Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Filter location I have a zenith e44w46lcd Tv I heard there is 2 filters I know of the one on the back where the fan is I make sure that is cleaned weekly but i heard there is one on the bottom is that true
    Problem Solver:
  • 17 Answers
No. Only one for customer to worry about.
Posted on Jan 07, 2009
  • Jason Swedenskey
    Jason Swedenskey Jan 18, 2009
    You also can take your filter, clean it, add a dryer sheet to the filter for 2 things:
    #1. your set will have better filteration without restricting too much airflow.
    #2, if your married, your wife will thank you for the scent your TV will be giving off into the living room. :)
Zenith E44W46LCD TV power/operation indicator lamp blinks green then goes red when power switch pressed. I can hear the fan motor but no picture. No history of lamp indicator warning.
If the tv projection lamp already been inside the tv now like a 1 1/2 or 2 years?Tv used it every day like 4 or 5 hrs every days?Yes?Than it is the tv projection lamp have to be replace,because the tv projection lamp life span have ended.
Sep 04, 2011 | Zenith E44W46LCD 44" Rear Projection...
My tv just displayed a temperature to high message what does it mean...i just cleaned the filter Thanks
Clean the interior with some canned air. Make sure it has adequate ventilation. If it does it again after that, you've got a board going bad.
Jul 07, 2011 | Zenith E44W46LCD 44" Rear Projection...
I get a message stating that the tv is overheating and eventually turns itself off. What needs to be replaced?
The problem could be that the filter on the back of the TV needs to be cleaned. Remove the pop out door and clean the foam filter. Do not get it wet, just use the vaccum or blow the dirt out. There is a fan behind the filter, so any dust and pet dander is filtered before the air is sucked into your unit. I make it a habit to clean mine every 6 months. I'd do it more often if your house is in a dry dusty location.
Sep 10, 2010 | Zenith E44W46LCD 44" Rear Projection...
Yellow circle
The huge yellow circle is either your blue filter is burnt out (very common in Zenith DLP) or you LCD cube is bad. I would bet it is the blue filter. Zeniths DLPs have 3 color filters one blue (a pinkish color), one green (a grayish brown)and one red (it is red). For the bulb indicator I would check and make sure your lamp is seated to the ballast correctly. Just take it out and put it back in.
Mar 24, 2008 | Zenith E44W46LCD 44" Rear Projection...
Lamp
it is located on the lower right side of the television
Mar 18, 2008 | Zenith E44W46LCD 44" Rear Projection...
Cooling fan problem
I had this problem and just turned off the TV and let it cool down. (You should unplug it before opening anyting). I opened the cover over the fan (on the back, near bottom center) and took out the filter. I washed off the filter, made sure it was good and dry, put it back in and turned the TV back on. The filter was quite dirty. I have not had a temperature problem since.
Oct 03, 2007 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD Lamp Access Door Location
I found the location to get at the lamp. If you are loking at the front of the TV there is a small panel at the bottom of the right end. Two screws, remove panel, two screws inside and a small handle that lifts so you can slide the unit out. 4 screws on top of the cage that the lamp sits in, carefully slide up the silver bracket holding the bulb, be careful the edges are sharp. Remove the bulb from bracket and remove the 2 cables attached to the bulb. Now just do the same but in reverse. Make sure you wear plastic gloves that should be provided because if your fingers touch the lense you could be out the price of the lamp.
Aug 31, 2007 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
87 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
