Question about Lexmark X5470 All-In-One InkJet Printer
Computer can't send item to be printed to printer
When I try to send item to be printed it says it cannot find printer.
I tried to uninstall printer but it will not let me it says that there is
a printing item going and cannot uninstall until printing is completed.
  • francis436 May 11, 2010
    x5400 when i try to print it say cant find printer
    Sergeant:
    Scholar:
  • 199 Answers
The delete the pending prints from the print que option aND then uninstall it will get uninstalled easily. thanks.
Posted on Jan 05, 2009
The other day I was trying to print an account from a bank. I deleted the page I thought, but my printer continues to show the item as being deleted, but meanwhile the printer is not printing anything and...
For that you need to uninstall old printer driver and all usb drivers.
First make sure your usb cable working fine.
Try it in different usb ports.
if still same then uninstall usb driver from device manager.
Right click on my computer icon then click on property then hardware->device manager.
Then you can see all driver list then uninstall usb drivers 1 by 1 then it install all usb drivers automatic.
Then go to control panel->add remove programs uninstall printer driver.
Then reinstall printer driver from disk or download driver from internet.Then install..
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 08, 2010 | Office Equipment & Supplies
My dell v305 printer won't print. commumition problem. I have done everything to try and solve problem. help
hi there!
-you need to uninstall and reinstall the program of the printer, if you have already done it. you may try the step below but it will still ask you to uninstall the printer software.
You can try these steps:
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software 5.Delete any items under the ff keys: NOTE: Be Exact on the File Directory ! HKLM = Hkey Local Machine -Click Start then type REGEDIT then press Enter -Delete any items under HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press . The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
Oct 24, 2009 | Dell V305w All-In-One R840635AU InkJet...
It will not print... I have reloaded the software,reinstalled the printer ,checked all of the drivers... It will receive and send a fax,however can't get it to print... The P/C does see the printer...
hi newprop1949,
you can try these steps:
4.Uninstall the printer driver and software, then unplug the usb cable.
Optional***
BJ Language Monitor
Local Port
USB Monitor
NOTE: DON'T DO THESE STEPS IF YOU HAVE ANOTHER PRINTER INSTALLED ON THE COMPUTER. JUST RESTART THE COMPUTER.
From the start search box type spool and press.
LexBce Server
Print Spooler
just update me if the issue is not yet resolved.
Oct 19, 2009 | Dell 926 All-In-One InkJet Printer
I send a document to print but it does not print, howver if a request it to scan it does it what do I need to do? in one occassion it told me that it was not set to work in a USB port but indeed it is my...
Hi melocoton777,
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software, then unplug the usb cable. 5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press. NOTE: IF YOU HAVE OTHER PRINTER INSTALLED ON THE COMPUTER DON'T RENAME THE W32X86 FOLDER. JUST PROCEED WITH RESTARTING WITH THE COMPUTER;
just send me an update if the issue would be same.
Oct 18, 2009 | Dell 922 All-In-One InkJet Printer
Dell 926 does not print...."communications with computer and printer not present"....tried reinstalling driver....no luck....Jeff
hi jeffhup,
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
Oct 11, 2009 | Dell 926 All-In-One InkJet Printer
Printer can't communicate with computer
Hi rcamp3,
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
Oct 05, 2009 | Dell 924 All-in-One InkJet Printer
Scans stop at 99% and make the entire prog (all in one software)not responding as well as printer freezes between a double sides printing (after finishing the pages on one side)
You've tried to uninstall and reinstall the printer driver of your printer. But still no luck. The printer still won't print. Or it would say printing but it won't finish printing.
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
good luck :)
http://tinyurl.com/yddyuw6
Sep 24, 2009 | Dell 926 All-In-One InkJet Printer
Prints pages with no words but symbols
Print test page from the printer. This prints fine? Then anytime a printer prints gibberish versus what you were trying to print from the computer means you should try one of two things. Download the most recent drivers from the products support site, install these. Be sure to uninstall the old drivers first. Another item that can cause gibberish print is a bad cable. Swapping out with a known good could solve the whole problem.
Print test page from the printer. This does not print fine? Then you are looking at something wrong with the printer. The cable and drivers would not be the cause because the only piece of equipment involved at this point is the printer. First step I would try in solving this. Download and update the firmware from the support site. If this does not work, then you may have a defunct printer. If you are under warranty, contact Dell tech support.
Mar 12, 2009 | Dell 1600n All-In-One Laser Printer
My Dell computer does not communicate with my printer
hi there,
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
have a great day.
you can check this link for complete info.
Jan 30, 2009 | Dell 946 All-In-One InkJet Printer
Can not print at all. Tried command prompt, test page, status of printer is online also checked printer port and restarting both printer and computer,etc; I'm still unable to print. printer does not...
Not that it is a help for your problem but the file name should be PSW_RE.DLL - a dot belongs before the '.DLL'
If you haven't tried it yet, delete the printer from the 'Printers and Faxes' folder in the Control Panel, make sure the printer is connected and turned on, then reboot the computer.
This will force Windows to reinstall drivers for it and should return functions.
Aug 20, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
