My Windows Media Player 10 or 11 Everytime I open it up it causes an error that says Windows Media Player has encountered a problem and needs to close
I have e samsung YP-u3 and no have mediaplayer 10.
I need this software do yoy want help mi?
Posted on Aug 09, 2009
    Sergeant:
    Scholar:
  • 199 Answers
Delete the media player software and reload it as this 1 which you have loaded must not be loaded perfectly.also try to load mediaplayer --8 or 9 instead of 10 ,11 as your operating system must not be supporting this.
Posted on Jan 05, 2009
Problem with Microsoft Digital image 2006 Windows media Player has encountered a problem and meeds to close. We are sorry for the incomvenience. Error Sig. App.Mane: wmplayer.exe Appver: 10.0.0.3646...
The error is a Windows Media Player error, and it looks like you are running an older unpatched version. Try to download a newer version of Windows Media Player from here:
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
I know MS discontinued their Digital Image Suite and encouraged people to switch over to the free Windows Live Photo Gallery:
http://explore.live.com/windows-live-photo-gallery?os=other
Mar 23, 2011 | Microsoft Digital Image Suite 2006 for PC
How do i fix error code C00D11B1 Media player 11 ?
Recognizing and Fixing Media Player Error Code c00d11b1
For the majority of Windows Media Player users who encounter the Media Player Error code c00d11b1 message, the problem only begins after they upgraded to 11. In other words, media player versions 9 and 10 worked perfectly well for them.
So, one option is to 'roll back' the player to a previous model that did not encounter any such problems.
To do this, initially go to Start, then Control Panel, and Add/Remove Programs. Next, click on the Windows Media Player 11 icon and click Uninstall.
It will ask if this is really the option you want to take. Confirm that it is, and then be patient as it may take several minutes for the operation to be completed. During this time, it may appear as if your PC has switched itself off, but it has simply deactivated all unnecessary extraneous computer operations, in order to retain memory and processing power for the job in hand.
Next, according to Microsoft, when this particular error code is encountered when trying to stream online video or audio, it most commonly indicates that the proxy settings for Windows Media Player are incorrectly configured.
This can be checked from the Tools menu within Media Player itself, after whch you need to click on Options. Then you must click the Network tab and in the Streaming proxy settings area, you need to verify your settings. If you're not sure what the correct settings are, first, click on Configure, and then in the Configure Protocol dialog box, select Autodetect proxy settings.
In some cases, you can also apparently encounter this problem if Media Player tries to receive an online stream by using the User Datagram Protocol (UDP), but for some reason, it cannot do so.
You may be able to fix this particular error by turning off this UDP option in the Player.
If these solutions are not effective, your problem may be something as simple as Media Player trying to access the wrong audio or video device on your machine.
Open Tools, select Options, and then select Devices. When this comes up, make sure that the correct audio for your PC is checked, and this could very well make your problem disappear.
If none of these operations is effective, then you may well need to check the underlying registry of your Windows operating system for defects and errors that may be causing Media Player to malfunction.
Almost inevitably you will find errors and defects in your registry whenever you run a thorough scan, and whilst it may not necessarily be possible to isolate a specific problem that is causing Media Player to malfunction, the cumulative effect could be the root cause of your difficulties.
If, therefore, you already have software installed on your machine that can scan and fix your registry for you, then you should use it.
If not, you can still avail yourself of a free online registry scan using proprietary software such as SpeedyPC. Whilst you will not be able to repair your registry errors without downloading and installing the full version of the software, nevertheless, the scan will indicate the extent of the problems that you have, and these problems may be what is causing you difficulties with Media Player.
Or download this software after downloading, install this software and try vlc media player. This will install (codec) compressor/decompressor for audio and video more supported multimedia.
Nov 18, 2010 | Computers & Internet
New computer dell inspiron 570 running windows 7-connected for 3 days. came back to use it this afternoon and the media player has lost it's sound and you can hardly hear the PC -the system tells me =media...
