Question about AudioBahn A12001DQ Car Audio Amplifier
Hi I have an audiobahn amp a18001dq that wont output sound but powers up. any ideas?
  • 15,935 Answers
One of the more confusing things with a car stereo can be when the amplifier goes into protection mode. One minute it's working and the next minute it's not. Here's a brief troubleshooting method that will hopefully help you if your amplifiers ever go into protection.
1. Try to determine the cause. Amp's can go into protection mode for several reasons. Knowing what happened before it cut out can help determine how to fix it. Did the amp not work as soon as it was turned on? Did it happen after blasting for hours (may be thermal overload and it needs to cool)? Did it cut out after you hit a bump (a wire connection may have come loose)?
2. Tear it down. Get the amp down to it's most basic state. Remove all of the speaker wiring and RCA wiring and leave only the power, ground and remote leads connected. If you still have a problem in this state then either your amp is defective or you may have an installation problem such as the amp touching metal.
Remember that an amplifier should only be connected to the vehicle through the power and ground terminals. Mounting the amplifier to the metal of the vehicle, including putting the mounting screws into metal, can cause problems for your amplifier. Always mount the amplifier to a non-conductive surface. An easy way to accomplish this is to mount the amplifier to a wood board and then mount the board to the vehicle.
3. If the amp is OK in this torn down state keep adding the other wires back on until you find what causes the problem. Add the RCA cables first. Then add the speaker wires one at a time. If the speaker wires cause the problem then they are probably touching metal. Check to make sure that a speaker wire isn't being pinched somewhere between the amp and the speaker. Also check that the speaker wire or speaker terminals aren't touching the vehicle metal near the speaker opening. Rear decks and door panels can easily touch unprotected speaker terminals if not properly installed.
If the problem starts occuring when you connect the subwoofer wires to the amplifier you may have your subwoofers wired at too low an impedence. First check the specs on your amplifier to make sure what kind of loads it is stable under. Then go here and check the wiring configuration to make sure that your load is not too low:
If you believe your amplifier is defective contact the manufacturer first. Many have flat repair rates that are very affordable and cover parts and labor. However local repair shops may be cheaper if it is just a small repair. Compare the manufacturer's repair rate to that of a local shop. If you don't know the reputation of the local shop it may be better to send it to the manufacturer who will have working knowledge of the amp and parts readily available.
Posted on Jan 05, 2009
  • blueextc3221
    blueextc3221 Jan 05, 2009
    Protection circuits are beyond the scope of this basic troubleshooting guide but I'll provide a basic introduction to them. In general, protection circuits are designed to prevent damage to the amplifier and, in some cases, they prevent damage to the speakers.
    • The most common protection circuit is the thermal shutdown circuit. It is designed to shut the amp down if it gets too hot.
    • Most amplifiers also have an over-current protection circuit. It's designed to shut the amp down if too much current is drawn from the speaker outputs or when there is an internal fault that causes excessive current draw.
    • Some amplifiers have DC offset protection. This prevents damage to the speakers in case the amp fails in a way that causes rail voltage to be driven to the speaker output terminals.
    • Over and under-voltage protection is employed in some amplifiers. If the B+ supply voltage is too high or too low, the amp will shut down.
    Any of these can shut the amp down. If there are no dedicated indicators to tell you which fault has caused the shutdown, you must determine which fault is causing the shutdown and then find the defective components. With a schematic, it's generally not too difficult. Without a schematic (many manufacturers won't provide schematics), it can be much tougher.
    There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause.
    If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure.
    Transistor Failure/Checking Transistors:
    In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals.
    I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit.
    If you aren’t competent and don’t know what you’re looking at inside the amplifier, please refer to a car audio technician for repair. Internal voltages can be lethal if not de-energized before starting the repair.
What would be the best size amp to purchase for two audiobahn aw1200 subwoofers and two pioneer 4-way 6"x9"?
First, I would purchase the amp based on the subwoofers alone. Allow unit power to run the 6x9's unless you are planning a intricate setup. Things to think about when buying your amplifier. Always get an amp that offers an RMS output of 25-30% greater than the combined RMS output of your subs. Also, the stability of the amp to handle ohms loads (1, 2, or 4 ohm stable). If you have two dual 4 ohm subs you can get a 2 channel 2 ohms stable amp, or a monoblock 1 ohm stable amp. This will get you the most power and sound for your buck. There are so many amplifiers out there at different price levels, it's really up to you. Hope this helps.
Sep 03, 2011 | AudioBahn AW1200 Car Subwoofer
I Have a audiobahn a1800dt its almost identical to this amp, i played it for a while with no problems, until i hooked up some crappy subs to it and it went into protection mode without comming out of it....
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . Please check speakers impedance A thumbs up would be greatly appreciated if this answer is helpful to you
Feb 03, 2011 | AudioBahn A18001DQ Car Audio Amplifier
Audiobahn 1800 watt amp has an error of LO and isn't working righ
you are not getting your amp enough volts try checking your ground or power cable
May 19, 2009 | AudioBahn A18001DQ Car Audio Amplifier
Audiobahn A6601T amp. Protection light on. No Sound output.
Disconnect all speakers from the unit and then switch it on. If the protection light is still on then the output stage in the amplifier is blown.
May 12, 2009 | AudioBahn A6601T Car Audio Amplifier
Audiobahn A4601T, only 1 audio channel works
Is it the same channel in both amps that produces output?
Have you tried all combinations of setting for the switches and pots on both amps?
Oct 25, 2008 | AudioBahn A4601T Car Audio Amplifier
AudioBahn A2300HCT no sound
Generally, if the amplifier smokes, the power supply FETs have failed.
Many times, the output transistors fail and that causes the power supply FETs to fail.
Audiobahn won't release schematics. The amplifiers are relatively simple and a schematic isn't generally required.
If you know how to check the transistors, check them to determine the severity of the damage. If you don't know how to check them, read through the following page following all links provided.
Basic Amplifier Repair
Let me know if you have any other questions.
Sep 04, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Wierd stopped working audiobahn a2300hct
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up normally, the wiring and speakers need to be checked. If it still shuts down, the amp likely has blown output transistors.
Apr 05, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Audiobahn A2502DP amp is alive but wont talk to me
Your "bumpin" may have killed the amps "bumpin" Was the amp secure when you were sliding? So wires are ok, and lights and finas running. You have power but no output..Check the settings on the amp, also the fuse. Something might be earthing itself to the amp as well.
Feb 14, 2008 | AudioBahn A2502DP Car Audio Amplifier
Audiobahn A2300HCt wont work
you might not have enough power pushing the amp.... I have two batteries and two caps running
Apr 02, 2007 | AudioBahn A2300HCT Car Audio Amplifier
AudioBahn A12001DQ Car Audio Amplifier Logo
363 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Nicholas Csorba Jr.
Colin Stickland
Colin Stickland
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
