Question about Dishwashers
DISHWASHER WONT STOP UNLESS YOU MANUALLY TURN IT OFF
I PURCHASED A FRIGIDAIRE FDB520RHS DISHWASHER YESTERDAY. USED IT FOR THE FIRST TIME TODAY AND IT RAN IN THE WASH CYCLE FOR OVER 2 HOURS. I CHECKED THE FLIMSY USE AND CARE GUIDE TO SEE WHAT THE APPROXIMATE CYCLE TIME FOR NORMAL WASH IS. ITS SUPPOSED TO BE 89 MINUTES INCLUDING THE DRY CYCLE. I WENT TO THE FRIGIDAIRE WEBSITE TO TRY TO DOWNLOAD A USERS MANUAL BUT THEY DONT EVEN HAVE THAT MODEL IN THEIR DATABASE, NOR DOES ELECTROLUX. CLEANS THE DISHES REALLY WELL BUT CANT LEAVE IT UNATTENDED DUE TO POWER AND WATER COST.
  • 530 Answers
Wow, I am just wondering is the water inside the dishwasher warm or hot? Or is it cold? IF it is cold it could be that the unit is trying to heat the water usually to 120 degrees.If it is hooked up to a cold water valve from your house this could be the problem. Or it is the heating element,.
Posted on Jan 05, 2009
Frigidaire FFB240 dishwasher won't stop
Good Morning AA1970,
I see that you are having trouble with your Frigidaire dishwasher, model# FFB240, continuing to run unless you shut it off. While I'm not familiar with this particular model number, I suggest that you give the appliance a hard reset. You will do this by shutting the power off at the circuit breaker for at least 20-30 minutes. After restoring power, run the cycle. If it is still continuing to run unless you shut it off, I suggest contacting a local authorized technician for further assistance.
-Best Regards-
WP
Apr 01, 2014 | Frigidaire FFBD2406NS Built In Dishwashers
Dishwasher model FDB52ORHS2 makes terrible noise when filling up
Possible that the inlet valve is chattering as there is dirt or there is problem in the flow tube , You must remove the hose from the inlet and check the flow and if the noise stops. If not disconnect the valve to confirm
Jun 30, 2012 | Frigidaire FDB520RHS Full Console...
My dishwasher is making a load hum what its in a wash cycle. The model is a Frigidaire FGHD2433KM. What would cause this problem? David
Chances are it is a defective motor. The motor in mine went out three months after installaton and again nine months later, just outside of the warranty period. Frigidaire offered to replace it, covering parts and labor, as a "good will gesture" but said they would not replace it a third time unless I purchased the extended warranty. In my opinion the part was either designed poorly or manufactured poorly, or both.
Nov 08, 2010 | Frigidaire FGHD2433KF Builtin Dishwasher
Dishwasher is less than a year old. Once in a while it will stop about 10 minutes into the cycle, then the display lights will blink. Sometimes it will stop and the lights wont blink so we will come back...
I would most likely guess a faulty latch....it will cancel the cycle, thinking that the door has opened, and the lights will flash. After a certain amount of time, it might "time out" and reset and the lights would stop flashing. Unfortunately it's a bit of a guess, but the other option would be a bad control board.
Apr 07, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Kitchenaid dishwasher Serial # FR2301552 Model # Kud101LWH5 Used yesterday but nothing will cut on today 10-15-09
Yes we solved the problem, called a serviceman and the parts and labor were to much to invest in an old machine and yesterday I purchased a new dishwasher.
Oct 15, 2009 | Dishwashers
Frigidaire portable dishwasher wont start
check the outlet where you plug this dishwasher into make sure you have power to it you may have a popped breaker. reply back if this is not the cause.
Nov 18, 2008 | Frigidaire 18 in. FDR252RB Built-in...
Viking Dishwasher won't fill with water
NEED TO CHANGE THE ELECTRIC TAP IN THE BACK OF THE DISHWASHER.
THE TAP IS WHAT THE WATER HOSE CONECTS TO AT THE BACK OF THE MACHINE.
Oct 14, 2008 | Viking 24 in. Professional Series VUD141...
Dishwashers Logo
427 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
