Question about Motorola Mobility H700 Wireless Headset
Connect trueblue bluetooth headset to Samsung Eternity cell phone
I truned on the power on button on the bluetooth headset. I got the blinking blue light going on. On the cell phone activated the bluetooth and when I am searching for the bluetooh device it says No bluetooth device found. Please help i have a tmobile dash and im having the same issue with my phone
    Problem Solver:
  • 12 Answers
PLESE TAKE THE BLUE TOOTH CONNECTION IN MORE CLOSELY
Posted on Jan 05, 2009
2 Suggested Answers
boopleloo
SOURCE: Connect trueblue bluetooth headset to Samsung Eternity cell phone
I had the same poroblem. I turned the phone off and then restarted it. That worked for me. Try to make a phone call and see if you can hear it on the Bluetooth.
Also... compliments of Best Buy Troubleshooting -
Bluetooth Troubleshooting: Phones & Headsets
Problem #1:
Headset and phone are turned on, but you don't hear anything in the headset, i.e., there is no dial tone.
Action #1: Make sure your phone is Bluetooth-capable. If it is not: A. Buy a new Bluetooth-capable phone. B. Purchase a Bluetooth adapter for your non-Bluetooth phone. The adapter will allow your phone to interact with a Bluetooth headset.
Problem #2:
It's a Bluetooth-capable phone and Bluetooth headset, both are turned on, but you still don't hear anything.
Action #2: Make sure your phone, headset, and, if necessary, adapter are fully charged before attempting to synch the Bluetooth connection between the two devices - in many cases a blinking blue light will indicate the headset is charged.
Problem #3:
Everything is charged, but still not working.
Action #3:Before two Bluetooth-enabled devices can communicate with each other, they need to be initially synched up to each other - also referred to as linking or pairing.
A. Find "Communications" or "Connections" on your phone's menu screen and explore within to locate "New" or "Bluetooth."
B. Push the main button on the headset until the light shines solid blue and is NOT blinking. C. Select Bluetooth on phone menu. Within Bluetooth you may need to select and highlight "Devices" or "Find Devices" (depending on where you are, there may be other Bluetooth devices available).
D. While the headset light is solid blue, open the Bluetooth link (or Find Devices) on your phone's menu screen and scroll through until you locate the headset you wish to synch up to. Your phone will automatically begin searching for Bluetooth devices within 30 feet of itself.
E. After a short period of time, your menu screen should say "connected" or "devices paired". Make sure you click or select the device name to finalize the connection. If you have successfully paired the two devices, you will hear a dial tone in the headset. Congratulations! You've joined the Bluetooth world.
Note: After a couple of minutes showing solid blue, the light on the headset will start blinking; you want to pair up the phone and headset while the light is still unblinking. This is important. If the light starts blinking before you can complete the connection, you will need to turn the headset off and on and start over.
Problem #4:
You've followed all the instructions in this guide, and your Bluetooth connection is still not functioning properly.
Action #4: Take out your manual and carefully reread the section on synching up Bluetooth devices. If you still can't get things properly connected, we suggest you call the manufacturer regarding this issue.
Motorola: 1-877-MOTO-BLU for troubleshooting, or www.hellomoto.com
Jabra: 1-800-327-2230 from 8 a.m. to 8 p.m. EST for technical support; or www.jabra.com
I hope this helps.
Posted on Dec 19, 2008
I just bought a TrueBlue TB-92EX bluetooth heaadset and when I try to pair it to my Samsung Android K3 it doesn't find it... Help... Please
go to setting , Bluetooth and delete some of your paired devices after you finish that switch on your phone Bluetooth to visible to all nearby devices also switch your trueblue tb 92ex Bluetooth to connect
Apr 08, 2017 | Samsung Cell Phones
How do you turn the samsung hm3700 bluetooth on? How do you snyc it to your phone?
To turn on the Samsung HM3700 headset, slide the power switch up. (You can see it's location on the image below). The indicator light below the power switch will blink blue 4 times (purple or red means your battery is low). If it stays blue it is ready to sync with your phone.2_29_2012_5_42_10_pm.jpgThere are 3 ways to sync this device to your phone:
  1. Once the headset is on, hold down the talk button for 3 seconds. (the blue light will stay lit for 3 minutes once you enter pairing/syncing mode).
  • Activate Bluetooth on your phone and search for the hm3700 (keep them close to each other).
  • Select the headset and enter a PIN number if asked.
2.) Active Pairing: Once you have held down the talk button for 3 seconds and the blue light is on, press and hold the talk button again to make the blue light purple.
  • The device will try to automatically connect to your phone for 20 seconds. Your phone should not be connected to other Bluetooth devices during this process.
3.) FreeSync is an application you can download if you have an Android (from the Android Marketplace). It allows you to access your headset settings and I believe it can read your text messages for you (text to speech).
For more information the user manual for your Samsung HM3700 Bluetooth headset can be found here: http://downloadcenter.samsung.com/content/UM/201111/20111116163119314/HM3700_UM_America_B_Rev.1.0_110923_screen.pdf
Feb 29, 2012 | Samsung Cell Phones
Blue Parrott Road Warrior B250XT, will not stay connected to my phone, The phone is a Motorolai335, it will connect and disconnect just when ever some times every 3 to 5 minutes and will reconnect within...
These steps are for a headset that is already paired to you cell phone and is stored in the phones trusted device / history list.
