Question about Sony PSP (Piano Black)
DNS Error using my PSP Internet Connection!!!!
Hi There!
I am trying to set up my daughter's internet connection on her PSP. I have a wireless network and am getting an error message each time I set the connection up: Communication with the server failed. A DNS error has occured. (8040418) Can someone please help me with this problem?
  • Anonymous Jan 10, 2009
    me to
  • 864 Answers
I can assist you with this.
Instructions
1 Take out the UMD disc from the back of the PSP if one is inserted. 2 Take out your memory card from the memory card reader if one is inserted. 3 Turn on your PSP. 4 Go to the "Settings" tab in the Cross Media Bar and select "System Settings." 5 Select "Restore Default Settings" and confirm that you wish to restore all settings to the factory defaults. 6 Restart your PSP. 7 Try connecting to the Internet again. If you still get the 80410A0b error, try connecting to another network. If you successfully establish a connection to another network, your router is at fault. If you cannot connect to the second network, your PSP's Wi-Fi card could be damaged and may need repairs. Tips & Warnings
Ensure that you are entering the Wi-Fi SSID and password correctly on the PSP. You can contact PlayStation Support (see Resources) to start a repair order if you PSP's Wi-Fi card is faulty. if you require further assistance please let me know and i will be glad to assist you. Thanks
Posted on Aug 27, 2010
Fix psp dns error 80410418
According to TARO, try this "System Setting - Default Setting will reset every thing for you and if you have a functioning connection will find it on reboot." (http://pr0gr4mm3r.com/internet/fix-psp-error-with-opendns-80410418/)
Jun 22, 2014 | 2wire Computers & Internet
Psp help
Did you know you can use your PSP to pick up free wireless internet? Most people don't even realize this but it's pretty straightforward once you know how! Sit back and relax while you learn to get internet on your PSP!
Requirements:
There are a couple of fundamental things you will need before you can start surfing the web with your PSP. The first is some form of wireless internet source. It doesn't matter where it comes from, could be in your home or in your local Starbucks, all that matters is that you are in an area where you can get internet. Psp wireless settings follow the 802.11b wireless networking protocols, which are just about the most common in the world, so most kinds of wireless network connection will be just fine.
Also note that a copy of Wipeout:Pure is necessary to get internet on your PSP.
Sitting comfortably? Ok, prepare to learn how to get internet on PSP!
Step 1- Switch on the PSP and go to the System Menu, and then enter "Network Settings". From there go into "Infrastructure mode", and select a connection to edit. If you already have a home connection set up or something, just select this as the one you are going to edit. Leave the name of the profile as it is, and skip the WLAN settings if they are already set up.
Step2- Go into "Address Settings" click on "Custom" and be sure to leave "IP Address Setting" as Automatic. Believe me; adjusting this will not help you get internet on your PSP!
Step 3- Go into "DNS Setting" and click on manual. This is where we need to type the address of the web gateway we will be using. The most popular one to use for this is the gateway at Endgadget, so input the numbers "208.42.28.174" as the Primary DNS IP, and put zeros for the Secondary DNS IP. (0.0.0.0). If for any reason this gateway is not working you can usually find others with a quick Google search.
Step 4- In the "Proxy Server" options, select "Do Not Use" All you need to do from there is confirm everything, and save it all by pushing X when prompted.
Step 5- Launch Wipeout:Pure as normal, and go into the Downloads menu. When asked to select a connection, choose the one you have just been editing, and you should be presented with the Endgadget web screen. Et voila! How to get internet on PSP!
Provided you have the resource mentioned above, it's pretty easy to get internet on your PSP. Once you have it all set up you'll probably wonder how you got by without it!
Jul 27, 2010 | Sony PlayStation Portable (PSP) Console
When I try to connect to the internet using a wireless connection, a screen comes up says "Communication with the server failed. A DNS error has occurred. (80410402)." How do I fix this problem?
if it is saying DNS error it is not a problem with the PSP, most likely a setting with your wireless router. or a problem with teh internet at the time of trying. check wireless settings on the PSP and make sure it has a number listed for DNS server.
Nov 24, 2009 | Sony PlayStation Portable (PSP) Console
DNS error when trying to connect to internet
1- Try setting your own DNS server settings, right click on your network connection > properties > TCPIP v4 > edit DNS settings ( use dyndns.com as a dns for example).
2- Try refreshing your DNS cache:
start > run > cmd > and type: ipconfig /flushdns
Hope it helps !
Feb 01, 2009 | Dynex 802.11g Wireless-G Laptop Card
Dns error when connecting how do I fix this
Unstable connection. if you have wireless connection that could be a problem depending on your environment. Try turning off your firewall too by calling your internet server(Comcast,DSL,etc.)
Jul 31, 2008 | Sony Playstation 3 (PS3) Console
DNS error (80410411) cannot find server
If you are using a public router (meaning you're using just a connection from somebody else's router) prolly, you're DNS have been blocked...have you tried connecting to other sources other than the one you can't use? If you have a connection and you don't own your own wireless router, try borrowing one from someone you know first then try if it works...then that's the time you should ask for your own wireless router...
Jul 29, 2008 | Sony PlayStation Portable (PSP) Console
Dns error # 80710102 ip address ok but internet connection fails
Contact your network admin or Your ISP (Internet Service Provider)
-Rel
May 28, 2008 | Sony PlayStation Portable (PSP) Slim...
DNS error while connecting my psp
i got solution
dont solved problem!
ok solution:
click inafacture mode in network settings.
new connection > scan > now look for internet wchich has no security > choose it > then click left arrow > then choose easy and go to the save settings, save,test connection. IT WILL SAY YOUR INFO AT THE END AND THEN YOU CLICK CIRCLE GO TO INTERNET BROWSER AND ENJOY
IF SOMETHING GOES WRONG TRY AGAIN IN DIFFERENT PLACES.
it should work.
enjoy internet
Jan 13, 2008 | Sony PlayStation Portable (PSP) Console
DNS error
Hey here are the instructions for your problem...
Go all the way left to SETTINGS
Get into SYSTEM SETTINGS
And then Go into RESTEOR DEFAULT SETTINGS and press YES
After you do that go into NETWORK SETTINGS
Then Go Into INFRUSTRUCTURE MODE
Then NEW Connection
Scan Your Wire-less connection and then go to internet browser wait for it to load and get ip and your fixed up
Dec 28, 2007 | Sony PlayStation Portable (PSP) Console
Error code 80410418
the same thing has happened to me.. I reset my psp completely! erased everything!! and still, the same bs dns error etc. if you find a solution to the problem.. email me at mrgrimm.ghs.mailbox@gmail.com, thanx!
Nov 30, 2007 | Video Game Consoles & Games
Sony PSP (Piano Black) Logo
161 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
