuck and won't turn in either position. What am I missing how to unlock it?
Jun 12, 2010 | Black & Decker CD9602SB 9.6 Volt Cordless...
How do I remove a stuck bit from the chuck?
put the drill in a vice. then use the chuck key  and a hammer to release the bit.
 if necessary use wd40 spray to free up chuck.
Jan 24, 2010 | Black & Decker 18V Cordless Drill/Driver
Black decker drill keyless chuck won.t open !
hold the back of the chuck with channel locks or a vice and use the same channel locks on the front and open the chuck manually it should work and you can get to the screw to replace it or the hand chuck. this can be a little frustrating but hang in there and you'll be a pro shortly.
Sep 02, 2009 | Makita Usa Inc No.8390DWPE 18V Crdls...
Best rgrds, W/D
Aug 18, 2009 | Black & Decker Drills
Black & Decker Impact Drill. Mod. 7277 type 3
If you say that the chuck can not be tighten only, then I would say that the left thread screw that keeps the chuck to the tool have become unloosen and can not allow the chuck to be tighten. The remedy for that is to unloosen the chuck as much as you can, then tight the left thread screw but rotating it left till the bottom and then the chuck will work. All the above if the chuck can not be tighten...
Mar 23, 2009 | Black & Decker 18V Drill / Impact Combo
Black & Decker 18V Cordless Drill/Driver Logo
67 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
