Question about American Standard Plumbing
How to install an american standard repair kit 3492-07 bath tub faucet
It is an old american standard bath tub faucet and I have the repair kit, but no instructions on how to install it, i have done many faucets but this one puzzles me.
  • 297 Answers
SOURCE: how to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
Posted on Jul 15, 2009
  • 297 Answers
SOURCE: American Standard single handle faucet
if it is 25 yrs old it might be to your favor to just replace the fixture.parts for something this old may be hard to find good luck.
Posted on Jul 29, 2009
  • 82 Answers
SOURCE: I just installed an american standard faucet
Silly question, but did you turn the shut offs back on after installing? If so, the aerator is probably clogged (the screen on the faucet). Unscrew it and clean it out. Good luck
Posted on Dec 31, 2009
wentlanv
  • 710 Answers
SOURCE: I have an american standard
The single handled faucets have a valve cartridge which needs to be replaced when it leaks. Disassemble the handle to find the valve inside. Take the valve to the hardware store to be sure you get the right one and reassemble. To disassemble, pop the cap off the lever, unscrew the single screw, then use slip-joint pliers to loosen the retainer nut. lift the cartridge out with pliers taking note of the direction of the notch at the top of the stem. Be sure to reassemble with the notch facing in the same direction. You should replace and lubricate the O-rings when you change the valve cartridge.
Since you have the numbers for that particular faucet, you might want to call around to find the cartridge first. Different models have different valves, so be sure yours is correct.
Posted on Feb 25, 2011
  • 27 Answers
SOURCE: american standard cadet shower faucet drips. originally made for tub faucet but tub faucet pluged.
sounds like one of the stems are leaking thru.
Posted on Mar 06, 2012
Does anyone have a video on how to install a 3s10h/c value kit in a bath tub faucet?
LOOK UP ON LINE UNDER 3S10H/C VALUE KIT FOR BATH TUB FAUCET. SEE IF THERE IS A MANUAL OR A TROUBLE SHOOTING PAGE.
Oct 11, 2014 | Delta Plumbing
I want to clean the jets in my tub they look mouldy
Cleaning your Tub
There are several options for cleaning the piping on a jetted bathtub.
The reason you have a residue on the bathtub surface when you are done bathing is because there is bacteria built up in the plumbing of the jetted tub. In order to remove that and reduce the amount of "yucky stuff" coming into the tub when using it, we recommend a regular usage of a jet cleaning product about once every couple of months
Here is a link at the bottom to the cleaning products I can find right now. There may be others out there that I am not aware of but I do know these products work well in all jetted bathtubs.
US Parts Center
Bath Parts Plus Bath Pump Spa Part Spa Accessories Powered by Network...
Feb 27, 2014 | American Standard 9330.014 Adhesive Bath...
Sunken bathtub
Is there are question in this somewhere?
May 04, 2013 | American Standard Hampton Two-Handle...
Odor coming from water in my home.
I have had this for no reason it smelt as you say The only thing is you may have disturbed the pipes Odd I know drives you mad , As you say a softener would do the trick . or maybe if your on a well , A well flush but they cost .
Mar 08, 2017 | American Standard Plumbing
Low water flow
buught sink taps same problem do they have flexy conectors with them. my problem was as they are american hot @ cold water suply are maines fed so hole in bottom of taps [or in flexy pipes are too small
May 17, 2009 | Danze D302521 Antioch Roman Tub Faucet...
Apr 22, 2009 | American Standard Reliant+ 4 In. Single...
I need the installations for a American Standard
I had a similar problem where the Drain-Kit that I ordered was missing a part. After contacting American Standard and requesting a schematic. I realized that the missing part was the rocker assembly with stopper. I have a PDF of the schematic that I can send you if you still need it. Let me know. The alternative is to contact American Standard directly between 8am and 6pm Eastern and request the information. The phone number is (800) 442-1902 Option 3 then 1 then 2. Tell the person that you need the installation instructions for a 1583.470.xxx universal bath drain.
Mar 03, 2009 | American Standard Plumbing
Plumbing Logo
1,352 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
