Question about Goodman GMS90703BXA Heater
How do you light the pilot on goodman model#cacf024a2a
2 Suggested Answers
  • 82 Answers
SOURCE: Finding Pilot light on Goodman Model caf024a2a
i think the ca # is for the cooling coil unit - the heater should start with gmXXXXX - if your unit is fairly new - the pilot light electronically when thermostat calls for heat the unit will not light if the burner door is open
Posted on Oct 24, 2009
Have a goodman gas pack and we lost power due to winter storm over night so now my unit is running but only cold air coming out
the pilot light runs from a very small gas jet and should not be affected by the power outage
however that is not to say that the jet may have frozen over and become blocked putting out the pilot light
AS the system needs power to drive the fan it is possible that without the fan and safety system working , the main gas supply solenoid would have shut down and that could have affected the pilot light
with the power reinstalled try lighting the pilot light
I would say that there would be a pizo starter on the front of the unit to light the pilot loght
Jan 24, 2016 | Goodman Heating & Cooling
Goodman gas heater model GUE080-4 . pilot lighs , but furnace will not . Electronic pilot lights & stays on for about 1 min, than shuts off seems main gas relay not switching on.need manual
Check roll out switches located around burner compartment.
there is a small square button between the wire terminals press firmly down on it to rest switches. If this solves the problem have the furnace cleaned and checked by a professional HVAC technician.
Bob
Jan 06, 2015 | Goodman Heating & Cooling
Where is the pilot light on a Goodman LP furnace CAPF1824B6CA
I could not find that exact model but I don't think it has a pilot. I think what you have is a faulty igniter.(its a glow plug)
You need to find it-should be on rt side just in front of a burner venturi. Unplug it and check for continuity.
Dec 24, 2014 | Goodman Heating & Cooling
We have a goodman unit that is both a/c and heat model #PGB048125-1 how do I light the pilot?
if you have a newer high efficiency furnace there is no pilot light. They are all electronic ignition
Oct 06, 2014 | Goodman Heating & Cooling
I have a Goodman forced air heating system in my attic that's only about 3 years old and I believe the pilot light went out last night in a storm. My problem is that I can't locate the pilot in the unit...
Marc, look for where the gas line enters the furnace and remove the panel adjacent to it. That should gibe you access to the pilot light. Also, look for a pilot access door, near where the gas line enters the furnace. The gas line will either be 1/2" flexible copper tubing. 1/2" black iron pine or 1/2" vinyl coated flexible stainless steel. Look for the lighting instructions inside or on the side of the unit.
Hope this helps you solve the problem.
Mar 24, 2011 | Goodman Heating & Cooling
I have a 1987 Goodman, (GU150-5 REV S) model gas furnace. The problem I have is keeping the pilot light on. I replace the thermal coupling twice, work for a few days and goes out again. Please tell me what...
If you have a weak pilot flame it could cause this. There is an adjustment screw for the pilot flame under another philips head screw that takes a small flat head screwdriver to adjust. Turning the pilot flame up may help.
Dec 21, 2009 | Goodman GMS90703BXA Heater
Finding Pilot light on Goodman Model caf024a2a. Cannot seem to find the pilot light...The blower works but no heat.
Oct 24, 2009 | Goodman Heating & Cooling
Goodman ez 1425 blower works but no heat
It has electronic ignition. no pilot light.. it uses a hot surface ignitor to light the burners. this device gets red hot (just like looking down into your electric toaster). this hot cherry red device lights your burners
Feb 21, 2009 | Goodman GMS90703BXA Heater
How do I light the pilot light on my older Goodman heating and air unit?
depending on how old the unit is , you turn the gas valve to pilot setting, hold down the button, light and hold for 1 min.
Oct 27, 2008 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
100 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
