Question about Acer Computers & Internet
Acer eRecovery Management (V7.5.17) - Acer Computers & Internet
GodSpeed
SOURCE: d2d recovery
Send me an e-mail and I will send you the fix! If you can't downloadload it from the below link. I had the same problem. The mbr was replaced, you have to add RTMBR.BIN to the MBR and it will work again. As long as you can get on your desktop and run this bat file you will repair the D2D again. Took me an hour to learn what was wrong, It works 100% though.
I have the Aspire 5610Z with the 2GB 533 mhz memory Stock.
Link #1
http://rapidshare.com/files/64293596/Acer_MBR_F10_Repair.zip.html
Link #2
http://www.sendspace.com/file/ngd4ql
matrix@gainbroadband.com
Posted on Oct 22, 2007
xCAUSALITYx
  • 210 Answers
Unfortunately once your original HDD has been replaced you lose all e-recovery features and there is no-way this can be reversed.
If you could get hold of the image from your old drive you maybe able to write it to your new, its a bit messy though.
The main reason for the "factory default image backup" you have not working now is because a snapshot of the C: drive is stored on D: drive so when you replaced the drive itself you basically made that disc useless for eRecovery features.
Sorry its bad news.
Cheers
Posted on Jun 17, 2008
ginko
  • 19396 Answers
SOURCE: ACER eRecovery management
Download the recovery manager from this link.
I will be grateful if you can take some time to rate the solution.
Many thanks.
Posted on Aug 31, 2008
joegoldman
  • 335 Answers
SOURCE: Acer eRecovery Management starts on boot or
Somehow, e-recovery is being triggered at boot time. click start-programs-startup, and remove e-recovery from the startup folder if it is present. If not, click start-run, type in msconfig - a window will appear. Go to the startup tab and uncheck any items with e-recovery in the name. do not delete all acer items. Tread lightly here. Anyhow, if that doesn't do it, remove the acer items one by one in msconfig and reboot after each change until it's right. Don't make a habit of using msconfig too often though.
Hope this helps!
Posted on Aug 09, 2009
envision507
  • 30 Answers
SOURCE: forgotten password on my Acer eRecovery Management
If you fully formatted the hard drive then most probably you have cleaned the PQservice division which might had recovery data; you can check this with the help of Computer Management console in Windows. It is in Windowssystem32compmgmt.msc. Also check the Disk Management and see what partitions you still have. Acer eRecovery Management won’t work if there is no default partition i.e. There should be E or D partition in order to run it.
Try www.download.com Here you might find your required software or else you have to ask the supplier to fix this problem for you. Hope this helps!
Posted on Sep 07, 2009
How do I reset my acer aspire one A150 to factory setting?
Instructions
Click "Start" and select "All Programs."
Click "Acer Empowering Technology," then "Acer
eRecovery Management."
Click "Acer eRecovery Management" in the Acer bar
that appears on your desktop. The "Acer eRecovery Management" window will open.
Click the "Restore" button.
Click "Restore System to Factory Default." Click
"Yes" to confirm. The system will restart and reset itself to factory settings.
Aug 24, 2013 | Apevia Aspire One A150-1777 Netbook
How to run backup
From the online manual:
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 In the Acer eRecovery Management window, select the type of backup you
want to create using Full or Fast.
3 Follow the instructions on screen to complete the process.
Nov 20, 2012 | Acer Aspire 4315 Notebook
HOW CAN I RESTORE MY ASPIRE KAV10 TO ORIGINAL FACTORY STATE?
press alt+F10 at acer logo displayed at first screen
you will directed to acer erecovery management
at acer erecovery management chose restore to factory setting
then follow the instruction until finish
Mar 14, 2011 | Acer Aspire 1 Xp Notebook
Missing Acer eRecovery Management icon where do I go to download the latest version or if it is located on the pqservice(z) drive how can I install the software?
Hi. This software is currently not available for download. You may check if it is still installed in your notebook.
To launch Acer eRecovery Management:
• Click Start > All Programs > Acer Empowering Technology > Acer eRecovery
Management.
To read more, click this.
Feb 06, 2011 | Acer Aspire 5610-4648 Notebook
How do i check if my acer travelmate 4230 has a bluetooth module ?
Hi, You need to Acer eNET Management, the empowering Technology,
using Acer eLock Management and Acer eRecovery Management, you must initialise the Empowering Technology password. Right-click on the Empowering Technology toolbar and select "Password Setup" this will enable you to do so. If you have not initialized the Empowering Technology password and run Acer eLock Management or Acer eRecovery Management, you must create it.
Acer eNet Management this will assist you to quickly connect to both wired and wireless networks. to access this utility, select "Acer eNet Management" from the Empowering Technology toolbar or
run the program from the Acer Empowering Technology program group in Start menu.
