Question about Shimano Cycling
Shimano st 440 nexave shifter - Shimano Cycling
  • 18 Answers
SOURCE: Shimano st 7900 shifter,left lever apart and how to reassemble
You can download an exploded diagram of the 7900 series STI shifters here:
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/ST/EV-ST-7900-2874E_v1_m56577569830670749.pdf
You can reassemble them according to this diagram.
Posted on Jul 07, 2009
SOURCE: shimano lx m569 shifter assembly diagrams
http://techdocs.shimano.com/techdocs/index.jsp
try here
Posted on Feb 18, 2010
Coachphil
  • 347 Answers
SOURCE: With Shimano 6603 Group can you use Shimano 5703
The answer is yes and no.
The 5703 shifters will work both derailleurs and match the 6603 group as they are both 10spd.
The Tiagra will not work because it is 9spd, it will functionally shift the derailluer but you will not be able to line up the gearing.
The rear shifter needs to match the number of gears on the back (cassette) in the case of the 6603 group that is 10spd, so you can use any 10spd rear shifter from shimano. The Tiagra is either an 8spd or 9spd depending on the model and will not work with the cassette. You can use a 6603 rear derailleur with a Tiagra group, as long as the shifter and cassette are both the same.
Posted on Dec 14, 2010
dunnbiker
  • 8546 Answers
SOURCE: Is there are barrel adjustment
Barrel adjusters on road bikes are usually where the cable enters the cable stop at the top of the down tube. They're for ON-THE-FLY adjustment trimming, not overall adjustment.
You need a basic adjustment...
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Posted on Apr 13, 2011
  • 1606 Answers
SOURCE: Topic : "Shimano DuraAce Di2 ST-7970" and the
It is apparently critical for the success of the pairing operation that initial power-up of the component to be paired be done cleanly, with little or no contact bounce when the battery is inserted. Since this is done with low power high frequency radio signals, interference and reflections can be an issue. If you have extraneous gear such as metal water bottle brackets mounted near the system controller / battery pack, remove it for this operation. Do not let anyone play with R/C toys within 30 feet while you are doing the pairing, and turn off Bluetooth devices to be really sure.
  1. Remove the batteries from all components of the system except the SC-7900, including the heart rate monitor and the speed sensor. Wipe the battery contacts of the shift system with a cotton swab moistened with isopropyl alcohol (get straight alcohol if you can, rather than the 70% rubbing alcohol mix). Clean the battery terminals with a clean paper towel moistened with isopropyl alcohol.
  2. Click the shift buttons on each lever, then use a piece of wire or suitable tool to short the battery contacts of the shifting components (NOT WITH THE BATTERY INSTALLED!) for 10 seconds. This will ensure that any power bypass capacitors in the system are fully discharged and the circuitry will completely reset when the battery is put back in.
  3. Set the SC-7900 into pairing mode as described in the manual (latest version can be downloaded here). I suggest removing the SC-7900 from its bracket and parking it someplace where you can conveniently grab it when you reinstall the battery in the shift system.
  4. If there is a power switch on the system, turn it on first. Push the shift system battery into place smoothly and hold it. If you can lock the clamp in place while holding the battery so it does not slip even a little bit from the contacts you may do so. Do not give it a second push "for insurance" at this time; this may generate a contact bounce.
  5. Immediately press the Select and Set buttons on the SC-7900 to put it in scan mode and hold the SC-7900 about 1-2 feet (30-70 cm.) away from one side of the bike. The pedal on that side should be in the lowest position to minimize any effect of radio signal reflections from it.
  6. If the pairing does not complete, remove the battery, then disconnect the electrical cable from the rear derailleur. Repeat step 4 and press "retry" (the Select button) on the SC-7900 to repeat the scan. If this works, the front and rear derailleurs are separately paired devices. In that case, remove the battery again, reconnect the rear derailleur and repeat the scan.
  7. Once the shift system is paired, you can pair the heart monitor and speed sensor. Note that all of this must be done in one pairing session. Do not exit the pairing mode until everything is paired, or you will have to start over.
