Question about Emerson Heating & Cooling
Wiring problem - replacing old GE model 3AAT80B2A1 with white rodgers blue easy reader thermostat
SOURCE: Hunter 44100A programmable thermostat
Sorry Iasumed you had a heat pump t-stat. You will need to exchange to a heat pump t-stat
Posted on Sep 28, 2008
  • 61 Answers
SOURCE: Thermostat wiring
your best bet and where i would start is to identify where the coulors are conected at the fernace. in the industry we use standard wireing coulors wher green is g for fan and red is rh=switched trans power for heating . rc=switched transformer power for cooling . now normaly there is only one transormer so you would put a jumper from rc to rh and conect the red wire from the furnace to eather of these.jumper installed. the y is your cooling witch is normaly the yellow wire. o on the stat is for a heat pump if you nead to energize reversing valve in cooling mode . w is first stage heating and this can be conected to eather brown or white youll have to check at the furnace to see witch it is . the final wire eather brown or white should be conected to c or 24v common witch you didnt say you see on the thermostat. once again
red to rc and rh
green to g
yellow to y
brown or white to w
brown or white to common or c
please post feadback hope i was of help
Posted on Oct 21, 2008
peyton32034
  • 410 Answers
SOURCE: thermostat wiring goodman model aruf032-ooa-1b
is this a heat pump or straight cool with heat strips?
Posted on Mar 16, 2009
  • 38 Answers
SOURCE: trouble code "malf" on my white rodgers thermostat 1F89-211
you need a new thermostat
Posted on May 07, 2009
  • 127 Answers
SOURCE: a duo therm thermostat (p/n 3105058) was removed
a. Remove the cover of the thermostat.
b. Connect the RED wire from the air conditioner
to the “RC” terminal on the thermostat.
c. Connect the “YELLOW” wire from the air conditioner
to the “Y” terminal on the thermostat.
d. Connect the “BLUE” wire from the air conditioner
to the “H” terminal on the thermostat.
e. Connect the “ORANGE” wire from the air conditioner
to the “G” terminal on the thermostat.
f. Push the thermostat wires into hole in wall and
fill excess hole with insulation.
g. Mount thermostat base to the wall with screws
provided.
h. Check all thermostat wires on base to ensure
they are completely clear of the bimetal coil of
the thermostat. Adjust if necessary.
i. Replace thermostat cover.
If nothing operates on the air conditioner, remove the
return air grille assembly and verify the red, orange, yellow
and blue wires are properly connected (red-to-red,
orange-to-orange, etc.).
Next, disconnect the red wires and check for 12 volt
DC between the red wire from roof section and the orange
or blue wire from roof section. If no voltage received,
refer to Section F2. If voltage is received, the
problem lies with the thermostat or thermostat wires.
Next, disconnect all 4 wires (red, orange, yellow and
blue) from the thermostat. With the thermostat set on
COOL mode, FAN mode set on AUTO and HIGH, and
temperature selector set lower than the room temperature. Check for continuity between terminal RC (red wire)
and terminal G (orange wire); and RC (red wire) and
terminal H (blue wire). If continuity is achieved on each,
proceed with the next step.
Set fan switch to LOW. Continuity should NOT be present
between terminal RC and Terminal H, but present between
the other terminals (Y & G) and terminal RC.
If all of the previous checks are good, the thermostat is
good, do not replace it. If any one of the previous checks
are not correct, replace the thermostat.
Posted on Jun 29, 2009
How do I replace an old White Rodgers thermostat with new honeywell TH5220
The Orange wire for the reversing valve and used with a Heat Pump
If you have a heat pump, then yes. If you have a gas furnace then no. If you have a HP and the reversing valve is not connected, then you might just be using the emergency electric heat strips. :-o
Jul 21, 2014 | Honeywell Th5220d1003 Non-programmable...
I have a white rodgers 1F80-24 thermostat which has worked fine for years. Now all of a sudden the numbers and time on the display are all broken up making it hard to read. Any ideas on how to fix. Thanks
http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-5287rev_E.pdf
This is the manual for your thermostat. You probably just have bad batteries. If you pull your thermostat shell off you should see batteries in the shell or base, further, if you have a blue wire in the wires that hook to base, make sure it's connected. The unit could be bad but, they count on the batteries for display and memory.
May 30, 2011 | White Rodgers White-Rodgers 1F85RF-275...
I am replacing a White-Rodgers thermostat with a Hunter 44155C and dont know where to connect the wires. I have white, red, green, blue, and yellow wires and none are labeled as to what they are.
The Yellow wire is for cooling, the white is for heating, the red is for power, the green is for blower fan, the blue is your common wire, all you should have to do is color code the wires to the thermostat. The thermostat should have the colors labeled R,W1,G,Y,B or C for common if it's wired correctly at the Air Handler or evaporator. The blue wire should go to B, or C.
May 28, 2011 | Hunter Fan Company 5/1/1 Programmable...
NO DISPLAY ON UNIT
Pull your display off wall and see if your unit has batteries. If you have a blue wire or, a wire connected to the "B" terminal in your thermostat(the part connected to wall, this should produce the power to show display. If you do not have a blue wire, it is dependant on the batteries for display. Change out batteries and see what happens. Obviously with no display, your system won't work. If this doesn't solve your problem, replace the thermostat.
Apr 26, 2011 | White Rodgers White-Rodgers 1F85RF-275...
Replacing WHITE-RODGERS manual thermostat with 3 wires ( red, white, blue and installing Honeywell electronic thermostat RTH110B, how do I connect it? The heating is not central, baseboard heating.
I have only seen one Honeywell thermostat that would work with a 3-wire heating system.
I would replace it with a White-Rodgers 1F80-0471. They are about $100, but they are a good thermostat, and they work well with the 3-wire zone valves.
Most other thermostats have the "Y" terminal that you need, but do not control the zone valve correctly.
Helping Hands Services
- Fairbanks, Alaska -
Jan 30, 2010 | Honeywell Electronic Programmable...
Lookin for wiring instruction in replacing old buld typr Weathertron 3AAT86B!D1 with wiring as follow: Y-Yellow T-Brown B-Blue R-Pink W-White G-Green O-Orange X2-Black to be replace with White-Rodgers...
The best thing to do here is to verify the function of each wire. You may need to call the manufacturer of the old thermostat to have that information. Then cross that with the WR stat. If have difficulty you may call hometechline 18002842925.
Nov 26, 2009 | White Rodgers White-Rodgers 1F85RF-275...
Changing home thermostat
Couldn't find your thermostat based off the information you provided; find the model number and follow the link to the Contractor Support Page.
White-Rodgers Multi-Stage Thermostate Diagrams for Contractors
Nov 28, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Emerson Heating & Cooling Experts
Dan Webster
Dan Webster
jdthefixer
Tim Whalen
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
