Question about Samsung Office Equipment & Supplies
Samsung clp300 shadow
Shadow printed
Soulvisitor
  • 1113 Answers
SOURCE: printouts with shadow
Two things - Fuser or cartridge - stop print halfway in machine, if fault occurs before paper has gone threw the fuser then it is a faulty cartridge, if print is ok before fuser (the hot bit at rear) but gets doubled up after fuser then the hear roller in fuser are faulty change fuser....but 95 % of the time it is due to dodgy refill cartridge or worn cartridge (the rubber blade inside cartridge fails to apply enough pressure against drum to clean away old image  hence duplicating itself onto your nice clean paper! Try a known good cartridge if in doubt..
Posted on Oct 16, 2007
SOURCE: Images are unclear
if you are good at taking things apart and not destroying them, then the problem can usually be fixed easily.
Remove the ink carts.
on either side of the carrage there is a screw, remove both of them.
CAREFULLY slide out the silver bar those screws are holding. Be sure to note its orentation for putting the thing back in later.
also carefully remove the silver "fingers".
remove the black clip/cover on the right side of the carrage that covers the ribbon cables.
lift the head (you see 4 nipples in there-- that is the top of the head assembly)
gently pull out the ribbon cables.
on the bottom of the head is 2 screws, remove them
now the head will come into 4 parts. Nipples, Gasket, nozzle block, and a metal guard.
get some windex with amonia.
soak the parts for a day or 2.
blot dry, then let it set for atleast 2 days to be sure it is COMPLETELY dry.
reassemble, charge the ink, do the printers head cleaning, and boom. back in business.
this works 90% of the time
Posted on Feb 09, 2008
  • 5 Answers
SOURCE: "shadow" print on letterhead and envelopes
CLEAN YOUR DRUM WITH COTTON SWAB. (AND BLOW OUT PRINTER1.gif IF YOUR DARING.)
Posted on Feb 14, 2008
printech
  • 159 Answers
SOURCE: printing color shadow
did you used a combat able cartridge ? if yes the ink is the problem if no the problem is firmware
Posted on Sep 04, 2008
  • 4 Answers
SOURCE: black printing faded although toner not low
metering blade is gunked up. You need to dissasemble part of the imaging unit to fix the problem. Clean it. put it back together and BINGO! Like new. Do this before throwing money into buying a new imaging unit.. You can thank me when this works
Posted on Dec 23, 2009
Samsung clp 315 printing shadow images
Ghosting appears often because of bad toner. If cartridges have been refilled, they have wrong toner in them. If drum has worn out it will usually tell you. All parts for this machine cost too much. If toner is not the problem, probably best to get a new machine rather than pay to get it fixed. Brothers are cheaper to run.
Sep 01, 2014 | Samsung CLP 315 Laser Printer
How to remove baffles from a 2004 honda shadow aero@
Hi, Bernie for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2013 Honda Shadow Aero 750cc Remove Baffles
Punched baffle Honda shadow aero
Honda 1998 VT750C Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C 2005 Shadow Aero Owner Manual
Oct 21, 2012 | 2004 Honda VT 750 Shadow Aero
Samsung CLP-310 printer shadow printing on second half of page
I would check that the tension between your fusing rollers is ok as the toner will come off the paper and than return back to paper on its next revolution causing a faint image further down the page
May 19, 2012 | Samsung CLP 310 Laser Printer
1999 Honda VT 1100 C3 Shadow Aero speedometer not working
Hi, Greg and the usual suspects are:
1. Contaminated or faulty speed sensor.
2. Faulty turn signal module.
2. Corroded, broken or loose connector pins/sockets in the wire harness between the speedometer and the ECM or TSSM and the sensor.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
speedometer problem
Speedometer Not Working
1997 2003 SHADOW 1100 SHADOW SPIRT VT1100C SHADOW ACE TOU1997 2003 SHADOW... $15
Honda 1999 Shadow Aero VT1100C3 Owner Manual
Oct 19, 2011 | 1999 Honda VT 1100 C3 Shadow Aero
Samsung CLP300 jams when normally printing, but will print test
If you are using a 6cm paper to print that is smaller than a A4 size paper.
do a check when you print did you select the correct paper size. as wrong paper size is print will course paper jam too.
Apr 08, 2010 | Samsung CLP 300 Laser Printer
Sharp AR 5320 printing a shadow copy
Shadow images may caused by several things :
1. Deformed rubber of the cleaning blade,
2. Drum aging,
3. Upper heater roller aging.
Jun 22, 2009 | Sharp Office Equipment & Supplies
Shadow print from 2200d laser printer
This shadow, or backgrounding, is generally caused by excess debris remaining on the drum. This is mostly caused by the wiper blade not dislodging all the waste toner. You will need to replace the cartridge (C4096A).
Mar 22, 2009 | HP LaserJet 2200D Printer
Printing color shadow
Sep 04, 2008 | HP Color LaserJet 2600n Printer
63 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
