Question about Microsoft Windows XP Professional
At startup SETUPLOADER.EXE-353E738A.pf failed to initialize the application
During startup this message will popup error SETUPLOADER.EXE-353E738A.pf failed to initialize the application
  • Microsoft Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Check ram modules for dirt and dust as well as ram sockets for dust and debri then reseat the modules
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
if still no joy
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue and
work your way through the problem
if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
or click start type in event viewer press ENTER
you might be able work your way through the problem
or
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
hope this helps
Posted on Nov 06, 2012
  • 19 Answers
SOURCE: LSASS.exe failed to initialize. error 0x0000005
This can happen after installing an antivirus. You might need to go into safe mode by hitting I believe F8 key after turning on computer, while you're still in the black screen and then uninstalling antivirus. You can also try the following link on repairing windows http://michaelstevenstech.com/XPrepairinstall.htm
Posted on Oct 22, 2009
  • 729 Answers
SOURCE: skypesetupfull.exe is not a valid win32 application
http://download.cnet.com/Skype/3000-2349_4-10225260.html
Try to download the file on the link above, any more problems let me know.
You can also get skype portable (this you do not have to install but you can have it in a folder of your choise) :
http://portableapps.com/apps/internet/skype_portable
REMEMBER for use Skype you have to make a account you have to use the default sign up in the program or this link :
https://login.skype.com/account/login-form?application=download&return_url=http%3A%2F%2Fwww.skype.com%2Fgo%2Fdownloading
Have a nice time over there
Posted on May 26, 2010
  • 1082 Answers
SOURCE: When i open some applications windows shows the
These error messages may be caused by the WORM_KLEZ.E virus, or one of its variations.
Go to trendmicro.com and run their free online virus scan. It can take a couple of hours to run and you must be connected to the internet.
It that doesn't do it let me know.
Posted on Sep 11, 2010
  • 145 Answers
SOURCE: The application failed to initialize
wash disk,,,,wipe with lint free cloth,,, reinstall
Posted on Nov 25, 2010
ramaly_b
  • 250 Answers
SOURCE: When i start my computer
There seems to be problem with a start up program. Check the startup programs for errors
Posted on Mar 02, 2011
Just recently everytime i startup windows xp pro an error message display SETUPLOADER.EXE-353E738A.pf failed to initialize the application
Hope this helps
Nov 06, 2012 | Computers & Internet
The application failed to initialize properly (0xc0150002). click ok to terminate the application. yahoomessenger.exe - application error. the application failed to initialize properly(0xc0150002). click...
I'm having the same problem, not quite sure whether it is happending due to upgrade to IE 8 or Windows Installer 4.5 installation. Cleanup and re-install of Yahoo Messenger 10 won't help. The YahooMessenger.exe fails to initialize right during the installation process.
May 14, 2010 | Yahoo Messenger
Bcmwltry.exe error message
Hi there!
Bcmwltry.exe is most likely a process that starts during boot. It runs the Broadcom Wireless Tray icon.
Try disabling this process from your startup configuration. To do this:
Click Start>Right-click My Computer>Select Manage
Expand Services and Applications and then select Services.
Look for an entry belonging to Broadcom Wireless. If you find it, right-click on it and change the Startup type to Disabled.
Restart your machine and watch for the error. If it doesn't show and you still have a wireless connection, your problem is solved.
If you don't find an entry, try uninstalling the software associated with the wireless adapter. Then restart your machine and watch for the error once more. If the error message doesn't appear, you'll have solved the problem; however, you'll need to double-check your wireless connection and make sure it is still functional. If not, unplug the adapter, restart your machine and then plug in the adapter as if it was the first time. Maybe a reinstallation of the software will correct the issue.
I hope this helps! Feel free to reply if you have any further questions.
Aug 16, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I have a dell latitude es400 and it keeps giving me a error messages like drwtsn32.exe-application error. The message in the box shows "the application failed to initialize properly (Oxc0000142). Click on...
You can reinstall the entire operative system with the CD that comes with your laptop, or with the restoration partition. See user's manual. This is the best way to fix error in a PC. Before restore the OS, backup your personal data.
May 14, 2009 | Computers & Internet
YahooMessenger.exe - Application Error
install new version yahoo messenger from filehippo.com
it will solve ur problem
Jan 29, 2009 | Yahoo Messenger
Hpqthb08.exe and HPQDocViewer.exe error messages
****, since you have been having many issues, I guess that your windows is corrupted.
The best way to proced is to install a clean copy of Windows, install all of services packs and updates and then install the HP software and test the printer.
I know this is a lot of work, but it probably will solve this and many other problem that you are experiencing.
good luck!
Nov 24, 2008 | HP PSC 1510 All-In-One InkJet Printer
Microsoft Windows XP Professional Logo
111 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
