Question about Vivitar ViviCam 3615 Digital Camera
Digital Camera I have a Vivitar digital camera and no matter what I do the flash will not work. I have tried all the settings ands still nothing.somebody help??
    Genius:
  • 2,985 Answers
Switch off camera remove batteries and leave for an hour or so. Replace batteries wet it as if you are going to use the flask and hold it to your ear. Can you hear a high pitched whine. if yeas then you have a processor fault or flash lamp fault If no then the Flash charge unit has died. If it is still under warranty that is the way to go. If not try Vivitar website for Technical help
Posted on May 22, 2007
Unable to get Vivitar 2800 on Canon XSI to work.
DANGER! Don't try it again!
That flash is an old fashioned thyrister flash intended for 35mm film cameras ONLY. The voltage which it passes through the foot contacts can fry digital camera circuitry.
It will not work with your camera, you must get a modern unit suited to digital cameras instead. If you're lucky, then your camera has been unharmed, but if not then you are looking at expensive and possibly uneconomical repairs which will not be covered by the warranty.
The 2800 is a great general purpose flash, but it's design pre-dated the widespread use of digital SLR's. Vivitar did release a digital-friendly version called the 2800D. You can use the 2800D on 35mm film cameras as well, but must not use the original 2800 on digital models.
Hopefully your camera is OK and you'll keep your flash well away from it..
Jun 21, 2011 | Cameras
How do i get the flash to work on my vivitar vivicam 5022 camera
Make sure you're not in the macro mode. There's a slide switch on the end of the camera, near the SD card slot. Set this switch to the mountain position.
Also bear in mind that the flash is only for still photos, not for videos.
Mar 08, 2010 | Vivitar ViviCam 5022 Digital Camera
How do I set vivitar 5199 to take close up photos of artwork? The flash in each flash setting spoils the photos and indoor photos without the flash some up AVI
this is a cheaper camera so most likley will not be able to do so. these cameras have trouble focusing up close. but its worth a try. You can go on to www.youtube.com to find instruction on how to make a home made diffuser for your flash from a milk jug. Hope this helps -Richard
Dec 28, 2009 | Vivitar ViviCam 3710 Digital Camera
Can the Vivitar 283 be used safely on Nikon Digital SLR Cameras?
I assume you're asking about the 283, not the DF-283 which is compatible with digital cameras.
As for the 283, yes, if you put an adapter such as the Wein Safe-Sync between the camera and the flash. Under no circumstances should the flash be mounted directly on the camera.
Nov 29, 2009 | Vivitar 283 Flash
I just got a vivitar camera and have tried ALL the setting its a x327 and It takes terrible pictures because it makes people like gost. I thought it was just the flash when I took pictures last night but I...
go into the menu of the camera and see if you have the back light on..or the over exposure setting on high. it has something to do with the settings. have you found the setting awb or oev... try different setting in the camera...or look thru the manual on settings
Nov 12, 2009 | Vivitar ViviCam 35 Digital Camera
Vivitar Vivicam 8400
The capacitor who charges the flash unit pop up and it needs replacement complete flash unit assembly, Contact any expert nearby to replace complete flash unit assembly.
Thanks for usinf fixya.
Nov 05, 2009 | Vivitar ViviCam 8400 Digital Camera
Flash wont work
i have a vivitar vivicam 3330 and i lost the C.D. to download my pictures on my computer. where can i get a new one??
Nov 22, 2007 | Vivitar ViviCam 3330 Digital Camera
Bright pictures
If this is in the normal modes, try the following.
Go to the set up or menu and reset all.. what you are doing is resetting all settings back to default or factory settings.
If the problem does not show at all in any of the menus or playback from a card, then the problem is more than likely a ccd problem of some kind. This problem may be fixed for free, not sure if Vivitar will fix, but worth a try to email or call them at:
Go to:
http://vivitar.com/en-us/Support.aspx
Ask for your model.
Oct 13, 2007 | Vivitar ViviCam 5100 Digital Camera
Can't turn on Vivitar 4345 digital camera
Searching google groups shows others with problems after attaching Vivitar cameras to PC's & then not working. The only fix seems to be leaving the battery out until the camera resets itself. If you can get to the setup menu then try the "default" option to reset the camera to factory settings.
Jul 22, 2007 | Vivitar ViviCam 4345 Digital Camera
Vivitar ViviCam 3615 Digital Camera Logo
27 people viewed this question
Top Vivitar Cameras Experts
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
