Question about Husqvarna 952711918 Leaf Blower Gutter Kit 125b 125bvx ()
Does Husqvqrna kit 952711918 fit 350 BT Blower
I purchased Husqvarna 370 BT Blower & now need gutter attachment
4 Suggested Answers
  • 10 Answers
SOURCE: what is the gas to oil ratio for the husqvarna
This blower uses a 50:1 oil ration
Posted on Apr 11, 2010
  • 2239 Answers
SOURCE: what is part number for plastic choke clip on husqvarna 356 bt blower
The clip is part of the choke shaft, the choke pull wire clips into it, the part no. is 537390201 they always break, the blue choke pull itself is part no. 537215701.
Posted on May 13, 2012
  • 7 Answers
SOURCE: can I extend the length of the blower tube on my 125BT blower?
I tried that (once). Used ABS plastic from Lowes to make a custom gutter cleaner, attached to a big ECHO back-pack leaf blower. Several problems: 1) Pipe is heavy, so put a couple of 90 degree elbows on the end to "hook" onto the gutter. 2) Need to wear a rain suit, because of the NASTY decomposed leaves raining down. 3) The air tended to lift the shingles (very bad). I only tried it once and don't recommend trying it. The same idea with a garden hose may work better? Eventually, leaf guards were installed with limited success.
Posted on Nov 01, 2012
Why does it "bog out"?
excess fuel and not enough air
check for blocked air filter, blocked exhaust , blocked jet
Nov 04, 2015 | Husqvarna Backpack Leaf Blower 350 Bt Yard...
Gutter attachment for leaf blower
Would that work for seamless gutter? We are going to replace ours and we had been looking into getting the seamless kind cause they looked fairly easy to deal with. It would be awesome if that leaf blower attachment worked for our gutters. http://www.thompsonheatingcooling.net/Seamless-Gutters
Nov 07, 2013 | Husqvarna 560BTS Backpack Blower
My blower just stalled and will not run it is less than a year old and now the pull cord is very tight but it will turn and start but it will not run for mor than a few seconds
Have you changed the fuel.? If it had been stored for a long time with fuel in it then it could have gone stale and will need replacing. Also the 2 stroke oil can gum up carbs as the fuel left in it evaporates. Possibly clean carb, check fuel is getting into the cylinder.
May 09, 2013 | Husqvarna Backpack Leaf Blower 350 Bt Yard...
Husqvarna Repair Manual
Have you used the correct fuel and oil mixture.?
If its new and still under warranty then take it back to your local dealer.
Here's the parts manual
May 08, 2013 | Husqvarna Backpack Leaf Blower 350 Bt Yard...
Can I extend the length of the blower tube on my 125BT blower?
Nov 01, 2012 | Husqvarna Garden
Husqvarna 350 bt won't start
Do you have good compression, good spark and is fuel getting into the cylinder.? More information would help diagnose the problem.
Jun 03, 2012 | Husqvarna BACKPACK BLOWER 350BT
Blower cranks easily and runs fine for about 1 minute and quits. I have cleaned the air filter and changed the spark plug but no luck. Any suggestions would be appreciated?
run it till it quits. pull the plug wire and check to see if you still have spark when pulling it over. if no spark replace the ignition module. if you still have spark then your fuel tank may not be venting. loosen the fuel cap enough that you know its venting and try running it again. if problem solved replace check valve and or fuel cap. hope this helps you
Aug 16, 2011 | Husqvarna 952711918 Leaf Blower Gutter Kit...
Leaf Blowers Features
* CFM (cubic feet per minute) is the measure of vacuuming power. Ratings fall in the 350 to 600 CFM range. * MPH (miles per hour) measures blowing. Leaf blowers perform at levels from 125 - 210 mph. * Decibels (dB) is the noise rating. * Reduction ratio on mulching blower/vacuums calculates how many units of leaves the mulcher can produce. A 10:1 ratio means that 10 bags of leaves can be reduced to 1 bag of mulch. * Speed settings allow better control when blowing or vacuuming. * Attachments, such as extension tubes for cleaning gutters, are available separately.
Aug 27, 2008 | Craftsman Blower Attachment
Husqvarna 952711918 Leaf Blower Gutter Kit 125b 125bvx () Logo
57 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
