Question about Garden
Need bag for craftsman model 113796811
Need a replacement bag for the above lawn vac. Part Number that Craftsman lists is 71-85681 and is no longer available.
  • 148 Answers
SOURCE: i need a replacement bag for my craftsman vacuum.
www.searspartsdirect.com probably has it.
Posted on Aug 09, 2009
lasvegasrich
  • 65 Answers
SOURCE: Looking for a manual on a Craftsman Eager-1 .
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=131.90300&productCategoryId=1503700&brandId=0247&modelName=ROTARY-LAWN-MOWER&diagramPageId=00001&documentId=00035640&pop=flush
PARTS LIST AND PICTURE.. WHAT DO YOU NEED TO KNOW OR DO??
Posted on Aug 22, 2009
vincob
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
  • 17 Answers
SOURCE: craftsman 19.5 lawn tractor w/briggs & stratton keeps flooding
This could be a number or items from no spark to a faulty carburetor, a plugged up air filter, valves out of adjustment, poor gas, faulty spark plug.
First, see if your getting spark, how about taking the wire off a plug(s) and holding it about 1/8" or so away from the plug with some masking tape while you crank the engine. You should be able to see the spark jumping the gap, it helps if it is not too light outside. If you attempt to do this with your hands, you will get a spark jolt, it hurts, so use the tape and remember, the engine could start so proceed with caution.
If you have no spark there, then you ignition or magneto is faulty. This would be unlikely in the broader scope of things. You will likely get spark. Make sure the plug is clean, take it out and inspect. If it is covered in gunk well clean it. It will smell like raw gas but you already know that. Change the plug if in doubt.
Remove and clean and replace the air filter.
If you have spark, and a clean filter it is likely a carburetor problem, Depending on the carb, it could be the choke is faulty or, as per the below.
Depending on what model you have there is a float assembly in the carburetor that stops the fuel from flooding the carb and air intake. The gas tank is higher then the carb right, so if you dont have a mechanism for stopping the fuel from leaking out the hole that goes into the engine, it will all leak out right, as into the fresh air intake because its easier than going into the engine. So, there is a miniature float assembly, sort of like your bathroom toilet float to stop the water. Well there is a small wedge type needle that seats into a hole and it is attached to a float. As the gas rises in the bowl, it pushes up the float, sealing the gas into a chamber, as you use more gas, the float lowers and more gas goes in. So ,there is dirt jammed into the float bowl sealing needle, just a little, thats all it takes. So, shut off the gas somehow, hopefully you have a valve, or squeeze the rubber line, then undo the float chamber, its one nut on the bottom. Clean carefully. The needle, little spring and float assembly are delicate. Also, the needle could be worn from engine vibration, so it may need a new needle. It would help if you described the engine and carb though.
I posted that as a solution to another problem, but yours may also be the valves need adjusting. Depending on the amount of hours, say over 200, then the valves timing will likely be off a bit. Check the clearances with a feeler gauge, it is not as difficult as it seems. Check your Owners manual for the clearance at top dead center. TDC is when you take the plug out and watch the piston arrive at the top of the cylinder through the spark plug hole when you are turning the engine over (do this by hand, battery off. Make the adjustments with the valve cover off. Follow the instructions.
Hope some of this helps.
Posted on Sep 21, 2009
  • 89 Answers
SOURCE: craftsman lawn mower wheels won't turn
take cover off the top off deck and see if your belt have came off next turn deck sideways but before you turn it sideways take air filter off cause oil can come through and ruin the filter noe look and make sure the belt is on the pully
Posted on Nov 04, 2009
Need part number 1763936 for Sears craftsman leaf vac model #987799800searsparts.com says no longer available any ideas????
Did you look on ebay?
& if you only need the bag replaced- you can try getting close dimensions
Dec 04, 2014 | Craftsman Garden
Can't find grass bag
As long as the model number is correct. Sears still carries the bag for this.
Part No. 410693 for $40 us
I found this at Sears parts direct, and yes there is a website.
Jun 17, 2013 | Craftsman Garden
I'm looking for a replacement bag for my craftsman model 358798370 blower/vac. The zipper is shot and there is a hole in it. Any ideas ?
http://www.searspartsdirect.com/partsdirect/part-number/Craftsman-Parts/Leaf-blower-Parts/530402533/0071/358/Model-358798370/0247/1503110?keySuffixId=NA&productTypeId=x&searchModelNumber=358798370&subCompDesc=Replacement%20parts&brandDesc=CRAFTSMAN&modelDesc=BLOWER&blt=11
Oct 31, 2010 | Craftsman 4 Cycle Blower/Vac
Need a leaf bag for a chipper/shredder/vac
That is actually a good price. MTD wants $225.00
Oct 04, 2009 | Craftsman 4 Cycle Blower/Vac
Old shop vac
Yes there should be a filter fitted onto the top section.
For suppliers, it would be cheapest to find your nearest stockist, or buy online and have it shipped. It's still current stock - so spares should be readily available.
Sears stock it -
CRAFTSMAN FILTER
Thank you for using Fixya,
Sep 22, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
I need a replacement bag for my craftsman vacuum.
Aug 08, 2009 | Craftsman 4 Cycle Blower/Vac
Need replacement manual
Go to Sears.com, click on the parts link, put in your model number, a parts list will come up, if you manual is available, you can click on it to buy it.
Jan 01, 2008 | Craftsman 17740 Wet/Dry Vacuum
Garden Logo
132 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
