Question about iLO CA3000V CD Player
CD Player shuts off when faceplate is up
I have an ILO CA3000V headunit. It plays just fine until you snap the faceplate into the up and locked position, then the unit just powers down... Im wanting to use this stereo because it just sounds better than my pioneer. Im just curious if anyone else has had this problem and if there is a fix available for it.
  • Ryan O'Rand Jan 23, 2009
    Had a pin with corrosion on it... cleaned the pin connectors and worked great
    New Friend:
  • 57 Answers
Check the pin connectors make sure there not bent and that the line up right if that dont work try lightly bending them or cleaning them if that dont work sometimes theres a little peice of plastic that triggers the radio on look on face plate or head unit to see if maybe something broke off if it did try to find peice of plastic that size and super glue it on good luck..
Posted on Jan 10, 2009
My cd wont eject
You can tried to open the cd player open and get it ou like that.
Sep 16, 2013 | iLO CA3000V CD Player
Sd problems
try a different sd, maybe the sd has bad sectors etc...You may need to run a check disk on it for...
Aug 05, 2009 | iLO CA3000V CD Player
2001 vw beetle, cd player says cd error.
the cd player lens needs cleaning do this by putting a cd cleaner disc into it or open it up urself and clean it with methilated spirits
Jul 05, 2009 | iLO CA3000V CD Player
I cant set the clock
I believe you have to hold down the display button until the clock blinks, then use the jog wheel.
Dec 01, 2008 | iLO CA3000V CD Player
Peogeou car 307 cd player
take it out & buy a mp3 player. or put a aux input to a ipod etc
Nov 08, 2008 | iLO CA3000V CD Player
Getting power yet cd player does not even turn on
first off id check the wiring/grounds, if there ok try cleaning the faceplate pins w/ alchol and a qtip if that dont work its internal
Jan 02, 2008 | iLO CA3000V CD Player
Ilo ca 3000v cd player
The RCA connections on the back of the Ilo CA3000V are exclusively for XM radio input, and do not send a 'low level' signal required for your amplifier to operate. You will need to have a 'high level' input on your amplifier to get a signal from the Ilo, this will be driven off the speaker wires themselves.
Apr 11, 2007 | iLO CA3000V CD Player
XM RADIO PROGRAMMING
For the Ilo CA3000v, all you need is an XM direct tuner box, Model XMD1000, the cable that came with the Ilo radio, and an RCA cable to connect the two. The RCA jacks and the 8-pin DIN jack on the back of the ILO CA3000v are exclusively used for XM signal translation. You will, of course, need a subscription to XM Satellite radio, but the items listed above cover the extent of the hardware you'll require. The XMD1000 comes with the antenna as well, so no need to worry about that, and all XM features are controlled from the head unit itself
Dec 11, 2006 | iLO CA3000V CD Player
Faceplate not responding / acting very weirdly
Sounds like a bad connection with the faceplate and the multi connector that the faceplate mates with when closed. check for dirt and bent pins on both connectors. Luck
Dec 14, 2006 | Sony CDX-CA900X CD Player
iLO CA3000V CD Player Logo
98 people viewed this question
Top iLO Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Libran Moreno
Are you an iLO Car Audio and Video Expert? Answer questions, earn points and help others
