Question about Honeywell Programmable Thermostat Heater
Honeywell t8400c 1008(2) led light not working when set on heat
3 Suggested Answers
  • 1015 Answers
SOURCE: want to replace analog Honeywell thermostat with digital
Your system uses 24 volts and that thermostat should work. You should only have a two wire system and that should work using the RH and W connection on the thermostat. My personal opinion about that thermostat...I don't like it. It will timeout for 15 minutes after furnace does not fire up. I deal with this thermostat all the time because that is what they install in the new homes. I always have to pull it off the wall, remove the batteries and wait for it to completely drain power becuase it does not have a reset switch. Very irritating...Might be too complicated for your application.
Posted on Oct 17, 2009
pendletonhea
  • 144 Answers
SOURCE: My honeywell t8400c also went blank. I can not
it should take a battery and it has wires coming from the unit for power as well the stat splits open from the wall leaving some of it mounted on the wall the batteries are in the part that pulls off the wall and the wires are on the part that stays on the wall the power wire is red on r terminal
Posted on Sep 23, 2010
The display on my thermostat T8400C 1024 isn't working. Everything else works but the heat and the flame is not igniting either. Please help.
Sounds like a manual limit needs to be reset (thermal disc). Generally the manual limits are around the exhaust - backdraft, or burner assembly - flame rollout.
Feb 15, 2014 | Honeywell Heating & Cooling
Changed honeywell T8400C 1024 to Hunter 44760, I have five wires white, red, yelliow, green, blue. Hunter Thermostat reads "NO A/C Power.
On the t-stat and the furnace make sure the wires are hooked like this...
Red to R
White to W
Green to G
Yellow to Y
Blue to C
then it should work..
Thermostat Wiring and Terminal Designations
heatman101
Jun 12, 2011 | Heating & Cooling
My honeywell t8400c also went blank. I can not find a battery anywhere and if plugs into the wall to get electricity. Everything works but the digital read out. Any suggestions
Sep 23, 2010 | Honeywell Electronic Programmable...
I have a Honeywell T8400C 1024 thermostat. the last two nights, our heat continues to run without shutting off at the pre-set temperature. We have woken up to 81 degrees in our house. What is the...
Hello
Try taking the batteries out for 5 min,or disconnect power for 5min.
To clear it out.
Then re input all your times days and temps,
Is t stat in a cold location near a door or window?this could also override your settings,most progrmamble stats will go into override at 58.f im guessing this is not your problem.
If it continues after you reset,i would consider a new thermostat.
Hope this helps.
Jan 28, 2010 | Heating & Cooling
Honeywell T8400c thermostat went blank. central heating is not working although warm water is alright. any idea?
I would check the batteries in the thermostat. If the batteries are okay then you might have a blown fuse in the furnace or the furnace lost power check the breaker.
Jan 21, 2010 | Heating & Cooling
Want to replace analog Honeywell thermostat with digital
Oct 17, 2009 | Honeywell Programmable Thermostat Heater
Honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Sep 28, 2009 | Honeywell Electronic Programmable...
Honeywell thermostat T8400c started flashing, heat/cool was off. Display flashes all icons (heat and cooling icons, temperatures, everything) and on the oppposite flash, the setpoint is displayed. The fan...
Based on the simplicity of this particular t-stat, I really think that it is bad and needs to be replaced. They do not make this particular model anymore. I have included a link to the operators manual for the stat. Good luck!
http://customer.honeywell.com/techlit/pdf/PackedLit/69-1491.pdf
Apr 05, 2009 | Heating & Cooling
Heating & Cooling Logo
145 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
