Just recently everytime i startup windows xp pro an error message display SETUPLOADER.EXE-353E738A.pf failed to initialize the application
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Check ram modules for dirt and dust as well as ram sockets for dust and debri then reseat the modules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps
Posted on Nov 06, 2012
The Machine
  • 788 Answers
SOURCE: System Code Error 87
Sounds like the application you are running may not be compatible with Windows 98. Probably can't do much as Windows 98 is so old.
Although it may be a missing file, DLL, or driver on your Windows 98 system, hard to tell.
Posted on Jan 11, 2008
SOURCE: problem when installing windows xp pro sp2
i have a problem i cannot remove nero trial and nero scout to my programme it say shellmanager database has corrupt so i want to remove this to my programme pls.help me
Posted on May 11, 2008
  • 23 Answers
SOURCE: Windows Startup Error csrss.exe
Okay, we are going to try two things. If the first don't work go to the second.
1) First perform a search on your computer for the 'csrss.exe' file. If found, copy it and then paste it into your C:\windows\system32 folder.
That should do it.
2) If that don't do it or your search can't find it, then perform the following;
To scan and verify the versions of all the system files that Windows File Protection protects, use the System File Checker (Sfc.exe) tool together with the /scannow parameter. If the SFC.exe tool detects that such a file was overwritten, the SFC.exe tool retrieves the correct version of the file from the Dllcache folder or from the Windows installation source files, and then replaces the incorrect file.
To run SFC, please follow these steps:
1. Click on Start > Run command prompt
2. Type SFC /scannow, and then press ENTER
Note: You may be asked for inset OS CD.
3. After finishing SFC, you may run CHKDSK C: /R in the Run command prompt as well.
Posted on Feb 14, 2009
  • 1082 Answers
SOURCE: When i open some applications windows shows the
These error messages may be caused by the WORM_KLEZ.E virus, or one of its variations.
Go to trendmicro.com and run their free online virus scan. It can take a couple of hours to run and you must be connected to the internet.
It that doesn't do it let me know.
Posted on Sep 11, 2010
  • 145 Answers
SOURCE: The application failed to initialize
wash disk,,,,wipe with lint free cloth,,, reinstall
Posted on Nov 25, 2010
The application failed to initialize properly (0xc0150002). click ok to terminate the application. yahoomessenger.exe - application error. the application failed to initialize properly(0xc0150002). click...
I'm having the same problem, not quite sure whether it is happending due to upgrade to IE 8 or Windows Installer 4.5 installation. Cleanup and re-install of Yahoo Messenger 10 won't help. The YahooMessenger.exe fails to initialize right during the installation process.
May 14, 2010 | Yahoo Messenger
I have a dell dimension 2400 with windows xp profewssional. When I try to turn the system on i get an isass.exe application error that says the application failed to initialize properly (oxc0000005). click...
if you have a window xp disk put it in start the machinfne and when it ask you to replace or repair windows you want to repair window xp hope this help .........................
Nov 23, 2009 | Dell Dimension 2400 PC Desktop
I have the same model and problem if installing from original CD on Windows XP (the driver is old and not for XP). The new XP driver will work.
Mar 25, 2009 | Genius ColorPage Vivid Pro Flatbed Scanner
Hpqthb08.exe and HPQDocViewer.exe error messages
****, since you have been having many issues, I guess that your windows is corrupted.
The best way to proced is to install a clean copy of Windows, install all of services packs and updates and then install the HP software and test the printer.
I know this is a lot of work, but it probably will solve this and many other problem that you are experiencing.
good luck!
Nov 24, 2008 | HP PSC 1510 All-In-One InkJet Printer
I am unable to do anything on my computer
you got virus, and Trojan on your laptop.
need to go buy a good antivirus software. i.e. symantec, McAfee, etc..........
ask the sales person in the store.
scan the laptop.
Nov 14, 2008 | Toshiba Computers & Internet
Three errors recently occuring, causing som problems
Try to remove that on the boot.ini on your system.
You can do that by following this.
1.Click Start>Run>type "msconfig" (without the "") then press enter, On the new window that will comes up that is the msconfig window.
2. uncheck the EABServ.exe on the startup or on the boot.ini. then click apply and restart. I'm not sure if the EABServ.exe is a virus or a malicious file that is not recognize by your antivirus but I know its not a microsoft application.
May 13, 2008 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
