Question about Craftsman Sears Snow Thrower Manual Model No 247.883700
Shear pins for snow thrower model 247.883700
What type of shear pins is required for snow thrower model no. 247.883700?
3 Suggested Answers
ToolBoxHero
  • 171 Answers
SOURCE: I have a 3 yr
I am going to assume the belt is good if the impeller it running. You can check the belt by removing the plastic cover in the center of the snow blower.
With the unit safely turned off reach in and turn the blower by hand while putting a little resistance with your other hand on the impeller. Does the shaft from the impeller to the gear box turn?
Does the shaft that the augers are attached to turn? If the impeller shaft turns but the auger shaft doesn't, the gearbox in the front is bad and will have to be replaced.
I the auger shaft turns, check your shear pins again. Sometimes they will break but still stay stuck in the holes. Actually take one out and check it.
If it is a Craftsman you can get a manual from managemyhome.com and parts from searspartsdirect.com. You will need the model number of the snowblower. The number looks like 247.123456.
Any other questions please ask. Do't forget to rate this answer!
Posted on Jan 16, 2011
geterrollin
  • 277 Answers
SOURCE: I have a Craftsman 9hp snowblower and it is not
It is belt driven, the belt is located between the chute and the engine behind the inspection cover some have it on the top and some on the bottom.That model may have to be split in half to get the belt past the shaft.But regardless it can at least be inspected by taking the cover off.Please let me know if this helps
Posted on Jan 19, 2011
Looking to see what shear pin the sno trac snowblower model 310-680502
Go to www.doityouself.com Look under who makes sno trac snow blowers. The article tell you what to do.
Mar 19, 2014 | Craftsman 16" High Garden Tractor Snow and...
How to change shear pin
With the motor OFF, the shaft shouldn't rotate, so you should be able to rotate the auger by hand until the holes line up.
Mar 01, 2014 | Craftsman Sears Snow Thrower Manual Model...
Snow thrower auger won't turn
One of the grip levers should engage a clutch that controls the augers. The other grip lever should engage a clutch to drive the wheels. Figure out which is which, and track the linkage from that lever down to the gearbox between the augers and the impeller. See if there's an adjustment you can make there.
If not... the gearbox may be damaged, possibly by hitting a solid object with hardened bolts in the place of your shear pins. ALWAYS use soft shear pins!
Feb 16, 2014 | Craftsman 24" 179cc Dual-Stage Snow Blower...
30 in. craftsman snow thrower,model no. 247.883960,pulls to the right
If your blower uses the two wheels to drive which I think it does I would suggest that you have a shear pin on the right side that is broken. If that is the case you will have to pull the wheel off and replace the shear pin. You can tell if it's broken by lifting the right side and trying to turn the wheel by hand.If it turns easily its broken.
This is an idea only. You might want to check both wheels as I'm not sure as far as the steering is concerned.
Feb 07, 2014 | Craftsman 30 In 357cc* Dual-Stage...
Snow thrower
you need to thin out your mixture on the carb. should solve this.
Jan 30, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
My yardmachine snow blower 8hp auger won't turn. I replaced the cable and belt but it still won't turn. What else could be wrong?
Check the auger shear pins replace if necessary with correct parts(not regular bolts).
If auger and the impeller are not turning your cable is out of adjustment.
If only the auger doesn't turn, and the shear pins are ok then the brass/bronze gear has shredded which is why proper shear pins must be used. Donyboy73 on youtube show how to replace that gear on an older but similar MTD affiliated blower.
Feb 16, 2013 | Yard Machines 24" 208cc Two Stage Snow...
Where is the auger sheer bolt
Figure 9 on Page 11 of the manual (linked below) shows the location of the auger shear pins. Do NOT substitute bolts for shear pins!
http://www.searspartsdirect.com/partsdirect/user-manuals/8227/536881800-Craftsman-Parts-SNOWTHROWER,+GAS-manual?pathRender=fromManualTabPage
Feb 11, 2013 | Craftsman Sears Snow Thrower Manual Model...
Snow thrower let auger not spinning with right side
If you look on the auger shaft you will see some bolts, they are called shear pins. They are there to break if something gets in the auger and jams it, the bolts will shear off to prevent damage to the auger or something else. What you have to do is replace the shear pin or pins on the side that is not turning. Hope this is helpful. All the best and good luck.
Feb 02, 2011 | Craftsman sears 18" Chain Saw Chain (...
Craftsman Sears Snow Thrower Manual Model No 247.883700 Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
