Question about Polaroid FLM-3734B 37 in. LCD HDTV
Polaroid Tv Repaired thank to you !!!! You are the MAN!!!
Hello. I wanted to let you know that I read your posting on the Polaroid FLM 373B and decided to give it a try since you did such a killer job of describing the process. 1/2 an hour later my TV was better than when I got it. YOU ROCK!!!!!! The parts to fix it were about $3.50 for the 2 caps. It was too easy to believe!!! Thnak you so so so so so much! You saved me from buying a new TV and a ton of headaches with Polaroid.
  • 2 more comments
  • auvico Jan 17, 2009
    Polaroid flm-373b lcd tv black screen with same problem. Took the advice and replaced the two each 1000mf caps with same value but 25v. Also had a 1000mf cap @35v that was found bad. Replaced with same value but 50v.
    Fired up fine. Did a "Default" to return to factory specs and channel scan.
    Works like new. Thanks for the help.
  • LoveyD Jan 20, 2009
    My Polaroid 37 inch flat screen tv makes a horrible humming noise and has vertical lines and no picture.
  • Anonymous Jan 29, 2009
    I had the same problem with no picture and used 35V caps from R.S. I actually found 3 caps that were bulging and replaced them all. Works great. Thanks again.
  • wolfleo66 Mar 31, 2009
    Count me in as well; the cable guy just left cause we thought it was the box they installed. I guess we were lucky because we've had ours for around 2 years with no problems.
    Thank you for the help, I was really glad to hear I can actually fix it for a lot less than the factory or a repair person would charge.
I had the same problem as everyone else. The blue light would come on, but no picture. We would have to unplug and reboot several times to get a picture. The quality of the picture was going bad as well. yesterday, it wouldn't turn on at all. We followed the advise and changed to two capacitors, plugged the tv in and it turned on without a problem!! (you could see the capacitators were buldging) We will see how long this will last, but hopefully will buy more time for us. (we have never soldered before, but thought we didn't have much to loose, and it wasn't that hard!) It took less than 30 minutes and under $20 to fix vs the minimum of $250 polaroid wanted to charge us. If there is a class action suit, count us in!!!
Posted on Mar 02, 2009
Had the same situation as others, powered on blue light but nothing else, then unplug multiple times to get a picture. Finally nothing would work. Replaced the capacitors as was suggested and everything is fine. Installed Radio Shack #272-1032 1000mf 35v in place of the original 10v
Posted on Jan 26, 2009
Tip
Polaroid FLX-374 Service Manual Download
Download Polaroid FLX-374 LCD HDTV Service Manual
Models: FLM-2632 / FLM-2632M / FLM-2634B / FLM-3232 / FLM-3232M
Models: FLM-323B / FLM-3234B / FLM-3732 / FLM-3732M / FLM-373B
Models: FLM-3734B / FLX-374
Have you misplaced your Polaroid FLX-374 LCD HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLX-374LCD HDTV Service Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Polaroid FLX-374 Manual Download
on May 01, 2010 | Polaroid FLX-374 37 in. LCD TV
I need help fixing a Polaroid FLM-3232 w/o power
I do not know what your problem is as you do not even describe a problem, but I dare say capacitors do not need to be bulged to be deffective.
Usually the ones closest to heat source are the ones to dry first; bulging can be result of a too strong current running through them too and not neccessarily related to heat.
Usually they are large and close to the connectors that carry power from the power board to other internal boards.
Other capacitors may also be affected, of course.
You can try your luck replacing them in order, bring the TV to a specialist or start reading the theory of repairing SMPS - you can find it online, an excellent read if you really want to get into it.
Nov 05, 2009 | Polaroid FLM-3232 Television
Tip
Download Polaroid FLX-374 LCD HDTV Manual
Have you misplaced your Polaroid FLX-374 LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLX-374 LCD HDTV Users Guide?
Follow this link
I hope that helps.
_____________________________________________
Tip
Polaroid FLM-373B Manual Download
Download Polaroid FLM-373B LCD HDTV Manual
Have you misplaced your Polaroid FLM-373B LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-373B LCD HDTV Users Guide?
Follow this link
I hope that helps.
Polaroid FLM-373B Service Manual Download
on May 01, 2010 | Televison & Video
Tip
Download Polaroid FLM-373B LCD HDTV Service Manual
Have you misplaced your Polaroid FLM-373B LCD HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-373BLCD HDTV Service Manual?
I hope that helps.
Tip
I hope that helps.
on May 01, 2010 | Polaroid FLM-323B Television
Tip
Follow this link
I hope that helps.
Polaroid FLM-3734B 37 in. LCD HDTV Logo
487 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