Microsoft Windows Media Player is a free media player software that comes with the personal computer version of Windows operating systems. The software supports basic file formats such as WMV, WMA, AVI, MP3, and ASF. The player included in Windows XP gives you the power to create your own CDs, search and organize digital media on your PC, and copy files to portable devices such as CDs and pen drives.
Fix Windows Media Player Problems
Corrupted and missing DLLs files, incorrect registry entries, and outdated files are some of the causes of Windows Media Player errors. Covered here are a few steps that you can take to fix common problems.
C00D11CD: Unknown Error
C00D11CD errors occur when an operating system component or some other program encounters an error and does not communicate it to Windows Media Player. Due to its generic nature and multiple reasons for occurrence, there is no specific solution to this problem.
If you encounter the error when trying to play an AVI or MPEG 2 file, then most likely, you do not have the correct codec version installed on your system. To fix a Windows Media Player problem related to codec, search for the required codec on the Internet, download it, and update it on your system to play the required file.
Windows Media Player uses Digital Rights Management (DRM) to authorize copying files to a CD or to download them from an online music store. If you do not have DRM authority to copy a particular song, you will not be able to play it and the error will pop up.
Windows Media Player uses the wmadmoe.dll file to encode files. If something goes wrong with this file, you may get the c00d11cd error when you try to copy songs from a CD to your hard disk. To fix a Windows Media Player problem in this situation, you must register the DLL file by running the command ‘regsvr32 wmadmoe.dll’.
80040155: Interface Not Registered
If this error occurs when you try to burn songs into a CD, then the most probable cause is that the required player files are no longer registered on your system. To fix this error, try to reinstall your Windows Media Player or download and install a newer version of the player, if available on the internet.
800C2EE2: Action timed out
This error occurs when your Windows Media Player is unable to connect to a server due to problem in the network, and therefore cannot play protected audio/video files that you download from an online music store. Incorrect Internet Explorer security settings might be the cause of this problem. To fix this, open Internet Explorer and select Tools-Internet Options-LAN Settings. Next, clear the Automatically detect settings check box.
C00D0FAA: Cannot rip the files
The error usually occurs when you try to rip CDs to MP3 format. Existence of entries from an earlier player version in the registry might be the reason behind this problem. One way to fix this problem is by adjusting the audio quality. However, if you want to maintain the audio quality, then to fix this Windows Media Player problem, open the Registry Editor by running the Regedit command and navigate to the subkey given below.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MediaPlayer\Sett ings\MP3Encoding
Here, open ‘LowrateSample’ and delete the value displayed in the Value Data box. Select OK and exit Registry Editor.
Many times errors also occur when there are corrupt files on the system or there are invalid DLL entries and other related incorrect entries in the system registry. For this, you must try to download reliable registry cleaner software from the Internet and scan your registry for invalid entries. Using registry cleaner software, you can easily and efficiently fix Windows registry problems, and make your PC free from irritating errors.
Errors can occur in Windows Media Player due to outdated files, missing or corrupt DLL files and incorrect registry entries. Most of the time, you can fix Windows Media Player problems by updating missing files or by upgrading the player to a later version. Additionally, to prevent registry-related problems, you can use a registry cleaner software to regularly scan the registry and eliminate invalid DLL entries and corrupt values from it.
Mar 06, 2010 | Computers & Internet
I can't get my music from my computer to my player.I have tons of music on my computer and everytime I try to sync my music to my player, my computer tells me that windows media player has encountered a...
I kept trying to get my music on to my player. I messed around and found a website that told me I needed to update my windows media player. So I downloaded the new version of windows media player. I went from media player 10 to the new 11. Now low and behold the new media player organized my music and told me what to do when I plugged in my player. Thank you, but I don't need any more help at this time.