This should resolve your issue
Apr 06, 2010 | Acer TravelMate 4230-6499 Notebook
Restore acer one to factory settings
Download this pdf it gives full instructions for restoring XP.
http://www.acerpanam.com/...
Using Acer eRecovery Management
You can launch Acer eRecovery Management in a number of ways:
• By pressing the hotkey <Alt> + <F10> during the boot-up process, or at any
time when you are running Microsoftâ® Windowsâ®.
• From the Start menu, go to Start > (All) Programs > Empowering
Technology > Acer eRecovery Management.
Jan 19, 2010 | Acer Aspire One A150-1006 Notebook
I have an Acer Aspire 5720, ive had it for a year now and it is starting to slow down. I have lost the booklet to it and i need to do a master reset on it. Ive already backed everything up im just finding...
This was taken straight out of the manual for your model, which can be found here.
Acer eRecovery Management is a tool to quickly backup and restore the system.
You can create and save a backup of the current system configuration to hard
disk, CD or DVD. You can also backup/restore the factory default image, and
reinstall applications and drivers.
Acer eRecovery Management consists of the following functions:
1 Create backup
2 Burn backup disc
3 Restore and recovery
This chapter will guide you through each process.
Note: This feature is only available on certain models. For systems
that do not have a built-in optical disc burner, plug in an external
optical disc burner before entering Acer eRecovery Management
for optical disc-related tasks.
When using Acer eRecovery Management, you may be prompted to enter the
Empowering Technology password to proceed. The Empowering Technology
password is set using the Empowering Technology toolbar or when first running
Acer eLock Management or Acer eRecovery Management.
Create backup
You can easily create full and fast (incremental) backup images of your system
configuration to hard disk from the main Acer eRecovery Management screen.
Note: Fast (incremental) Backup is only available after a Full
Backup is made.
83
English
Burn backup disc
Using the Burn Disc page of Acer eRecovery Management, you can burn the
factory default image, a user backup image, the current system configuration,
or an application backup image to CD or DVD.
2 Switch to the Burn Disc page by selecting the Burn Disc button.
3 Select the type of backup (factory default, user, current system,
application) you would like to burn to disc. Choosing to burn a user backup
will burn your most recently created backup image to disc.
4 Follow the instructions on screen to complete the process.
Note: Create a factory default image when you want to burn a
bootable disc that contains your computer's entire operating
system as it was delivered to you from the factory. If you wish to
have a disc that will allow you to browse the contents and install
selected drivers and applications, create an application backup
image instead — this disc will not be bootable.
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
Dec 20, 2009 | Acer Aspire 5720 Notebook
How can i reformat my laptop on CD acer aspire 3000
Acer eRecovery Management requires a password to activate. The default password is six zeros (0s).
Note: These steps will return the system to the original factory installation including all factory installed drivers and applications.
Back up all data prior to using this procedure.
  1. Plug in the AC adapter and battery.
  2. Turn the system on
  3. Immediately, press ALT on the keyboard and start tapping F10.
    Continue holding ALT and tapping F10 as the unit boots up.
  4. A screen stating "Starting Acer Erecovery" should appear.
    (Release ALT and stop tapping F10 at this point)
  5. There will be 4 options:
    1. Restore system to factory default
    2. Restore system from user backup
    3. Restore system from cd/dvd
    4. Exit
OR
From the Start menu, go to Start > (All) Programs > Empowering Technology > Acer eRecovery Management.
Or try this By clicking on the Empowering Technology icon from your desktop, or pressing the key to launch the Empowering Technology user interface. Select the Acer eRecovery Management icon.
Oct 11, 2009 | Acer Aspire 3000 Notebook
Acer e-lock locked my cd-rom
Acer eRecovery Management and Acer disk-to-disk recovery are protected by a password that can be changed by the user. Follow the steps below to change the password in Acer eRecovery Management.
Boot to Windows XP.
Press ALT + F10 to open the Acer eRecovery Management utility.
Enter the password to proceed. The default password is six zeros.
In the Acer eRecovery Management window, select Recovery settings and click Next.
In the Recovery settings window, select Password: Change Acer eRecovery Management password and click Next.
Sep 01, 2009 | Acer Aspire 3000 Notebook
Acer laptop restore factory settings?
If windows is running you can start it by going to Programs, Acer Empowering Technology and run the Acer eRecovery Management. Note that on the bottom of the eRecovery Management window are 3 choices, Backup, Burn Disk and Restore. Click on Restore. Here you have the choice of select Restore System to Factory Default.
If windows is not working but the system boots -
Reboot the system and when the Acer logo appears, hold down the ALT key and press F10. This starts the recovery process, just follow the instructions.
Oct 19, 2008 | Acer Aspire 5050-3242 Notebook
Computers & Internet Logo
395 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
