Question about Roper RAS8445KQ Top Load Washer
Washer won't stop filling
I replaced the cold water hose. When I turned the water back on the water just began to fill. The washer is in the stop position, but water continues to fill. My mom has the same issue with a Roper top loader. Her home uses water from a well. She had problems with the pump and had it replaced. After the pump was replaced some dirty water was pumping for a few days. That's when the problem started. The cold water stays on through all cycles and even when the machine is off. Does this mean that the mising valve must be replaced? Or can it be removed and cleaned?
Not sure about the model number
  • ballardr Jan 28, 2009
    Mom had someon fix the problem. The water inlet valve was full of mud. Was caused by her well water pump problems previously. The guy charged her $75.00 including the part. Not too bad, since my mom lives in the country. The guy had to drive 35 miles each way to get the part.
    Thanks for you helpful advice.
  • 3 Answers
For what it's worth ,you may have a faulty fill switch.
As the water fills the tub this switch will cut off the water at a predetermined level.
The switch sends power to a water shut off valve.
If the shut off valve does not receive power through the switch, then the water will continue to flow.
Posted on Jan 05, 2009
  • 530 Answers
If you can turn the washer off while it is still filling. and the water continues to enter the machine you have a bad inlet valve.
Do me a favor turn the washer to fill, with the washer still running unplug from the wall. If the water is still entering the unit you have a bad inlet valve
  • erica graber Jan 05, 2009
    No ususally you cannot clean the solinoids in the inlet valve. It needs to be replaced
I believe the water temp switch is bad. It will start filling on warm then stop if I put it on hot it will fill with cold water. I have cut the hot water off to achieve this but when it reaches rinse it...
it sounds to me that the hoses are connected to the machine incorrectly. Typically if the plumber ran the water lines behind washer correctly the hot pipe is on the left and the cold pipe is on the right sometimes thats backward and be determined by touching hoses while filling on warm setting and see which hose feels hot. On the back of washer they where they connect hot goes on the bottom and cold on top
Aug 08, 2011 | Estate ETW4400VQ Top Load Washer
Cold water fills very slowly
Turn off the water, remove the cold water hose at the back of the washer ... inside you will find a hose washer with a screen on it - remove and replace it. I believe you will discover the screen is clogged. While you have the hose disconnected, run some water into a bucket from the hose to clean it as well.
Jun 19, 2010 | Kenmore 24032\24036 Top Load Washer
Water pressure for Washer (rinse only)
you nead to turn off both cold and hot you nead to remove cold water hose from washer.remove screen and clean it and replace it.hookup cold water hose to washer and turn water back should have better pressure.your rince cycle is cold water.
Nov 18, 2009 | Kitchen Ranges
When my washer goes to fill on the rise cycle It just trinkels. I have to turn back to wash fill & then go back again
Your cold water valve is stopped up with sediment. Turn off the cold water. Unscrew the hose from the cold water side on the washer. Clean out the sediment screen in the washer water valve.
Nov 01, 2009 | GE Washing Machines
Washer stopped at the drain cycle Model LSR8233JQ1
Could be either a bad lid switch or a bad water valve.
Set the timer dial to SPIN and turn the machine on.
If it spins the lid switch is OK. If it does not spin the lid switch must be replaced.
Next,set the timer dial on a wash cycle and set the water temperature knob to COLD water. If it fills,the lid switch is bad. If it does not fill the water valve is bad or the cold screen filter is clogged.
If the COLD does not fill,turn off the cold water faucet. Remove the cold water hose from the machine water valve and check for a clooged screen.
If it does not fill with COLD water and the screen is clear,replace the water valve.
Oct 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
Cold water enters washer very slowly
First - check the water inlet hose screen for calcium or rust build-up.
If cold water is filling slowly, take these steps:
  1. Unplug the washer.
  2. Turn off the cold water supply faucet.
  3. Remove the fill hose connected to the back of the washer.
  4. Checkthe fill screen on the cold water inlet valve for debris or depositsthat can restrict the water flow. If necessary, you can carefully pullthe screen out and clean it. Flush the inlet thoroughly and replace thescreen. NOTE: If debris makes it past this screen, it can cause thevalve to leak and cause a flood in your laundry room. Monitor thewasher for this type of problem is you pull the screen out and clean it.
  5. Placethe end of the hose in a bucket and briefly turn on the faucet to checkfor proper pressure and flow from the cold water hose. If waterpressure from the cold inlet water hose is bad, check the hose forclogs. If the hose is okay, then I recommend calling a plumber to checkthe water supply to your washer cold water faucet.
  6. If the above checks do not help you resolve the fill problem, you will likely need to replace the inlet fill valve.
Your cold water fill valve (mixer valve) solenoid has failed if after cleaning - the condition remains.
CLICK HERE for a replacement part.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 24, 2009 | Roper RAS8445KQ Top Load Washer
The mixing valve that is part of the connector where the hose is attached has either failed or is disconnected electrically.
These are simple to replace and not too expensive.
You may have gotten some debris into the valve assembly which is being held open and is a sealed device.
If this is the case, it will probably not be removable since the valve is trying to close and will only open if voltage is applied.
Aug 24, 2008 | Frigidaire CWS3600AS Top Load Washer
Cold Water runs constantly even if the washer is off
you will need to replace fill valve where hoses connect probably has sand in valve especially if screens have been removed remove screws in rear of console lift and roll console back disconnect wire to lid switch remove clips om right and left rear corners cabinet lifts off disconnect hoses and wires 1 screw usually holds valve in postion
May 01, 2008 | Whirlpool Ultimate Care II GSW9650LW Top...
Washer filling up improperly
Well its definately not your water level switch, so that only leaves your water fill valve at the back of the washer, the cold valve is stuck open by debris. hope this helps
May 18, 2007 | Whirlpool LSR5132PQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
319 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
