Question about Frigidaire MWS939Z Top Load Washer
Frigidaire GLW1749AS4 leaking into tub - Frigidaire MWS939Z Top Load Washer
2 Suggested Answers
  • 12 Answers
SOURCE: Leaking Frigidaire FWS445RF
First suggestion,
if your not qualified to do this, i'd suggest you take it to a service center.
Removing the tub requires specialty tools, and adjustments that are crucial to working properly. It can actually be leaking from somewhere else. This can also be quite expensive, as most repairmen will not replace old parts once they are disassembled. Please weigh the cost of replacement, vs. fixing this one. If you decide to tackle this job yourself, get a manual. http://laundry.manualsonline.com
Good luck..
Jay
Posted on Oct 04, 2009
Error code 13. Turned water on to machine and it leaked.
Try this link
it says the following:
E13 Condition Water leak in the tub or air leak in pressure-switch air hose Check/Repair The washer fills for too long without the water level pressure switch tripping to indicate that the washer is full. Check for a leak in the wash tub. If the tub is not leaking, check to see if the washer is overfilling. If it is, check the air hose and water-level pressure switch for problems.
Shop Parts Outer wash tub, Air hose, Water-level pressure switch
Frigidaire Front Load Washer Error Codes Sears PartsDirect
Jun 09, 2015 | Frigidaire Washing Machines
Tub fill line leaking
Good Afternoon Friend,
I understand that the washer on your Frigidaire laundry center, model# FEX831CS, is leaking at the back of your appliance. I also see that the dryer is in the way of accessing the line that is leaking. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to change the line with ease. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire disherwasher leaking water
It could leak from a coupleof areas. Door gasket, door tabs at bottom of tub opening, leaking pumps. I hope it is the gaskets as they are fairly cheap if it is the pumps they are expensive but easily replaced. Good luck
May 03, 2014 | Frigidaire Dishwashers
Fdb1050rec1 frigidaire dishwasher door leak
I think you most likely have a basin Float water level sensor that is no working correctly, the door seal is not water proof, if the water level gets over the lip of the basin it will leak on the floor.
May 01, 2017 | Frigidaire Dishwashers
First suggestion,
Good luck..
Jay
Oct 04, 2009 | Frigidaire FWS445RF
I have Frigidaire front loading. During the spin
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Apr 03, 2009 | Frigidaire Washing Machines
Frigidaire washing machine top load. troubleshoot
There are levelers at the corners of the unit for levelng - tubs have springs attached to them for righting the tub while working (spinning, agitating) - also if the clothes are evenly distrbuted in tub it will wobble badly during operation.
Leaking is usually from the drain pump especially from the point whwere the hose is attached to the pump
Regards
Sep 20, 2008 | Frigidaire CWS3600AS Top Load Washer
Leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Mar 01, 2008 | Frigidaire GLWS1233A Top Load Washer
Frigidaire MWS939Z Top Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
