Question about Exercise & Fitness
Proform xp 110 elliptical squeak in the pedal disk
How can we get rid of the constant squeak in the pedal disk?
4 Suggested Answers
  • 103 Answers
SOURCE: Have proform 850 elliptical, unit jerks at bottom of travel
This is caused by a loose crank arm. The key assembly is loose. (#32 on your parts list) The covers will need to be removed to access this. Be sure the crank arms are realigned against the frame when completing the repair. Good luck, Tim
Posted on Nov 13, 2009
maxtreadmill
  • 832 Answers
SOURCE: After replacing batteries on Proform PF800 console stays lit
Pull the batteries out let it reset itself while its doing that check all cable to make the connection are seated firmly then reinstall the batteries, unless the function pad is sending a phantom signal engaging the display to be on continuously,or by pure chance the upper electronics went hay wire
Posted on Apr 11, 2010
Testimonial: "Thank you very much for your advice! Very helpful!!"
ercupa190
  • 12223 Answers
SOURCE: my proform 2605 elliptical the right foot pedal is
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Posted on Nov 30, 2011
We folded the Proform 500 LE Elliptical and moved it. Now we are unable to unfold the elliptical with the latch button. Suggestions?
HOW TO FOLD AND UNFOLD THE ELLIPTICAL
When the elliptical is not in use, the frame can be folded out of the way. First, lift the latch under each pedal arm, and lift the pedal arms off the adjustment sleeves on the crank arms.
Next, raise the pedal arms until they touch the magnets on the upper body legs; the magnets will hold the pedal arms in place.
Then, hold the handle and lift the frame until it locks in a vertical position. To use the elliptical, first hold the handle, press the latch button, and lower the frame.
Next, pull the pedal arms off the magnets on the upper body legs.
Then, lift the latches under the pedal arms, and set the pedal arms on the adjustment sleeves on the crank arms.
Release the latches, and make sure that the pedal arms are securely connected to the adjustment sleeves.
Will be attaching a link to your manual also
http://www.sportsmith.net/images/product_support/ProForm/PFEVEL959101%20-%20PROFORM%20500%20ZLE%20ELLIPTICAL/PFEVEL95910.1-307585.pdf
May 25, 2015 | Proform Exercise & Fitness
My precor efx 546 makes noise like a squeaking in left pedal it seems I tried to tighten pedal but I the whole bolt and screw turn together and the other pedal makes no noise
This squeak is normally caused by a bad bearing in the wheel. In order to provide you with the correct wheel, I will need your serial number. The following link will take you to our Precor EFX 546 page.
Repair Parts for Precor EFX 546 Ellipticals SPORTSMITH net
May 29, 2014 | Exercise & Fitness
Proform hybrid trainer squeaks - elliptical portion only. Everything tight. What do I do now?
Locate the site of the sqeak. Then spray WD40 or similar spray lubricant thoroughly in and around the screws in that area using the straw attachment. I did just that and it took care of the problem.
Aug 07, 2013 | Proform Hybrid Trainer Elliptical
I have a 390 proform Elliptical and it's is locked up. When I get on it, the pedals are tight and I can not move them.
There may be a problem with the belt inside the machine.
It has to be taken apart to assess.
Jul 14, 2013 | Proform 395 E Elliptical
My Nordictrack E9.0 Elliptical machine has a loud squeek
I have found a possible source for your squeak. I have the same elliptical and had an annoying squeak in the front end of the machine. The squeak could be coming from the roller arm flex bracket and/or the pedal arm flex bracket. These brackets are secured to the front of the roller arms and the pedal arms with a single bolt. Tightening these bolts may help get rid of the squeak. If you don't have your manual, you can download the manual at the nordictrack website. The manual will have an exploded drawing of the elliptical. The roller arm bracket and the pedal arm bracket are numbered 135 and 136 and you will see which bolt I am talking about. I have had numerous issues with my elliptical but after changing some parts under warranty, it is working like new. Good luck.
Mar 19, 2013 | Exercise & Fitness
Left side its sqeak when i peddle
My Precor EFX 546 elliptical trainer began squeaking when my weight was on the pedals. I thoroughly cleaned the track and wheels with Windex and then used my finger to apply a thin coat of teflon based lubricant (Tri-Flow brand) to the outer surface of the wheels. After 2 applications of lubricant, the squeaking has been eliminated completely. Hope this helps!
Sep 24, 2012 | Exercise & Fitness
My proform 2605 elliptical the right foot pedal is making a loud noise like it's slipping.
Oct 01, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
How to use the Proform 515S EKG Elliptical?
To mount the elliptical trainer, firmly hold the handlebars or the T-handle and carefully step onto the pedal that is in the lowest position. Next, step onto the other pedal. Push the pedals until they begin to move with a continuous motion. Note: The pedal disks can turn in either direction. It is recommended that you turn the pedal disks in the direction shown below; however, to give variety to your exercise, you may choose to turn the pedal disks in the opposite direction.
To dismount the elliptical trainer, allow the pedals to come to a complete stop. CAUTION: The elliptical trainer does not have a free wheel; the pedals will continue to move until the flywheel stops. When the pedals are stationary, step off the highest pedal first. Then, step off the lowest pedal.
As you exercise, you can adjust the resistance of the pedals with the resistance knob on the console. To increase the resistance, turn the knob clockwise; to decrease the resistance, turn the knob counterclockwise.
Jun 02, 2010 | Proform Exercise & Fitness
Proform XP110 R recumbent bike makes clanking noise.
I have the same problem with my XP 110. After taking the ENTIRE thing apart and independently testing every single moving mechanism, I found out that it wasn't the motor, pedals, armbars, or any internal mechanism. Instead, it was the front stabilizer foot that made the annoying noise. There is a plastic mechanism around the front stabilizer legs that holds the front wheels in place (for moving the elliptical). Whenever a rotation forward occurs, the plastic squeaks and the noise resonates to make it sound like the pedals or motor is squeaking. I am still trying to find a solution to fixing the feet, but may end up ordering a new set from the manufacturer. Good luck with your elliptical!
Mar 22, 2009 | Exercise & Fitness
Exercise & Fitness Logo
48 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
