Question about Dishwashers
Air pump for door seal not activated MODEL-DD601V2 . Dual draw dish washer.Would it be the PCB is faulty or a program error?
2 Suggested Answers
  • 842 Answers
SOURCE: top draw has code U2
I have seen this fault code on 3 occasions. It is caused by someone has been opened or forced open during cycle, You will need to reset the drawer by turning off/unplug unit wait 20 sec, than plug back in. If the code doesn't go away there are to possible issues. First one, drawer micro switch has failed, second one, exhaust valve has failed and would need to be replaced.
I have done both in the last year and I can say its not a simple part change depending on how the unit was installed. If you have never worked on this drawer I would suggest seeking a professional to correct the problem. Here is a number for the factory who can direct you to a trained person 1 (888) 936-7872. This is a 24/7 phone line and will direct you to everything you need to correct the problem.
Any more questions please feel free to ask..
Posted on Jul 15, 2011
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
How do I drain water out of dish draw
http://www.scribd.com/doc/6462163/DD601V2-Manual
The Dishdraws are designed to leave some water inside so the drive pump does not burn out on initial start up.
Also check your levels and the flow of the drain hoses. Try removing the hoses that plumb into your sink drain and place them into a bucket . Run the Dishwasher to check the hoses are not blocked, This link should provide anymore info if required.
Sep 16, 2014 | Fisher and Paykel Dishwashers
On my Amana Model # ADB1100AWW dish washer the soap door will not open during wash.
Possible Causes:
1) clogged door latch
2) door latch solenoid faulty
3) PCB Board
Oct 01, 2013 | Amana 24 in. ADB1500AWS Stainless Steel...
Colins, Please, I have already checked: the volmetric with PTC door interlock, motor, electrovalves for water fill system, pressure switch, the drain pum, heating element, heating sensor, all the...
Ok..Not sure if this applies to your model however.The drain pump can be activated by a Float micoswitch if the machine is leaking water, also if the drain hose is too low then it will syphon away the water......Both of these will cause the drain pump to empty the machine..
Jan 21, 2011 | Tricity Bendix AW1000W Front Load Washer
What does f 11 indicate. The wash gets to the end of the cycle but F11 then appears and the door will not open.
F11 - Pump cannot be activated
f11 lights 1&3&4, pump/draining error
this means an open circuit pump or fauty pcb
Nov 28, 2010 | Hotpoint Aquarius WD640 Front Load...
Doulbe Draw model receiving an F1 error message.
F1 indicates flood switch has been activated. I wouldn't advise you attempt repair on these drawers- they really require an expert to disassemble (I worked for F+P for 10 years!!). Depending on which model you have (DD603 or DD601v2), repair varies. 603 has a small circuit board that acts as flood switch- located in base beneath drawer- requires drawer to be removed for access. 601v2 model has polystyrene float that acts as flood switch-leaks usually caused by split lid seal(tricky to access- drawer has to be removed) In either case, a leak has occurred and activated flood switch. These drawers are very sensitive to detergents (don't use tablets!!), and the way they are loaded.
Would suggest you get service technician to remedy F1 fault
Aug 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishdrawer DD601 v2 Error F1 on the bottom draw.
Below is the link to the service manual
This will be able to explain the problems better that I can in the tiny space I get to write in.
Mat
Please rate me
Mar 15, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hoover easy logic error message number 3 model is a EL 160
E3 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain program.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 25, 2009 | Washing Machines
Dishwashers Logo
29 people viewed this question
Top Dishwashers Experts
