Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker L712 and rockford fosgate800a2 amp.weak prfmce
The woofer isnt performing like it should. ihooked up an mtx 12 to my amp and it rocked. My solo baric should kill the lower quality speaker.should I wire it parallelcause now it is in series? want it to rattle my bones please help
    Problem Solver:
  • 6 Answers
Is the box sealed air tight, leaking around speaker? plumbers putty works great. Amp may be good enough for the mtx but underpowered for the kicker. When kicker says 1000 watts that what it is (at a 14.4 volt input). Mtx is ok but may not tell the true watts. Check to see if the speakers are the same ohms also!
Posted on Feb 06, 2009
I have 2 different subs in one box, a 12" MTX thunder and a 12" Kicker CVR. the kicker is a dual voice coil while the MTX I dont believe is. Can I use one amp for this set up? And how would it be wired?
im guessing both speakers are 4 ohms ..mtx 4ohms and kicker dual 4ohms..now if your amp can go down to 1 ohm wiring the kicker dual coils in parallel (2ohms) and the mtx connected together (4ohms) should leave you with a final impedance between 1 and 2 ohms ...i suggest you use one or get another
Oct 08, 2013 | MTX Car Audio & Video
I have 2 12 inch kickers cvr and i have the rockfordfosgate g15002 hooked up and briged and it keeps cutting off
This is usually due to wiring the subwoofers to the wrong Ohm load. Normally those amps are rated at a 4 Ohm load. It sounds to me like they are wired down to a 2 Ohm load and bridged. It's a protection situation for the amp. If you have a multimeter, disconnect the woofers from the amp. Next, hook the meter up to the subwoofers where the wire or wires are coming out of the box. If you can give more information on the woofers, I can give you a better idea on what the numbers that you should see. It depends on if they are dual 2 or 4 Ohm woofers.
Apr 23, 2011 | Rockford Fosgate Car Audio & Video
I have an sony xplod 4 channel 600 watt amp
First are they in the same box? If so and they are sharing the same air space running one amp to both is best andwill perform better. One woofer could be over powering the other and or you could have a woofer problem. A lso your wiring coul be problem. When amp is bridged it changes the OHM reading and output your other woofer may not be rated at or able to handle a lower Ohm rating also it coul blow that woofer if it hasn't already hapened . Be careful. check woofers independently for operation and check the non performing woofer on an unbridged power source or amp. Hope this helps. Write back if not.
May 06, 2010 | Rockford Fosgate P112-200 Car Subwoofer
How do i wire my solo-baric L7 12"
how should i wire my s12 L7 2 ohm dual voice coil to my JL 500/1 amp
Sep 15, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
WHAT AMP WILL PUSH KICKER SOLO BARICS 15...i HAVE A RF 1501DB AND IT IS NOT THAT GREAT.
Try any decent amp that runs 800-1000 watts RMS/continuous at 4ohms. Hifonics, Kicker, PPI, MTX etc. You should expect to pay $500+ for a decent amp. You get what you pay for.
Aug 28, 2009 | Rockford Fosgate Power 1501BD Car Audio...
What Amp would i need to push three Kicker L7 12's?
It depends on the specific subs and exactly what you want out of them. You have practically unlimited choices for amps.
The 10" L7 has a power range of from 30-600 watts RMS, the 12" from 50-750 watts, and the 15" from 100-1000 watts.
So if you have the 10's, you would want an amp that puts out at least 90 watts RMS and not more that 1,800. Unless you are really into SPL and have an unlimited budget, it's probably best to go somewhere in between.
Keep in mind that these Kickers need to be in a proper enclosure. They like a little more volume to work as compared to RF's or MTX's and some others.
Mar 30, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Sub blown
As an authorized dealer - i can tell you that kicker WILL NOT repair any subwoofer that is out of warranty.
They use a proprietary cone assembly and do not sell it to ANYONE to make repairs.
Unless you know someone that works there personally - you have a doorstop on your hands.
I have a dead L712 in the shop if you would like matching doorstops :D
Sorry to be the bearer of bad news!
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question (although it may not be the answer you wanted to hear - it is correct.)
Mar 19, 2009 | Kicker Solo-Baric L7 12'' Car Speaker
My solo kicker isnt performing right
do both voicecoils work? try one at a time...then if they do....get a piece of speaker wire about a foot long...connect the positive to the positive and the negative to the negative...then hook the wire from the amp up to one voicecoil....
Jan 05, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker solobarrick...still not working...
kicker aint kickin? warranty,warranty,warranty!!!
Oct 16, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
103 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
