Question about Proview PL713B 17" Flat Panel LCD Monitor
Monitor compatibility with 64 bit system
Will the Proview PL713B 17 in. Flat Panel LCD Monitor work with a new deal 64 bit system
    Genius:
  • 2,120 Answers
Yes
Posted on Jan 05, 2009
Monitor come on for a few seconds then goes black,green signal light stay on green. can you help
the monitor may be losing the back lite. take a flash light or bright light and shine it at the screen after it goes black. can you see a faint picture? if so the back lite has failed. usually the cost of replacement exceeds the cost of a new monitor but there are a couple of web sites that detail the replacement of the "ccfl" cold cathode flouresecent light.
Apr 27, 2011 | Proview PL713B 17" Flat Panel LCD Monitor
How many cables to hook up monitor to tower
1 Single VGA cable will connect into the back of your PC. Another power cable will be needed to plug the monitor into an AC outlet.
Mar 14, 2011 | Proview PL713B 17" Flat Panel LCD Monitor
Was cleaning my mouse and the screen is now having a pink/purple background. How do I fix to go back to the great colors showing as before
This is probably to do with the cables coming loss, push thecables at the back of the monitor into their housing, see if than changes the coulors.
The cables may also be loss at the back of the machine,check this by pushing the cable that runs from your monitor into your PC backinto its housing.
Mar 02, 2011 | Proview PL713B 17" Flat Panel LCD Monitor
Screen comes on then goes off after 5 seconds
You may have power supply DC filter caps problem or the back light inverter circuits, need to inspect the inside.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 29, 2010 | Proview PL713B 17" Flat Panel LCD Monitor
Monitor will not come on...blue light clicks on/off
Peaase make that it not the PC by hooking this monitor to other PC first to see if you still have the same problem before you start taking the monitor apart.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Proview PL713B 17" Flat Panel LCD Monitor
The monitor keeps going blank after a minute or so
hey right click on your desktop.go to properties.in the propertes menu go to screen saver tab.click on the screen saver tab.in the screen saver tab menu you will see a tab called power.click on the power tab.change your settings there for the monitor.let me know if it works.
Sep 09, 2009 | Proview PL713B 17" Flat Panel LCD Monitor
My monitor does not work right. it says vga not support.. its a proview 17" flatscreen..active matrix tft lcd
I suspect your Computers Display settings need adjustments and or a Driver from Proview installed...therefor if you can get on the net, I would look at FAQ's on Proviews Website, i.e:
http://www.proview.net/Support/FAQ_Question.aspx?pi=2026
hope that helps,
Bastian
Jun 02, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
Is this monitor 64 bite compatible?
All monitors are compatible whit 64 bite system
Good luck to you
Dec 18, 2008 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Beware this monitor! PL713s
Probably a good solution. 17" LCD's are pretty inexpensive these days and probably cost as much to diagnose and fix this one. You can purchase on-line as well. www.tigerdirect.com www.newegg.com Good luck
Aug 27, 2007 | Proview PL713S 17" Flat Panel LCD Monitor
MONITOR CONTRAST OR COLOR
find on the net an adjust software (eg. Nokia test), it helps you on dealing the problem...
Jul 12, 2007 | Proview PL713S 17" Flat Panel LCD Monitor
Proview PL713B 17" Flat Panel LCD Monitor Logo
73 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
