Question about Fuji FinePix A205 Digital Camera
Zoom error--again! I followed the steps suggested on the zoom error for when the lens comes out before the error message. That worked, for a short while, but now the lens stays in and I am receiving the zoom error again. I can't hold the lens down, since it is already in the down position. I can hear something clicking inside, when I turn it on, but nothing happens. I tried recharging the battery, and even removing the battery for a few moments. I am at a loss as to what to do next. :-(
    Genius:
  • 2,985 Answers
Try Fuji website for tech help - looks as if this needs some surgery. If it is a recent purchase they may fix it for nothing - depends where you are.
Posted on May 22, 2007
DSC W80 Error Message - Zoom and Picture Doesn't work
There is something blocking the sensors for the lens position. This can something as small as a piece of sand. The motors and gears that move the lens are very small and delicate. You can send it in for repairs to www.unitedcamera.com
Nov 24, 2013 | Sony Cybershot DSCW80 7.2MP Digital Camera...
System error Zoom
Lens errors (system error zoom on Panasonics) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Apr 13, 2012 | Panasonic Lumix DMC-FH27 / DMC-FS37...
Camera will not take pictures. Message on screen says: System Error Zoom I have not had any problems with zoom. How do I fix or clear this message. Thanks, Marsha
Please follow the steps:
1. Ensure batteries are fully charged.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine.
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec... in not done the press both Menu & self time key for 2 - 4 sec.
After all of this if you not success then its a lens error.The lens stuck from the inside becasue the lens guide pin is damaged or out of guide line. In this case you have to replace or repair the camera lens.
Hope helps; keep us updated and remember to rate this answer.
Jun 16, 2011 | Cameras
Zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix F410 Digital Camera
Zoom in/out power off message
While zooming in-out camera gives error message means lens mechanism is either defective or lens drive motor is bad. In both cases, lens assembly will be replaced.
Contact nearest camera repair shop for fix.
Thanks.
Sep 04, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Lens does not zoom in
This is not a common error on canon digital. This is caused due to possible short in zoom control circuit (main pcb). At normal use, if the lens does not retract due to mechanical jam, when the zoom control button is pressed, lens error 18 message supposed to be displayed. Since control circuit is shorted and faulty, error 18 message was not displayed. The remedy for this problem probably requires a replacement of a main pcb. Replacing a main circuit board may run around $100-140. -James
Mar 29, 2009 | Canon PowerShot A640 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Zoom error message on fujifilm a350 digital camera
whilst reading out loud instruction to fix the 'zoom error' my wife turned and twisted the zoom lens clockwise and shake th camera gently - all of a certain it worked again as per normal - try it - hope it works for you too!
Feb 17, 2008 | Fuji FinePix A350 Digital Camera
Fuji finepix A600 camera - Zoom error
I had the same problem turn up after a few weeks. When I used the zoom button, the lens pushed out again and the camera worked normally for that time. I had to go through that procedure every time I turned the camera on.
I then sent it back on warranty and they replaced the lens assembly as well as the mode dial knob etc.
This camera has a 3 year warranty.
good luck...
Jan 02, 2008 | Fuji FinePix A600 Digital Camera
Fuji FinePix A205 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
