Question about Whirlpool WTW6400SW Cabrio Washer
F 51 whirlpool cabrio wtw6400swo - Whirlpool WTW6400SW Cabrio Washer
SOURCE: whirlpool wtw6200 cabrio washer error message f 51
I work for an appliance repair company and I had a recent service call for the same exact situation on this washer. I also know that Rotary Position Sensor is linked to the F-51 error code. I have found that this is not always the case. On this paticular call the F-51 error code was caused by a piece of clothing (sock, wash cloth, etc.) being stuck or jammed between the internal basket and the outer tub. I removed the cloth and the washer ran fine, so give that a check first before you spend the money.
Posted on Jan 01, 2009
jsrock516
  • 5911 Answers
SOURCE: Cabrio washer is giving an F 51 Code
The "F51" error code is common problem with the Cabrio. This is an RPS sensor error. The sensor is mounted along the motor windings under the washer and detects the rotation spin speed. The sensors on these units can go bad, causing the error code, and it has been a frequent problem. I would recommend you contact Whirlpool first (due to the unit only being a year old) and see if there is a recall or upgrade on this part. I believe there is. The repair would then be covered by the manufacturer. If I give you the steps to access and/or replace the sensor at this point, you may be voiding any existing warranty you may still have. Some components carry a longer warranty than your normal one year limited warranty from the manufacturer. Something you may consider.
If you have further questions, please let me know. I hope this helps you in some way.
Posted on Jun 11, 2009
  • 299 Answers
SOURCE: help
F then 51 flashes when there is a motor rotor position sensor (RPS) failure.
It can also be a defective control board false reporting an error which is common on these models.
Posted on Apr 27, 2010
  • 327 Answers
SOURCE: Washer stops and F 51 flashs
Hello, It is a rotor position sensor code. The control is no longer receiving a signal from the motor. It can be a failed sensor or control, but usually it is a bad connection where the wires plug on to the sensor.
Thanks
Posted on Jun 11, 2010
  • 202 Answers
SOURCE: whirlpool cabrio top load, has flashing dial and
The F51 error is a RPS (rotary position sensor) board failure where the control board looses contact with the RPS during the machines operation. The RPS uses hall effect sensors to determine the speed and direction of the drive motor, allowing the control board to constantly monitor the motors operation. Because this error is a communication error and not a mechanical error with the motor itself (that would be and F52 error) we can limit our trouble shooting to the three items that make up the RPS circuit, the control board, the wiring harness, and the RPS itself.
Posted on Apr 09, 2011
Where can I find a user manual for a Whirlpool Cabrio washer, model wtw6400swo? Google search turns up dozens of links, but they're all for an 8 page parts manual, not the user manual.
This is the website I downloaded the PDF service manual for my whirlpool cabrio platinum washer. It gave me all the information I needed to make several repairs and run the diagnostics, which confirmed I had a bad drain pump.
http://applianceassistant.com/Appliance-Repair/Appliance-Service-Repair-Manual-Feature.php?id=1563 Hope this helps!
Jan 09, 2016 | Whirlpool Washing Machines
F 51 code
my hhot point washing machine door won't open and is displaying F5 and door block
Nov 20, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Thanks
Jun 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Help
Apr 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F-51 code on kenmore elite oasis washer - how to prevent and or fix
Please see the following Whirlpool Cabrio installation and service manual, the Oasis is essentially the same washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
The F and 51 code relates to the motor rotor.
"F then 51 flashes when there is a motor rotor position sensor (RPS) failure. See TEST #3."
The "test #3 is a bit complicated but can be completed if you are reasonably comfortable with test equipment.
Oct 20, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Whirlpool Cabrio W10106470 has an F51 code. What
F51 error is a rotor position sensor error, two parts really need to be replaced. 1) the rotor sensor itself ($43) and 2) the control board ($197)
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F_i on the cabrio washing machine at the rinse cycle
F is a code then another number or letter should pop up too that is needed. It will say F then a number like 50 or 51.
Dec 10, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool WTW6400SW Cabrio Washer Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
