Question about Kenmore 15899 Built-in Dishwasher
Kenmore 665 water gets too hot
How can I turn down temperature?
  • ron_sam Jan 06, 2009
    my wife complains about the dishes being extremely hot when she opens the door,and she feels that it discolors the glasses.
  • 530 Answers
Hello, your water that enters the unit is directly comeing out of your wall. then is heated at a certain point in the wash cycle. So the only way to turn down the temp would be at your water heater.
Posted on Jan 05, 2009
  • erica graber Jan 06, 2009
    I am just wondering how old is this? and how long have you been having this problem?
My kenmore 665 started pumping hot water without ever turning machine on
You might have a bad water valve, or a bad timer (especially if this dishwasher uses a mechanical timer - one that has a rotary dial in front).
Feb 24, 2015 | Kenmore 665
Why does my kenmore 665 dishwasher start pumping hot water even though its not turned on?
Dishwasher keeps running to long
Most likely the hot water temperature is the problem. If you have a separate hot water inlet check that the water temperature is ok. But if you only have a single cold water inlet then the heater inside dishwasher may be faulty. Check if the dishwasher is still cold when you terminate the cycle.
Heater is part 13 in this diagram.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-66515752000/0582/0130000/P0101063/00003?blt=06&prst=&shdMod=
Apr 04, 2014 | Kenmore 665
Clean light stays on and will not run on our Kenmore 665 dishwasher.
if you have a whirlpool/ kenmore dishwasher and the clean light is flashing 7 times then pauses and then repeats, it is a problem with the heating circuit.
follow this keypad operation: push the high temp wash, air dry, high temp wash, air dry. this will put the unit into a service mode and it will run a short diagnosis cycle. after it gets done, about 5-7 minutes, then it will reset and allow you to use the unit again.
make sure the water is hot enough at your faucet at least 120 degrees, and the door is getting closed tight.
Jan 18, 2010 | Kenmore Dishwashers
Powdered dishwasher detergent stays stuck in dispenser after wash
There is a rather delicate mechanism which controls that soap door. Often this is the first part of a dishwasher to cause trouble. Instead of using the powdered detergent in the soap holder just pour the measured amount into the floor of the machine.
Once you have used up the powder, you might wish to consider a tablet which also just gets tossed.
Sep 18, 2009 | Dishwashers
It wont start after I turned off hot water
Most dishwasher requires water at a certain temperature before starting a wash cycle. If you don't have hot water, Cold water can not have temperature sensed to qualified level for machine to operate.
Jul 04, 2009 | Kenmore Dishwashers
Water fill never stops - never! on Kenmore Model 665-16379301
I had this problem and the drain hose had become disconnected. I had a flooded basement.
Jan 10, 2009 | Kenmore 16919 Built-in Dishwasher
My kenmore ultra wash model #665 does not pump out water.
my model #665 dishwasher will not pump water into the unit
Apr 25, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Model 665/157874000/Undercounter Dishwasher
Hi First I would check to see if the water may have been turned almost off under the sink, it will be the Hot water side. if that don't help then check for something plugging the line. let me know what you find, or we can go deeper krazytech
Aug 30, 2007 | Kenmore 24 in. 15874 Built-in Dishwasher
Kenmore 15899 Built-in Dishwasher Logo
70 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
D. E. Hev
Raisin Brann
Level 1 Expert
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
