Question about Refrigerators
Left side fan fail repeat - Refrigerators
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Nov 06, 2012
Oki B431D error 127
The fan on the left side of the chassis has either failed or is running slow. They do however get quite a lot of dust and c--p on them and that can slow them down. Remove the left side cover and clean the fan. If that does not cure it then a new one is required. The part number and description are: 43289101 OR-Motor-FAN(80). Any OKI dealer should be able to get it for you.
Aug 25, 2016 | OKI Office Equipment & Supplies
Recently on start up my PC shutdown after a message that the CPU fan had failed. I took the side off and could see that the jeat sink and fan were well covered in dust and fluff. I have cleaned both and...
It can be a failed motor or if the bearings are dry or worn it can make the rotor stick..Try and see if you can wobble the fan left and right, if it wobbles a lot replace the fan..if its a bit tight to turn you can put a DROP of oil on the bearing fron the non fan blade side (remove the sticker) But prob replace the fan as they are cheap..
Sep 05, 2013 | Computers & Internet
Geting erro of 59.00 in 4250 printer
hi
HP LaserJet 4250n Printer - (Q5401A)
replace the fan --- erro 59.00 is failed fan.
on right or left of printer
Fan RK2-0278-000CN In stock
Cooling fan - Located on left side of printer (FN101)
RoHS: Modified
93.60 0.00 93.60 RK2-0280-000CN In stock
Cooling fan - Located on right side of printer - Provides air to the print cartridge area (FN103)
RoHS: Modified
Aug 01, 2011 | HP LaserJet 4250n Printer
Panasonic - TH-46PZ85U - Will not power up, either from the remote or from the TV on-off power button. With the TV plugged in, a light on the bottom left corner flashes 10 times, pauses and then the...
Could be a cooling fan failure, there are five fans across the back of this tv ( i think) if even 1 fails the power supply shuts down. If so fan needs replacing,
pete
Nov 11, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
The electronic touch control has fallen inside the hood this is the second time it has happened is there a plastic mounting bracket on the switch that has broken? left side of switch I can see a mounting...
Yep! This is a classic problem with the Therador PHE series hoods. Very weak design and NO help from the factory! Just the plastic housing is $82.00 bucks online. The panel is REALLY hard to access and the control boards, inside, fail regularly. The board alone costs over $200.00 bucks! These will fail to switch on the fan or change fan speeds or turn lights on and off or fan off. All of this randomly and arbitrarily so people tend to push the switch buttons too hard, causing the bracket to fail and entire panel body falling off inside. We have had ours propped up inside with two chop sticks for several years now and to get the fan to switch on or change speeds we fiddle with the chop sticks while repeatedly pushing the buttons and sooner or later it comes on. The lights rarely will come on, however. This unit is made by Bosch and they have all the same problems with NO fix except to replace ENTIRE control panel at a cost of $350.00 retail. This is truely an example of modern, fancy kitchen appliance over-engineered ripoff junk. Looks great but it makes sure that the fool who buys into the Brand name and cool design gets to pay and pay again for their naivete'.
Oct 16, 2009 | Thermador 30", 36", 42", 48", 60" Wall...
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
Left rear turn signal quit on 2000 ford ranger.
Check correct wattage globe is installed in both front and rear indicator lights;
check if any other side/repeat indicator lights have failed.
Jun 18, 2009 | 2007 Ford Freestyle Limited
The dreaded blinking lights
It can be saved, but you need to determine the fan that is bad. Looking at the set from the rear, on the left side you will see a series of baffles. Shine a light in there and you will see a fan. Have someone turn on the power and watch this fan. If it doesn't turn, there is your culprit. This is the most likely fan to fail. Please be sure to rate this solution. Thanks!
Jul 01, 2008 | Sony KDS-60A2000 60" HDTV
Fan or motor contantly running and howeling
It really sounds like you need to replace the evaporator fan motor if it sounds like an a/c fan (if it sounds cyclic, metal on metal, screeching, or even like a light aircraft then the bearings are probably failed). The only addition I would make to this is when checking the fan motor with the back cover off you check for any undue ice build up on the coil which may be causing the howling (TO RULE THIS OUT). Hope this helps.
Aug 08, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