The graphics shown in the SC-7900 supplemental manual imply that the right and left shift levers are separate devices, but they are powered from the same battery and connected to the system at a single point. While Shimano's online documentation on this is rather sparse, the Di2 7900 system description says the system logic and communication circuits are inside the front derailleur. I do not expect step 6 will be needed. If you go through step 6 and it doesn't work you may need to disconnect the shift levers individually and try again. Once a device is paired, you should not have to disconnect it or remove power from it to continue the process with other devices.
If none of this works to pair your shifting system with the SC-7900, then the wireless circuitry in the shift system is defective (as I mentioned previously, this is probably in the front derailleur). Even if it is out of warranty, you may be able to get a warranty replacement since it is a newly discovered defect that could have existed from the factory. You will probably have to talk directly to the Shimano service department for this.
Posted on Jun 11, 2011
Exploded view of shimano gear shifter altus st-ct90
Sorry, Shimano never intended those shifters to be taken apart and serviced, so they didn't release an exploded view. Here's a link to the orginial EV document. http://bernd.sluka.de/Fahrrad/Shimano/TM/ST-CT90_1995.gif
Mar 30, 2017 | Shimano Cycling
Exploded view of parts diagram for shimano tourney st-ef40 shifters for re-assembly?
If you can't find with a search for st-ef40 diagram or on the Shimano site then it does not exist. Although not identical carefully disassembling the other shifter may give you enough insight.
Apr 08, 2015 | Shimano Tourney ST-EF40 3x7 Speed Brake...
How do sti shifters work?
there is a gear mechanism inside the shifter that uses a 2:1 ratio and is synced with the spacing of the rear cogs and the width of the chain. You cannot use a 9 or 10 speed rear shifter with 7 or 8 cog gear cluster. They are all integrated. You cannot use a SRAM shifter with Shimano gears, the ratio's are different (as a general rule of thumb, there are exceptions, but why mess with it?) Just remember that the shift, chain and rear cogs all need to be compatible and your drivetrain will work.
Feb 03, 2014 | Shimano Claris ST-2400 2x8Sp Shifter Brake...
Hi! is there any replacement for shimano ST-3300, 8 speed, right hand STI lever?? many thanks
There's a used pair on an eBay auction right now ending 6d 09h (Sep 21, 201101:52:54 PDT) that you might be able to snag for cheaper than a separate right lever. Wait til the last 10 seconds and bid ONCE. Leave time to confrm the bid.
http://www.ebay.com/itm/SHIMANO-SORA-8-SPEED-STI-3300-BRAKE-LEVERS-DUAL-SHIFTERS-8x2-8sp-/200651614761?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item2eb7c4aa29
There are other models, too.
My $.02: I'd take the opportunity to switch to Campi Ergo (also available on eBay). The brake lever is ONLY a brake lever so you don't have to tip toe around it when shifting and ALL CABLES are hidden.
Sep 14, 2011 | Shimano Sora ST-3304
Is there are barrel adjustment screw that goes into the shifter/lever on my Shimano 105 ST-5600 STI lever? The cable feels loose and other bikes (that I see) have an adjustment barrel screw. If not,...
Apr 13, 2011 | Shimano 105 ST-5600
How to dismantle and re-assemble the lever mechanisms as the levers are slipping when operated. Hopefully they are not worn internally. They are Shimano ST-T400 shifter/brake.
Here's the diagram:http://fish.shimano-eu.com/media/techdocs/content/cycle/EV/bikecomponents/ST/EV-ST-T400-S-1970_v1_m56577569830613258.pdf The lube in them tends to dry out and harden over time and needs to be flushed out with whatever is safe for the parts (cleaner/degreaser) and then relubed with some high quality lubricant. The spray stuff doesn't stay around long enough. Ask your local bike tech what he uses.I used saxophone key oil.
Aug 08, 2009 | Cycling
May 11, 2009 | Shimano 2008 Dura-Ace BR7800 Rear Road...
Cycling Logo
Top Shimano Cycling Experts
Michial Gueffroy
john h
Paul Bade
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
