The gren light n my mitsubushi wd 62527 keeps flashing
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Boot up problem and likely bad caps in power supply
the gren light n my mitsubushi  wd 62527 keeps fla - 11_6_2012_6_54_38_pm.jpg11_6_2012_6_54_57_pm.jpg
Posted on Nov 06, 2012
  • 213 Answers
SOURCE: Flashing green light on Mitsubishi WD- 62527 TV
how time dose the light blinking was your pix
dark if so you need a lamp@powersupply for lamp. hope this help you out,
Posted on Aug 25, 2009
  • 556 Answers
SOURCE: I have a wd-62527 that keeps locking up have to
probably a dm board problem only problem is Mitsubishi doesn't have this board the whole chassis has to be sent in for repair.
Posted on Sep 15, 2009
  • 115 Answers
SOURCE: Screen Removal - Mitsubishi WD-62527
SPEAKER GRILLE Removal
Pull the SPEAKER-GRILLE away from the cabinet to remove.
SCREEN-ASSY Removal
1) Remove 10 screws (a) from the upper cabinet rear cover (3 screws on each side and 4 screws across the
top).
2) Remove screws (b) along the bottom of the SCREEN-ASSY (8 screws on 52 inch models, and 12 screws
on 62 inch models),
3) Unplug the LL connector to the front CONTROL-PANEL.
4) Lift the SCREEN-ASSY up slightly and then pull away from the cabinet.
CABINET FRONT DISASSEMBLY
Posted on Sep 28, 2009
  • 135 Answers
SOURCE: my mitsubushi wd 52525 we replaced bulb but can't
This is due to failing capacitors in the power supply. Many people have fixed them self repair but it takes some skill. If you cannot do this yourself, contact Mitsubishi. They will help with the repair under an extended warranty. You will have to pay labor.
Posted on Feb 01, 2010
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi wd 62527 has very dark picture changed
Clean the small front projection mirror. That mirror can get dust on it and will cause the projected image to appear dull and dim and cleaning that mirror will usually restore the brightness and crisp details in the image.
Posted on Oct 23, 2010
My tv a mitsubishi d 62527 the green light kees blinking
Called the blinking green light of death---set should if power lost when put back blink for 70 seconds or so---digital unit booting up.
About the only simple cause is in the main power supply are four 1000 uf caps that puff up and fail--provide boot up voltage.
follower power cord to supply and look for bad caps (they will be easy to spot) and see attached photos of what to look for.
Nov 06, 2012 | Mitsubishi WD-62527 Compatible TV Lamp
I have a WD 62527. mfg Oct 2005, I have been dealing with this problem for two years. TV wont come on and green and yellow light flash, then just the yellow flashes all the time. I can push the reset...
which LED blinks yellow? that model has a filter in the back that you really want to keep clean. also make sure that the lamp door on the back is securely closed. the lamp door and filter are right next to each other.
Dec 23, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My mitsubushi wd 52525 we replaced bulb but can't turn timer light keeps flashing what do i do
Feb 01, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Aug 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
SCREEN-ASSY Removal
top).
on 62 inch models),
Aug 01, 2009 | Mitsubishi WD-65735 Television
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Tv 62527 light goes off when after a few seconds when turned on
This is generally a Power Supply problem, usually the SMPS so it's replacement or repair.
Jul 15, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
