Question about Refrigerators
My Haier mini fridge makes a clicking sound and does not get cool.
dcp2
  • 63 Answers
SOURCE: Haier 4.6 stainless steel fridge...
Check the thermostat. make sure it is turned on. The thermostat can shut it off. Also check to see if you have power to that outlet you are using. If none of that is the problem you can try and bypass the thermostat with a jumper wire( If you are comfortable with do this) Be careful when doing this cause electric shock is possible. don't touch any wires directly
Posted on Jan 28, 2008
  • 171 Answers
SOURCE: I have a mini fridge
Hi ejb9,
I'm Harvey the Master Plumber.
Your question is: You have a mini fridge at school, a small Haier. Your fridge is getting power and the motor gets very hot but the fridge is not cooling, not even a little... any ideas???
May be low on freon or cloged expantion valve. You're going to need a certified tech to check and repair. Maybe it's time to look at the cost of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 14, 2008
  • 531 Answers
SOURCE: Haier mini fridge runs very loudly!
some thing is wrong
Posted on Apr 07, 2009
  • 306 Answers
SOURCE: Making clicking sound motor gets hot but not cooling
Your PTC relay on the compressor is bad needs to be replaced.
First be sure to unplug cooler. Remove the cardboard cover that covers most backs of the units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on May 03, 2009
  • 257 Answers
SOURCE: igloo mini fridge isnt cooling. and making a
i am not a pro just trying to help,,sounds like the timer is stuck,,pull fride out and take the bottom plate off and look for a control with a small knob on it and turn clock wise ,, if it work then ,, maybe keep going but if not replace it.. hope this help you
Posted on Oct 20, 2009
Fridge not cooling
The freezer compartment is easily damaged could have lost it's gas if you tried to remove the ice with something sharp. If the compressor is running all the time then it could be the problem.
Nov 18, 2013 | Haier 1.7 Cu. Ft. Mini Fridge With Freezer...
I have a haier mini fridge model #HSW02C when i plug it in it humms for a few seconds then it clicks then i hear nothing could this be the relay? any sugestions?
I would say that the motor is humming because it is not turning and the click is when the overload control switches the power off. It may be a start run capacitor blown out but it may be a seized compressor motor. have a fridge mechanic check it out.
Oct 13, 2013 | Haier HSW02C
Sides of Haier Compact Fridge are very hot to the touch
On some small units such as this, the condenser coil is actually in the walls of the cooler. It is not that unusual for this type of construction. I have seen this in chest freezers and other such units. If the unit makes the desired temperature, I would watch it for a day or 2 before putting any product into it to ensure it is okay and so you don't loose any product.
Sep 06, 2017 | Haier HNSE045 4.5 Cu. Ft. Capacity Compact...
Haier model HRQ04WNAWW refrigerator. Stopped cooling suddenly. Compressor is hot, really hot, and doesn't make a sound. Light is still on inside of unit, so are getting power.
the compressor has an internal overlod inside of it after 115 degress it opens and wont start till it cools down below 115 unplug and try putting ice cubes on top of com pessor to cool it down otherwise it will take hours to cool off
Aug 07, 2011 | Haier HRQ04WNAWW 4.2 Cu. Ft. Refrigerator
Mini Fridge is not getting cold. Compressor is not comming on at all. Just makes one faint click sound and thats it
you need to go to your local appliance parts store and pickup what's called a 3 in 1 starter,it has the directions on it and easy to install and it will get your frig going again,let me know how it turns out-mike
Oct 15, 2008 | Haier Refrigerators
I have a mini fridge at school, a small Haier. My fridge is getting power and the motor gets very hot but the fridge is not cooling, not even a little... any ideas???
Hi ejb9,
Thank you,
Sep 14, 2008 | Haier Refrigerators
Clicking near compressor but doesnt run not even a year old haier compact mini fridge
since your mini fridge is under warranty, have a technician come and take a look at it. i would say it's the damper.
Sep 13, 2008 | Haier Refrigerators
Haier hrt02wnc compact refridgerator 1.7 cubic
I have a Haier mini fridge model hrt02wncbb it will not cool, The fan runs all the time. I keep it in my class at school but there is five other mini fridge they work find what should i do?
Apr 13, 2008 | Haier HRT02WNC Compact Refrigerator
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