Look at the lights on the Multi-Function Button of the headset (the top / largest button of the three buttons); the light will be blinking Red if not connected and blue if connected (paired and connected are two different things). Push the volume up (middle button) 2 times, you should hear a beep each time you press it. If you hear the beeps go to the next paragraph. If you hear no beeps at all you will need to call 1-800-742-8588 for an RA # (Return Authorization Number) for warranty and non warranty repairs.
Look at the lights on the Multi-Function Button on the headset (the top / largest button of the three buttons); the light should be blinking Red if not connected and Blue if connected (paired and connected are two different things). Plug the headset into the power adaptor with power applied. Make sure your cell phone is on and the Bluetooth power of the PHONE is turned on. After 5 seconds unplug the headset from the charger and do not press any buttons. You should get a slow Red blinking light at first. Allow the headset to connect automatically to the cell phone, this may take up to 10 seconds. Once the connection has occurred the Blue light on the Multi-Function Button will blink once every second.
If after 10 seconds the light is still blinking Red once every 5 seconds you will need to press either the Multi-Function Button of the headset once to connect to the cell phone, or, your phone may be set up requiring you press a designated button or sequence in the phone to connect to the headset (meaning your cell phone is not set with or does not support automatic connect).
*NOTE* Most newer model cell phones have an automatic connect feature. Some phones have the categories of "Headset", and "Hands Free" in their Bluetooth menu. Some companies use the term Auto-Connect under the "Hands Free" category in their Bluetooth menu to indicate the set up for use with the Bluetooth system in an AUTOMOBILE.
Automatic connection under the "Headset" category and Auto-connect under the "Hands Free" category are not the same thing. When dealing with the headset you want to work in the "Headset" menu and make sure the Auto-connect of the "Hands Free" menu is turned off.
If this doesn't correct the issue I'd recommend calling VXi at 800-742-8588 for additional clear and reset instructions and the possability of warranty repair options.
Aug 29, 2011 | VXI Corporation Blueparrott B250-XT...
My em228 flashes blue red why?
It is NOT the battery. When you turned the bluetooth on, only hold the power button until the blue light flashes about 3 times. If blue tooth is enabled on your phone, this should allow the bluetooth to connect without having to search for any devices, that is, if you already have it in your settings.
The red and blue alternating lights are to setup the bluetooth and allow it to connect to your phone, THE FIRST TIME. Once the device is listed in the bluetooth settings on the phone, you can just connect, instead of searching for the device every time you need to turn it on.
Only hold the button until the bluetooth flashes BLUE, about 3 flashes........see if this works better for you.....
Another frustration, (sometimes) depends on what brand of phone you have. I know my EM227 connects differently between my DG Razr and my Samsung Eternity.
Let me know if this helps, and if not, let me know what phone you have, and I will tell you for sure, exactly how to turn on and connect, with no problems.
Good luck~~!
mstipps@yahoo.com
Nov 18, 2010 | Emerson EM227 Bluetooth Headset
How do I setup wep301 headset to a simple at&t phone
Follow the steps to connect your WEP 301 bluetooth headset to phone.
1.When you turn on your Samsung Bluetooth
headset for the first time, it proceeds into pairing
mode immediately.
2. If you have paired the headset with other
Bluetooth devices, make sure that the headset
is off. Press and hold the Multi-Function button
until the blue indicator light stays solid blue after
blinking.
3. Set your Bluetooth phone to discover the headset
by following your phone’s guide. Typically, the
steps involve going to a ‘Setting’, ‘Connection’,
or ‘Bluetooth’ menu on your phone and then
selecting the option to discover Bluetooth devices.
4. Your phone will find the Samsung headset and
ask if you want to pair with it. Confirm this by
pressing the Yes or OK key.
5. Enter a passkey or PIN, 0000 (4 zeros), then
press the Yes or OK key.
6. If pairing was successful, the indicator light will
flash in blue 10 times rapidly before going to
flashing every 3 seconds. If unsuccessful, the
light remains on, and you will need to re-attempt
pairing.
7. When you turn on your headset after pairing
with the phone, the headset is automatically
connected to the phone.
8. When you turn on your phone after pairing with
the headset, the phone is connected to the
headset by pressing the Multi-Function button.
Thank You
Aug 14, 2010 | Samsung Cell Phones
Bluetooth device cannot be found by Samsung Eternity
Reset your phone by taking out your battery try again
Aug 15, 2017 | Cell Phones
Won't connect to trueblue bluetooth
my friend found her book with the instructions. You have to turn the phone on. Make sure the bluetooth is enabled. Then hold the power button on the bluetooth down until the red and blue lights flash back and forth. then try to discover it on the phone. it works!!!!!!!
May 11, 2009 | LG Vu CU920 Cellular Phone
Pair motorola H500 to samsung eternity SGH-A867
I have had this problem too. Here is what worked for me.
1) With the Motorola H500 OFF, press and hold the talk key until you see a steady, non-blinking blue light.
2) Keeping that button pressed, turn on the bluetooth on the samsung eternity.
3) It should now find the H500, click on it and select connect.
4) Put in a pass key (I just put in 0000) and your done.
Mar 06, 2009 | Cell Phones
hold your finger on the call button on your blutooth device for around 6-10 seconds, this should make a couple of lights flash, when it does this it is active and ready to pair uo, then search, it will ask you for a code, usually they are generic and are prob the following 1234-12345-1111-11111-0000-00000-5555-55555 eiter one of these should work
Dec 26, 2008 | Cell Phones
Problem #1:
Problem #2:
Problem #3:
Problem #4:
I hope this helps.
Dec 19, 2008 | True Blue TB-50CR Bluetooth Headset
Motorola Mobility H700 Wireless Headset Logo
298 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