May 28, 2009 | Philips GoGear Flash MP3 Player
Windows media player error message
Options:
1. Restore your system to an earlier time.
2. Re install media player on control panel add remove programs uncheck and recheck media player on add/remove windows components and click next... then re-start your system.
3. Download your version of Media Player or an upgraded one from Microsoft and install it.
Apr 25, 2009 | Microsoft Windows Media Player
My GoGear won't synchronize with Windows Media Player 11
You have to update the firmware on that particular player to make it compatible with Windows Media Player 11. Grab the latest version of the Philips Device Manager from Philips website, install it, open it, and click the "Update" button. It will erase all your songs in the process, but then your player will be fixed, and you can move on.
-Tha Mp3 Doctor
Mar 01, 2009 | Philips GOGEAR SA6045 MP3 Player
My MP3 Player is saying system disk err
use your computer to remove the files, and put 'em back on with windows media player.with another program open, you should have windows media player open and use it to put 'em on.Limewire and internet syncing sites usually stink.
Feb 18, 2009 | Nextar MA933A MP3 Player
You can not play WMV or ASF media on a website with Internet Explorer's Media Bar turned on. Internet Explorer has its own player for the Media Bar. To get around the c00d11cd error being generated you need to turn the Media Bar off. To disable Internet Explorer's (version 6) Media Bar click the Media button on the main Toolbar, then click "Media Options" in the new pane that opens. Now select "settings", and then un check "Play web media in the bar".
There is no need to restart your machine as this will take effect immediately.
You have a "playlist" on your PC that you are trying to copy to a CD-R. When you hit the copy button it goes straight to the c00d11cd error!
The most likely cause is DRM. Check the songs on your "playlist" to see if any of the content protected. To do this simply "right click" on each song, then select the "license tab". If any of the songs are protected then you can NOT copy them without the appropriate DRM authority. (DRM = Digital Rights Management) You will need to check with the site you purchased from to see the level of DRM used.
You have a "playlist" on your PC that you are trying to copy to another computer. When you try and play on the new computer it goes straight to the c00d11cd error!
The most likely cause is DRM. (DRM = Digital Rights Management)
It is likely you purchased and downloaded from a site Like Walmart.com Online stores like these set restrictions on what you can do with the .WMA files you download. It is likely that the DRM licence for your download restricts you copying to another PC. You will need to check with the site you purchased from to see the level of DRM used.
You can not copy songs from a CD in the CD drive to your hard disk. Windows Media Player generates the c00d11cd error.
The most likely cause is that something has gone wrong with the special file responsible for the "encoding". The name of the file is: wmadmoe.dll
The first thing we need to do is re-register this file with Windows XP To do this go to the "Start Menu" and select "Run". Now type in the following: regsvr32 wmadmoe.dll
If this does not work then the file itself may be corrupt. To fix this go to the "Start Menu" again and select "Run". Now type in the following: sfc /scannow
This will now scan your XP machine to see if there are any corrupt system files. If there are any then XP will prompt you for the XP CD so it can get a new copy... This may help you resolve the c00d11cd error.
This will get you up and running again, however due to some underlying problems with your installation you may actually need to re-install Windows Media Player.
Please rate this fixya
Jan 25, 2009 | Microsoft Windows Media Player
Error when I try to use Windows Media Player 10 or 11
This error is generally the result of a corrupt or missing Custsat.dll file, usually located in the C:Program FilesWindows Media Player folder.To workaround this problem:
1. Remove the current Windows Media Player 10 install.
2. Download and install
Windows Media Player 11 for Windows Vista
or
wm_tn_wmp11xp.jpgDownload Player 11 for Windows XP
I tend to use VLC Player, as it plays everything I throw at it..
Hope this helps
Chris (ziraffa)
Jan 05, 2009 | Microsoft Windows Media Player
Error on Media Player
I had the same thing happen to me when I installed the copy of windows media player that came with the player, I downloaded wmp10 off the internet and started again and then it worked.
Sep 05, 2006 | iRiver H10 MP3 Player
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
