Question about Kenmore Washing Machines
Machine will wash but not spin or drain-Kenmore series 80
The machine will work on wash cycle but will not drain rinse or spin.
  • elrmiller Jan 05, 2009
    Thanks egraber, you were 100% correct. I appreciate you getting back to me right away. I checked the lid switch and it had broke off.
  • 530 Answers
Hello, Is the washer completly stopping? at the drain and spin cycle? If so you probably have a bad lid switch
Posted on Jan 05, 2009
  • erica graber Jan 05, 2009
    usually if the pump is bad it will make a humming sound. is it makeing a humming sound? If not and is completly dead. check your lid switch.
    you are very welcome I am glad to help :)
  • 115 Answers
Needs a new drain pump you can replace it easily by leaning the washer back at a 45 degree angle then right at the front panel you will see the 2 hoses hooked up on the drain pump there is a clip on top and bottom of it unclip them and slide the pump off the motor shaft then undo the hoses and do in reverse order to replace and please rate me
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Kenmore series 80 washer won't drain after wash cycle
Try the 'drain' portion of a few of the other cycles (heavy, perm. press, delicates) and see if it will drain/spin there. You can also try advancing the timer slowly through the 'spin' portion to see if it kicks in anywhere.
If it will rinse and spin in the other cycles, you most likely have a bad timer.
Hope this helps.
Sep 25, 2011 | Kenmore 22422 Top Load Washer
Kenmore 80 series top load washer. In the permanent press mode the machine will stop when it moves to the rinse mode. I can manually move the time past the midpoint of the cycle it will run for a minute...
So it will spin and drain when put in the spin cycle right? More than likely it is your timer if you have to keep manually setting. I would check on timer prices and go from there.
Dec 28, 2010 | Kenmore Washing Machines
Rinse cycle do not disengaged
does it drain?did you check the lid switch?
May 17, 2009 | Kenmore Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine will not drain
Replace the timer.
This is a neutral drain machine. If there is no natural pause in the timer at the end of the rinse cycle the timer is bad.
Mar 13, 2009 | Kenmore Washing Machines
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer will not spin
KENMORE 80 SERIES 110.92582110 - NOT SPINNING. I REPLACED THE TRANI, CLUTCH, COUPLER BUT I FORGOT TO PUT BACK IN THE AGITATOR WASHER. IT STILL WON'T SPIN SO WHAT NEXT
Jun 12, 2008 | Kenmore 23822 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Washing Machines Logo
88 people viewed this question
Sal De
fordexpert
Robert Rankin
