Question about White Sewing Sewing Machines
Tension settings for white sewing machine - White Sewing Sewing Machines
clyde2j2
  • 137 Answers
SOURCE: TENSION SETTINGS
Try this URL.
www.managemyhome.com
Posted on Mar 02, 2009
bargainbox
  • 1388 Answers
SOURCE: tension
Bobbin Tension is too loose......probably thread/lint trapped in the spring tension of the bobbin case.
Check this tutorial for all things tension....
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Aug 02, 2009
SOURCE: sewing machine XL 5500 settings
Your bobbin is probably too loose. When you set a new bobbin, stop every now and then and try with your fingers nail if it's nice and tight enough. Not extremely tight, but tight, not loose and moves easily when you set your finger between the threads.
With most fabrics (99%) the plate is fine at the the top position, just with very thick and "fragile" (satins etc) you might need to adjust it.
Settings: Tightest tension for the thinnest materials, more loose for the thicker ones, better have a test piece, it rarely goes under 5 anyway.
Posted on Aug 25, 2009
mohammed387
  • 1952 Answers
SOURCE: Need to know how to set the tension to sew hems on
Re-thread the machine and make sure that the needle is in properly. The tension would not cause the thread to break.
If it is not working, what is the machine doing? Try re-threading the machine again, check the needle to make sure that it is in correctly. There are no set numbers for tension- it is a feel, push, pull. If you could e-mail me back with a better description of what the machine is doing or not doing,
Posted on Aug 31, 2009
bargainbox
  • 1388 Answers
SOURCE: tension adjustment
TOP THREAD TENSION:
BOBBIN TENSION:
TOP LOADER:
FRONT LOADER:
back properly.
OTHER ISSUES:
Best Wishes
Martyn
Bargain Box in Australia
Posted on Sep 10, 2009
Model 4075 white sewing machine problem with thread from bobbin
1. Replace thread with good thread. (Check by holding to light to see if there is fuzz).
2. Adjust the bobbin tension. The tension on top is set to three and the bobbin tension should be equal to this amount.
3. Replace needle.
4. Check the top tension with tension foot down to see if the thread can move or does it get stuck? If it gets stuck the tension control may need adjusted or cleaned.
5. Pull the bobbin thread above the throat plate and pull on the thread. It must have some tension but not get stuck.
TENSION TENSION TENSION IS THE PROBLEM!
Sep 30, 2016 | White Sewing Sewing Machines
Tension settings
Some general suggestion - not familiar with White. If you know where the tensioner is, take a scrap of relatively stiff cloth in a constrasting color to the thread to make it easier to see. A good stitch tension will look like a line of adjacent dashed on top and dash-dot-dash on the bottom. If you are seeing dash-dot-dash on top and Dash-dash on the bottom, the tension is too tight. If - usual case - the bottom has dash-loopyloop-dash, or worse, snags, the tension is too loose. Remember tension may need to be adjusted for thicker or thinner work.
Jan 20, 2014 | White Sewing 1418 Mechanical Sewing...
Upper tension dial on White sewing machine turns complete circles
try a top tension of 4 or if you have a automatic setting try that
if that doesn't help then the tension dial need to be checked
to see if some thing is wrong with it, it might need to be replaced
Sep 09, 2012 | White Sewing Sewing Machines
When i set my dials to the suggested settings the tension is still too loose what could be the problem?
suggested settings are just that.. suggestions.
tension can be affected by many things. cotton quality and thickness. material sewn. needle size.
if the tension is too loose, set the tension a little higher
Mar 02, 2011 | White Sewing Speedylock 1600 Mechanical...
Need setting numbers for tension control for regular stitching for white 2037
The thread tension is dictated by the fabric being sewn, the application and the thread itself, as well as the type of stitch being used. These unknown factors must be addressed.
Feb 27, 2011 | White Sewing 2037 Mechanical Sewing...
What should my tension be for my machine to run properly?
upper tension dial should be set at 4 or 5 any more and your bobbin case tension is off you can loose or tightenthe screw on the bobbin case but only do small turns
Jul 14, 2009 | White Sewing 1409 Mechanical Sewing...
What are the recommended tensions for a White 534 serger? I just need to get it back to basics -- little hands undid the settings and I don't have my book where I wrote down where the settings should be. ...
Your tension should be between 3-5 but all your dials need to be right around the same setting. Try them on 3 then go to 5 see what the difference is and then adjust accordingly.
Apr 20, 2009 | White Sewing 1300DE Sewing Machine
What numbers are the knobs supposed to be set on?
Flannel is a light - mid weight fabric. If your tension dial goes to 8 , set your tension between 3-5ish. Try that and just tweak it to either side to get a smooth stitch on either side of yhour fabric.
Apr 15, 2009 | White Sewing 1409 Mechanical Sewing...
Tension settings for a rolled edge
3 Needle
1-3 Upper
7-9 Lower
1-2 Stitch length
Tension .7
Stitch finger 7
Dec 10, 2008 | White Sewing Superlock 1934D Mechanical...
Keeps cutting the thread from inside the machine
Make sure all of your threads are in between the tension dials. Sounds that the machine isn't catching because of the tension. Good Luck
Apr 06, 2008 | White Sewing Speedylock 1600 Mechanical...
Sewing Machines Logo
76 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
