Question about KitchenAid Food Mixers
Model khm9qwh5 won't start
When i plugged it in the "power" indicator light did not light up and the beaters won't turn
This particular model has some sort of internal electronics that require a charge before the unit will function. As a result, when allowed to sit in the cabinet for a long period of time it will simply not turn on. Instead, all you will hear is a "click" noise when you try to power it on. When you get the dreaded "click" noise leave plugged in for several hours and try again.
Posted on May 07, 2013
2 Suggested Answers
  • 1746 Answers
SOURCE: beater won't turn, but motor
Hi, Did you push the beater in so that it clicks. If all is good there, gear box maybe at fault or jammed. Take it to a service center for repair. If you are machanicly inclined (DIY) Take it apart and see why its not turning. Good luck.
Posted on Jun 04, 2011
Mixer won't turn on after adjusting beater height
The kitchenaid warranty is exactly 365 days from date of registration "No Questions Asked" on day 366 you have no warranty and you gotta pay.
Now the good news; first check the wall socket, I know it works but check it anyway. then check your plug, did you step on it while you were working on the machine? The plug often falls to the floor during work and can get underfoot, you may have broken the plug it'self. next you will need a parts list for your model from Kitchenaid's website.
http://www.kitchenaid.com/customer-service/manuals/
My first suggestion is to try a minor adjustment of the speed control switch, they often get out of sync when you do something to the machine. You can find several videos of this on the youtube site. "Adjusting the speed control switch on kitchenaid mixer"
If the two or one of the top 2 screws on the speed control switch move it can shut the machine down just like an on/off switch. Did you remove the back cover during your adjustments? Did you remove and replace the carbon brushes on the side of the machine while working on the machine? If you did you might have put them back in incorrectly, if you did they will also act a a shutoff switch. If you did not take them out then DON"T as there are four ways to put the brushes back in and only one way is correct and there are two brushes to deal with. Has work ever been performed on the mixer before? Because if all you did was to adjjust the beater height screw then nothing should have effected the normal operation of the mixer. So if there is anything that you did but did not include in your description of work you performed then please let us know. We strive to give accurate solutions but... as I am a KA tech I do not have any other solutions with out the machine in front of me. Just so you know you can fix this yourself.
May 26, 2013 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid hand mixer model#KHM5AP beaters hit each other
I have never seen one of these mixers myself but from your description it sounds like the gears are out of timing. Plugs covering screws often get damaged on removal, they are pretty but not really a necessary part. If you cannot get something sharp down the side to flick it out you will need to skewer a hole in the middle to get a bit more leverage on it. When you have changed the gear timing check that the beaters miss each other before you put the screws back in.
Feb 22, 2013 | KitchenAid KHM3 Classic Hand Mixer
Black and Decker Spatula Smart Hand Mixer
1990? Dump it and purchase a new one
Mar 17, 2017 | Food Mixers
I can't get the beater released from the shaft. I did exactly what the book said, push up as far as it goes and turn to the left, but it doesn't seem to go far enough.
Get a copy of the Repair Part List for your model at Kitchenaid.com
Constant pushing of the beater onto the Agitator shaft (40) can cause
it to be pushed in too far into the Planetary (33). With the beater in place,
use a rubber mallet to slightly tap the edges of the beater and push the
shaft out until you can see the retaining clip.
Now you have enough clearance on the shaft to push the beater upward
and twist it to remove it.
Aug 05, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
First time using bread dough beater It was hard to put on and am unable to remove
as far as possible.
5. Pull beater from beater shaft.
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough beater will not come off
as far as possible.
The top part of my mixer is sitting about 1/4 inch lower than it should. It's placing the beater too low in the bowl and therefore won't mix. (I tried to whip up some whipping cream but it pushes...
Download the following Kitchenaid Service Manual:
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers several models including yours.
1. Check/Adjust the Flat Beater to Bowl Clearance:
Turn screw (A) SLIGHTLY counter clockwise (left) to raise the flat
beater or clockwise (right) to lower the flat beater
2. Check the Beater Shaft (Agitator Shaft) making sure the Retaining ring
is flushed with the surface of the Planetary Assembly
Constant Pulling and Removal of the beaters can cause the Agitator shaft to move
3. If the above two still don't solve your problem, follow the service manual
directions to disassemble the Planetary Assembly and check for loose screws
Jul 04, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Beater won't turn, but motor is running.
Jun 04, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
K-beater is stuck on our Kenwood Chef and we can't remove it
I couldn't remove the K-Beater as when I tried to turn it the whole mechanism turned with it. I couldn't even remove the splashguard! I was going to take it to the Kenwood factory (a few miles from home) but then I thought I'd give it one more go and this is what I did...
  1. Next to where the K-Beater attaches in the middle of the circular plate is a lug with a pointed-shape bolt on the end. Remove this with a spanner and the beater plus gear cog can be removed.
  2. Place some mole grips or wide pliers on a worktop and sit the cogged gear in to it and grip so that it won't turn.
  3. Now you should be able to remove the K-Beater!
Perhaps someone can suggest how to stop it happening again. I haven't attached anything since but will update this post if I have any other helpful tips.
Feb 15, 2009 | Kenwood KM400 / KM410 Chef Classic Stand...
Food Mixers Logo
168 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
